Question about Navman GPS
How to replace battery on navman MY60T
Navman MY60T battery needs replacing
  • 4 Answers
SOURCE: navman icn 320
carefully pull off front grey cover with your thumb, next to card socket, underneath are 4 security screws you need a small torque head screwdriver, take off cover losen security screws inside around battery, unplug and remove battery, replace in reverse.
Posted on Jul 16, 2008
SOURCE: Navman Tracker 5500 Marine Chartplotter
Yes the screen is replaceable, there are four screws holding it to the PCB and a short ribon and a two wire power lead.
Posted on Oct 21, 2008
SOURCE: f20 navman error
I have had the same problem and did what gossages recommended and it worked straight away thank you very much!!!!
Posted on Jan 13, 2009
PlatoAu
  • 67 Answers
SOURCE: Navman Pin570 battery replacement
There are 2 little black tabs at the botton of the back that you have to remove, behind these there are 2 screws u remove, and flip the ariel up and there are 2 screws under there you remove also.
The body is clicked together use a guitar pick, ur fingernails or small scewdriver to seperate the 2 sections.
Inside you will see a few screws holding the systemboard down, if need unscrew them.
you will see the battery its stuck onto the system board... be carefull seperating it,.. use a flat intrument or a butter knife to work it of the board ( its stuck on with double-sided tape or some kind of silicon)..
unplug it,
plug your new battery in.. BONGO
Let me know how you go.
cheers
plato
Put it all back together again
Posted on Apr 02, 2009
SOURCE: how do i replace the battery Navman S30?
dead useful Falter!
OK - remove the 2 screws on the bottom, then to open the unit you have to unclip the end panels... from the back, use an old card of some sort (I just used a hotel room key)
If you need to, cut a slight angle on an edge to let you force it into the groove. slide it about, pushing outwards and you should find the ends will un clip. there are then 2 more screws on either end to un do. The back then carefully unclips from the top and bottom panel. the battery is then free to be replaced.
Posted on Dec 07, 2009
Can I download maps for South Africa onto the Navman Ezy 40 Series?
No you can't. They are not available.
EZY/MY - Series
EZY15/EZY45/EZY30/EZY40
MY60T/MY65T/MY75T
MY80T/MY85XLT/MYESCAPE Download GPS map installation guide Australia Download GPS Map Purchase GPS Map Western Europe Download GPS Map Purchase GPS Map Eastern Europe Download GPS Map Purchase GPS Map North America Download GPS Map Purchase GPS Map NAVMAN GPS MAPPING
Feb 28, 2016 | Navman GPS
Does the same apply for the NavMan S100T battery as you can buy replacement batteries for this model?
No. From the manual: "Your Navman contains a non-replaceable internal lithium-ion polymer battery."
Mar 05, 2012 | Navman GPS
I purchased a Navman MY50T Christmas before last and do not use it on a regular basis. Yesterday when I went to use it after fully charging it, it ran out of battery power within 5 minutes and did so...
yes you need to replace the batt the reason for burn out so fast can be a number of things from moister getting into it during storage to simply bad line assembley
Jul 01, 2011 | Navman iCN 520 GPS Receiver
Navman my60t freezes on start up any idea how to fix it thanks for your help
Thanks for visiting FixYa!
For assistance with this problem, call Navman at:
1300 628 626
Have the following information ready:
Model:
What type of Navman do you have?
Date of Purchase: When did you purchase your Navman?
Detailed description of the fault: What seems to be the fault/problem with your Navman?
Serial Number: What is your Navman's serial number? The serial number is usually found on the unit, beneath the barcode.
Warranty Information: Is your unit covered by warranty? If your unit is covered by extended warranty, please contact the extended warranty company first to obtain a claim number before calling out customer service team.
Jun 27, 2011 | GPS
I appear to have lost all my maps on my (my60t) after downloading available maps from nav desk Only puurchased four days ago.Please help
Check your downloads directory on your hard drive. You should be able to get there by going to "My Computer" - " Drive C-Local Drive" and the it would either be "My Documents" or "Users" - "Downloads" or "My Documents" .You can also go to Start - Search and search for files with a date stamp of the date you downloaded them. You should also be able to go the NavMan website and just re download the files to your system again and note the folder it is saving them to.
May 14, 2011 | Navman GPS
Navman My50T - screen has frozen, can't get any other screen apart from initial start-up screen (except for screen showing connected to computer when connected by usb).
Had a similar problem with a MY60T.
Spoke to Navman support.
1. Connect your unit to the computer.
2. Use windows explorer to go to the Navman folder
3. Go to the database folder.
4. Delete "Database.db"
5. Switch off & re-start you unit. The databse file is re-created on startup
Dec 24, 2010 | GPS
Navman n60i how to replace battery
Do i need to keep power to my Navman N60i as i change the battery,or is it ok to remove the battery and place the new one in. Will i wipe out the memory.Thank you.
Aug 30, 2008 | Navman NavPix N60i GPS Receiver
When i switch my navman F series on it comes up whith a cross over the battery but it shows it as charging and will not go past the large circle of dots? please help???
Basicly that tells me you have a faulty or dead battery, does the unit stay on at all when unplugged? If the unit shuts off when unplugged this means you need to replace the battery in your unit.
please post your navman model if you require further assistance.
Thanks,
ekse
Aug 20, 2008 | Navman GPS
Navman icn 320
Jan 03, 2008 | Navman iCN 320 GPS Receiver
GPS Logo
125 people viewed this question
Top Navman GPS Experts
Neil Gossage
Level 1 Expert
Are you a Navman GPS Expert? Answer questions, earn points and help others
