I need to reset my password on my Dimension xps t600r]
Resetting administration password on xps 435mt
download password recovery software and boot it....
May 12, 2014 | Dell Dimension 4500 PC Desktop
System password for dell xps gen 4
There is a reset jumper on the motherboard or look for similar issues on various Dell PC forums and how the were fixed.
I know there are special programs that you have to pay for to retrieve the PW, as a last resort.
Apr 07, 2014 | Dell Dimension Computers & Internet
Need new video card for dell U2424 motherboard
What is the Dell model? XPS-G2? This is a Laptop?
Jan 17, 2013 | Computers & Internet
Unlock bios on xps 710
HI
TRY TO REMOVE BATTERY
IF DOESN'T WORK SEARCH FOR SERVICE MANUAL
Feb 18, 2012 | Dell Dimension XPS PC Desktop
How to reset admin password in bios on dell xps 400. Or is there a default or backdoor password for dells?
no default password is there..if you want to enter the bios..start the desktop..hit either F2 or F12 and it will open up the bios for you. you shld be able to find a option of password in that..
Feb 23, 2010 | Dell Dimension XPS PC Desktop
What is the 6 pin
You can replace the power supply in this Dell with a normal ATX power supply. Make sure the total wattage is equal to or greater than the old power supply.
Oct 02, 2009 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
Transfer data from Dinension hard drive to XPS hard drive
If you have no experience with this, it might be easier to just copy the data from your Dimension to a external usb harddisk and then to the XPS. But i will try to explain it.
I've looked a bit around: your XPS hard drive is a SATA drive, while your the drive in your Dimension is probably a PATA-drive (just connection types. Look at the hard drives and compare them with this image to see which types they are.)
As far as I know the XPS 530 has a Foxconn G33M-S motherboard, which contains one ATA (PATA) connector. So you should be able to just connect the hard drive from your Dimension into the XPS.
To make it work properly, you should set the drive from the Dimension to slave. This can be done by setting the jumpers next to the cable connector. The jumper setting depends on your hard drive model. Usually the possible settings are shown on the hard drive.
If you feel uncomfortable with this whole thing, you could ask someone, who has some experience and who you trust to do it for you, or just use an external usb hard disk
Make sure the computers are off and disconnected from the power outlet, when you open the case...
Dell offers a user manual for your Dimension and XPS. Maybe it's of some help by removing and placing the various parts...
Please tell me how it worked out.
As you probably understand, I can't take any responsibiity for damage to your system...
If you have any problems, just post them here!
May 31, 2008 | Dell Dimension 4600 PC Desktop
Transfering data from one desktop to another
sol 1 you can burn your data in dvd or cd
sol 2 you can transfer your data in thumb drive (pen drive)
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
