Question about Camp Chef Triton 10L Portable Water Heater
Triton 10 L wont light up has inginiton but not getting gas
Not getting gas water is on ingnitor sparks but no gas.tanks full
    Problem Solver:
  • 10 Answers
There is something that must be blocking the pipe for the gas to flow check the pipe
Posted on Feb 20, 2014
1972 atwood water heater
Check your propane tanks (are they full?), make sure the valve is on, then check to make sure gas is making its way to the hot water tank, if the pilot lights but won't stay lit your flame sensor is faulty.
May 14, 2014 | Water Heaters
Shuts down and needs to be restarted
Have you tried new batteries? Mine lighted fine but would then go out. The batteries provide the spark but they also keep the gas valve open.
Oct 21, 2013 | Camp Chef Hwd5 Triton Hot Water Heater...
After years of problem free hot water the pilot light went out and now when trying to re-light the pilot light as per instructions it does not light although the spark is strong and hitting the ther
look at label on side of unit, then add a comment with Brand and type of gas water heater.
AO Smith tank-type, or Rheem tankless so expert can suggest best solution.
Tank-type:
Gas control could be bad.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Water heater is in lockout because combustion chamber overheated and tripped FV system because air intake is clogged.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Oct 10, 2012 | Water Heaters
How do I drain the tank for maintainence?
Turn the gas valve to pilot and leave it there. This way the pilot will stay on but it wont try to heat and you dont have to re light the pilot. Turn off the water supply valve to the heater. Open the drain valve at the bottom of the heater and hold the lever open on the pop off valve towards the top of the tank. This will allow air into the tank and it will drain faster. If there is not a floor drain nearby you can hook a garden hose to the drain valve. When you are finished do not turn the gas valve back on until the heater is full of water. Open sink faucets when filling tank with water to avoid excess pressure.
Jan 30, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
I have a Atwood 10 gallon electric/ propane water heater on the Hornet travel trailer I purchased used. There are two switches on the wall, one is an on/off switch that lights up and the oither is just an...
The two switches control the water heater either in the gas or electric mode. The switch with the lights would be for the gas operation, and the switch without lights would be for the electric mode. Prior to operating either switch, make sure the water tank is full of water. Turn your hot water tap on, if water comes out, tank is full. Connect trailer to 110 Volt source, turn circuit breakers on, Place switch without lights to on position. If water does not heat in 45 minutes, Install new heat proble. The gas mode should be repaired by someone that is familiar with that system. Atwood can provide you with a local service center.
Oct 10, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
My atwood water heater has spark and will light
If you see a little short round (cut-out)diode-like piece inside a clear plastic sleeve that runs from wiring to thermostat terminal,(usually right under pressure relief valve) remove it from the thermostat terminal, as well as wiring from heater (take it right out of the circuit) and connect that wire directly to the spade connector where it was attached at thermostat, and now try it. They are a one shot cut-out, and if it went, no power gets to the system and by removing it, you will see if it's the problem or not. They are a safety device that if for some reason you get too large of a flame from water heater, and it feels the flame/heat, it blows and cuts off power. Should be replaced when you get a chance, but at least you'll know what the problem is. Let me know if that works please.
Jul 16, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Water heater in my 1988 minne has spark at ignitor but no gas has gas inlp tank
turn off LP tank valve. let sit for 5-10 minutes, then slowly open LP tank valve. opening the valve too quickly cause a ck valve to close. It's a safty in the event of excessive gas escape like a damaged regulator or hose. just barely crack it open and let the system balance. do not open suddenly.
Good Luck
Apr 20, 2009 | RTO Atwood Water Heater - 6 Gal LP
Bosch 1600H NG
I hope this helps!
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/1600HTechSupport/Troubleshoot/tabid/1094/Default.aspx
Copy and paste to google search engine!
Jan 29, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Water heater is not heating water up
Every part has been replaced by new units except the tank and the water do not heat up the water. The water is hot 3 inches on the bottom and three hour later the water is still cold on the top of the tank.
The ingnitor is still lite and the flame is still going but I dont get hot water. The Gas Company assured me of no leaks and ever part was in place. Whats the problem?
Jan 26, 2009 | Water Heaters
Camp Chef Triton 10L Portable Water Heater Logo
191 people viewed this question
Top Camp Chef Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Camp Chef Water Heater Expert? Answer questions, earn points and help others
