Question about Breville BKC600XL Coffee Maker
Water leaking at drip tray
Water leaking at water tray when it goes into cycle
2 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: In standby mode water tank continued to completely
Try backwashing the machine with espresso machine soap. There might be something keeping the brew solenoid discharge open.
Posted on May 17, 2009
Model 1068630583. Why is it leaking water on the floor?
Remove the floor grille and check drip pan if full carefully remove and drain water if pan is dry [pan is drip tray from auto defrost water goes to pan than usually dissipates ] if dry look to back at water line for damaged or leaking line or valve
Aug 11, 2015 | Kenmore Refrigerators
Leaking water on floor
remove the floor grille and check drip pan if full carefully remove and drain water if pan is dry [pan is drip tray from auto defrost water goes to pan than usually dissipates ] if dry look to back at water line for damaged or leaking line or valve
Aug 11, 2015 | Refrigerators
Water is leaking from the bottom of the refriderator
Blue connector means nothing to me but I guess the water is generated by the auto-defrost function where any frost or ice that is created is melted by a brief heating cycle and the water collects in a sort of funnel or vee shape moulded into the internal plastic liner near the bottom.
The water then should run through a tube into a tray on top of the motor unit where the heat evaporates it.
Sometimes the tube becomes detached or blocked or otherwise preventing the water from collecting in the drip tray. A closer examination should reveal the trouble.
Aug 08, 2015 | Refrigerators
Water appears on the floor outside the fridge. I have a side by side fridge freezer, Magic Chef
There's a tray under the refrigerator that catches the water dripping down when your auto-defrost cycle runs. Usually this water evaporates before the tray overfills. Either you don't have enough air flow around the refrigerator for the water to evaporate, or the tray may have developed a leak.
Oct 10, 2014 | Refrigerators
Pim10bls
Possibly the water control valve is leaking when shut off, and water constantly drips into the ice tray fill tube. When this happens, the fill tube becomes clogged with ice, and the ice tray does not fill. The ice tray will cycle often, because there is no water in the tray, but will remain empty. If this is the case, the water control valve at the bottom rear of the refrigerator will have to be replaced.
Jul 31, 2014 | Polar PIM10BLS Portable Ice Maker
Kenmore refrigerator model 795
This is a simple fix but will take a little time to correct this. First of all, empty the freezer of food and shelving, ice maker if you have it also. The back wall in the freezer is a false wall, so gain access by removing screws and harness from top left corner. By the way turn off the unit or unplug it!! Now at the bottom of the unit far back you will see an ice glassier in the bottom middle is a drain hole that all the water is to exit after defrost. Well because its blocked with ice the water overfills and leaking into the refer section. Make sure you can use hot water to clear this out but make sure you cleaned out the entire drain system before reassembling this to restore cooling. Once clear you problem is solved.
Good Luck
Oct 29, 2013 | Refrigerators
My frost free freezer has had a small puddle of water under the front right corner several times now. I unplugged it and let it defrost completely thinking that would stop the problem but it hasn't. Can...
There is a chance the water is coming from the drip tray and or the drain hose to the tray.
when the unit goes into a defrost cycle it is leaking from one of those places check and make sure the hose is in the drip pan correctly and that the pan is also mounted properly and level.
If there is is a lot of water in the pan you may need to check the door seals on you unit and make sure they are sealing properly.
If there is an air leak then the unit could have excessive ice build up and also be defrosting more than usual amounts of water.
Jan 02, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Water is leaking from the bottom of the fridge. Why? It is destroying the wooden floor. Refrigerator is Whirlpool Model # ED25UEXHW01
Some water dripping under the refrigerator is normal. There is supposed to be a drip tray to collect it, and there is not so much that it can't evaporate. Check to see that the tray is still there, in the right place, and not cracked. If the drip tray is full of water, then you have another problem. If your air is humid, you would get more water during the defrost cycle and the water in the drip tray wouldn't evaporate very fast. If your freezer door seal is not air tight, you would get more water to defrost. My guess is, the drip tray is out of place or cracked.
Sep 11, 2009 | Refrigerators
Ice maker drip into ice bucket and manual cycle leaks more water
Need to take the ice maker out to measure the amount of water input into the ice tray. In this case the tray was already full (from the leaking valve). The spillage I saw was just the tray overflowing. Time for a new valve.
Apr 28, 2009 | Kenmore Refrigerators
Breville BKC600XL Coffee Maker Logo
82 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
