Forgot password I need to reset or override my password on my dell dimension xp t600r
Password forgot
Darvell,
You can click the link below for resetting the Windows XP password. If the information listed in the link does not work you will need to reinstall Windows or search the internet for password recovery software.
Password Reset Windows XP
http://dell.to/188EYWd
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Sep 06, 2013 | Dell Inspiron B130 Notebook
Forgot password, Microsoft Windows xp, Media Center Edition, running on Dell Dimension forgot password, 4600 series
Forgot your Windows XP password? Don't worry about that. I have troubled the same thing before. I searched from internet and solved the problem. Now i want to share with you and hope it will really help.
Solution 1: If you have owned another available admin password, it can work. Just log on your PC->Click "Start"button->Control Panel->Add or remove user account->Select the account you want to reset->Change or Remove the password. Then the password will be reset.
Solution 2: You can use one of the password recovery software tool to reset the forgotten password. Here, i would like to introduce you one of them, which i have applied. It is really a good hand. That is Windows Password Reset . The process is following.
Step 1: Download the Windows Password Reset Deluxe from http://www.windowspasswordreset.net and burn a erasable CD
Step 2: Boot the CD into the ISO image which is provided by Windows Password Reset Deluxe
Step 3:BIOS settings
Step 4:Recover the Windows XP admin password.
It is an easy-to-use way to reset windows password.
You can have a try.
Jul 28, 2012 | Dell Dimension 4600 PC Desktop
My dell xp wont reset
You can have a try.
Jul 28, 2012 | Dell DIMENSION 3000 CELERON 2.4GHZ...
FORGOT ADMINISTRATOR PASSWORD FOR DELL PC DIMENSION 3000
Forgot Dell windows password ?
If you have already have one, so just do as below:
Here are the steps to use the disk for your password recovery.
Step 1: If you enter the wrong password when you attempt to log on, Windows will display a message that the password is incorrect. Click "OK" to close the message box.
Step 2: Click "Reset Windows Password", and then insert Windows password reset disk (or other removable media).
Step 3: Follow the steps in the "Password Reset Wizard" to create a new password.
Step 4: Log on with the new password.
If you do not have a reset disk, you can use Windows Password Reset ( http://www.windowspasswordreset.net ) to create one.
Jul 19, 2012 | Dell Dimension 3000 PC Desktop
Need to find out how to unlock my password for my dell 2400 desktop
I forgot dell password, i just reset the password by the following steps,
Step1.Download Smartkey Windows Password Recovery from recoverlostpassword.com and decompress it on that PC. There is a.ISO file. Burn the .ISO file to CD or USB Flash Driver.Step2.Get out the newly created CD or USB Flash Driver and insert it tothe locked computer.Step3. Re-boot the locked computer and then follow the process ofinstructions. Just after a few steps, the old password will be removed.It can recover all Windowsversion.
May 17, 2012 | Dell Dimension 2400 PC Desktop
How do i reset my windows xp password if i have forgotten it
Forgot Windows XP password? The first thing which you check is whether you forgot windows xp login password or not. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forgot your user account password then try this:
Start system and when you See Windows Welcome screen / Login screen, press ctrl+alt+del keys Twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
Windows XP and further versions also provide another method to recover forgotten Password by using "Reset Disk". If you created a Password Reset Disk in past, you can use that disk to reset the password. Or try free program called Ophcrack or Windows Password Recovery Tool 3.0.
More detail guide on: http://www.windowspasswordsrecovery.com/bypass-xp-password-in-safe-mode.htm
Dec 01, 2011 | Dell Dimension C521 PC Desktop
I forgot my adminstrative password for dell dimension 2400 pc (windows xp)
Oct 09, 2009 | Dell Dimension 2400 PC Desktop
Forgot password
If you forgot your bios password.
Then first try with defaulots passowrd "dell" or "DELL"
then if still same issue then open cpu cabinet and pull cmos cell from motherbord for 10 minutes so all settings are back to defaults. so then it not wan't password.
Let me know if yolu need more assistanse.
Thanks.
Aug 30, 2009 | Dell Dimension 4500 PC Desktop
Forgot my password to my dell dimension 3000, how can I reset?
It's a large file, but you can download and burn a copy of:
http://www.ubcd4win.com/
It's a bootable cd that has a password recovery tool plus a lot of other stuff.
Feb 13, 2009 | Dell Dimension 3000 PC Desktop
Password Problems
Could you be more specific , which password are you talking about. Does the system prompt you for the password after the windows Xp screen loads or at Dell logo screen.
If its a problem with the windows xp password, you can try the following option
1. Restart your computer at the Dell logo screen tap on the F8 screen 5 - 6 times
2. Select safe mode from the advanced options menu
3. Hit enter
4.Hit enter again
5. Select adminstrator login
6.Reset the password. a. Click Start, and then click Run. b. Type control userpasswords2, and then click OK. c. On the Users tab, click the name of the user account that you want to reset the password for, and then click Reset Password. d. Type a new password in the New password box, and then type the password again in the Confirm new password box, and then click OK. e. Restart the computer, and then try to log on to Windows XP again.
Note : If you donot have the adminstator account , then you might need to reset the computer to factory defaults.
Thanks
proton
Nov 04, 2008 | Dell Inspiron B120 Notebook
Computers & Internet Logo
David Payne
David Payne
