Question about Dyna-Glo Heating & Cooling
Company number-1877-4474768 The heater almost caught my 3900sq house on fire. It also ruined my carpet with soot on everything. I don't know what to do this is the second problem I've had with this heater
    Top Expert:
  • Dyna-Glo Master
  • 44,435 Answers
I would quit using it .
Posted on Feb 16, 2015
4 Suggested Answers
  • 2519 Answers
SOURCE: Fire and Heaters producing soot.
no its not gas it sounds like fumes get them checked over asap the localgas company will check them out for you
Posted on Jan 14, 2010
  • 8 Answers
SOURCE: need customer service ASAp my
I just had the SAME problem with an Aloha Breeze Tower model # 02044, mine just buzzed, sparks started coming out and it smoked! Fried and dead -- could have burnt my house down! Scary made in China JUNK! :-( Beware!!!
Posted on Dec 03, 2010
SOURCE: natural gas heater
Stop burning candles
Posted on Apr 15, 2013
Black oil smelling soot coming out of heater. It also makes a squealing type of noise. It is natural gas. Pressure by utility company already checked. It fires up fine and remains on, but doesn't look...
i think you are on the right track. the gas company will verify the pressure going to unit but it sounds like the gas control valve on your heater may need to be adjusted. for that you will need a licensed gas fitter. call your local pool company or the company who installed the heater. directions on how to adjust the valve will be found in your owners manual
May 30, 2014 | Hayward H Series Pool & Spa Heater...
I noticed soot in my lp gas oven that had been clean. concerned when it started to ruin my food I decided to run the self cleaning cycle again. My whole house filled with toxic soot. My eyes were on fire...
Normally soot is from a range that hasn't been converted for the gas type, like natural or propane. It may be set up for natural when you're on propane or visa versa. Has this range ever worked properly without sooting?
Sep 20, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Hi there my home is about 3 years old. i have noteced black dust on the doors window frames basically everywhere. i don't know why.
Does this unit have an blower? If so there is no filter and this can happen.
Direct vent means no open flame in the house but you might still have a combustion problem. Open the front cover and check for black soot. Also check outside at the flue for soot. If so then you need to get this thing checked. Also make sure the little door for the pilot is closed. May have a improper install here if only 3-years.
Sep 05, 2011 | Empire DV-215 Direct Vent Natural Gas...
Our Rinnai gasheater is in 'n working condition but since we used it the white walls and ceilings are covered with black marks - I am worried that it could be dangerous - any advice?
Unfortunately, you failed to mention the Model Number and whether its a flue-less or Vented unit. In either case, the black streaks you see on the walls and ceilings is soot. If it's a flue-less unit, this is an indication that the unit has not received routine maintenance on a regular basis. The sooting is caused by a dirty or clogged burner or low gas pressure.
Also, burning scented candles and operating the heater at the same time, will cause soot. Not from the heater, but from the candles. All candles soot, but scented candles soot more than others. Combine them with the warm moist heat and they will soot 50 times worse. If this is the case, it's the candles sooting, not the heater. Stop burning the candles while the heater is in operation.
Is the soot dangerous? Yes, to the point that you are breathing it in, when it;s floating in the air. The sooting didn't occur over night, it has been doing it for sometime. You finally realized it, when you saw the black streaks. Stop using the heater until it is professionally serviced by and authorized Rinnai Service Technician and the walls and ceiling are cleaned.
You can either remove the soot yourself or have it professionally done. Then, you should prime paint the walls and ceiling with a sealer like Kilz, before repainting. All curtains or draperies should be washed or dry cleaned. All furniture and carpeting should be vacuumed thoroughly.
I hope this helped you and thanks for choosing FixYa.
Aug 10, 2011 | Heating & Cooling
Is it allright to burn part deisel with kerosine in a Toyo laser ignited heating stove?
Only if you want to stink up the house (more than just what the kerosene does) and don't mind dealing with a little soot on the walls and ceiling.
I wouldn't. But the choice is yours to make.
hope this helped you in some way. Please let me know. Thanks.
Jun 09, 2011 | Rinnai Toyostove Direct Vent Heater:...
Jan 10, 2010 | Cozy (W352E) Heater
Kerosene heater smoking
Hi, I would say that you have a build up of soot. Kerosene and propane heaters are notorious for this, you wouldn't think so but it happens a lot.Carbon up and soot.You will have to open it up, the combustion chamber and give it a good cleaning. I would wear a dust mask as soot as i am sure you know, will get on and in everything. Please let me know how it goes and if this solves the problem.
Good Luck,
Shastalaker7
Nov 07, 2009 | Heating & Cooling
HOW DO YOU BY PASS THE FLAMABLE VAPOR VALVE ON A HOT WATER HEATER
You buy a new water heater AND have a QUALIFIED person from your gas supply company or a qualified plumber install it.
You bypass that valve and you're just asking to blow up yourself, your family, and possibly any nearby neighbors. They'll be picking up pieces of your house a quarter mile away.
As the other posters said, too, any means of bypassing this valve is in violation of all kinds of local, state, and federal laws, voids your warranty, and will definitely be found by the fire marshal when they try to determine what caused your house to suddenly explode, thereby ruining your chances at getting a settlement from your insurance company. They may even classify it as arson. All points considered, and no offense intended, it would be downright stupid given the safety implications.
Go to YouTube and search "propane explosion" or "natural gas explosion".
May 23, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
I placed yam to microwave - left room and came back to see yam on fire (black as coal) and now my microwave control panel does not work - the yam was on fire before I put it out. filled the house with...
my son did the same with a conker /horsechestnut micowave full of soot kitchen full of smoke microwave was no more / the soot got in to everything just had to replace it
Jan 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Heating & Cooling Logo
61 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
drifterray
Level 1 Expert
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
