Question about Kyocera Office Equipment & Supplies
Where is cassette 1 on kyocera - Kyocera Office Equipment & Supplies
I have a Kyocera FS6530MFP Printer and gives a ' error in cassette 1 ' message. Any clues?
Could be the rollers in that cassette are worn and causing a delay jam (Not picking the next sheet up) Try cleaning them.
Aug 13, 2014 | Kyocera Office Equipment & Supplies
C0500 problem solution km6030
This indicates that cassettes 1 and 2 are not communicating correctly with the machine. Try removing the cassettes from the machine and ensure that no paper is jammed where the cassettes will meet the rear of the machine. Please ensure that you unplug the copier before you attempt to remove any obstruction.
Jan 11, 2014 | Kyocera Office Equipment & Supplies
Kyocera echosys fs1135 mfp with jam code 0501
It jamming from cassette one ,if you remove the cassette look inside where the cassette came out of and you will see two grey/blanch roller give them a good clean with a damp cloth and your problem should be fixed
Oct 11, 2013 | Kyocera FS-920 Laser Printer
Kyocera fs 1920 installed on windows 7 64 bit cassette 2 not showing
Download the KPDL drivers and after they are installed go to the printer properties, then device settings and select how many paper feeders you have "in addition" do the 1st tray. So if you have two trays just pick "one" for that option. Then you will be able to scroll back up and choose what paper type it is.
Lastly, set your Printing Preferences in the properties if you want to specify a specific tray/cassette to print from or just let the printer auto select.
Jul 27, 2012 | Kyocera Mita FS-1920 Laser Printer
Sir! the problem of our kyocera mita fs 3800 is this that it gives us message that the paper is jam please open the cassette 1.and remove the paper. we opened the cassette 1 checked the tray but there is...
Try cleaning the paper feed rollers for that cassette. Sometimes the rollers get dirty causing the paper to slip and not feed from the cassette causing the machine to register a paper jam.
The rollers can be cleaned with rubbing alcohol and a cloth.
Apr 04, 2011 | Kyocera Mita FS 3800 Laser Printer
Print out landscape
Make cassette number 1 8 X 11. Load paper portrait in tray 1
Mar 08, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera FS 4000 cassette error
under the front of the cassette on the bottom is a white catch if you pull it towards you the paper will spring up. more then likely it is not automatically getting pushed when you put the cassette in.
if this is not correct if you take the cassette out and look in where you took it out of there should be a arm hanging down just left of center that is the paper out sensor arm of that is broken it could be your problem also
Dec 16, 2008 | Kyocera FS-4000DN Laser Printer
181 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
