Question about Behringer Europower Pmp5000 Powered Mixer Pmp5000
How do i connect focusrite to europowered pmp4000
    Scholar:
    New Friend:
  • 125 Answers
You don't say what item of Focusrite equipment you are trying to connect or for what purpose. Most focusrite stuff has jacks with analog outputs for each channel that can be used into the line ins on the mixer and jack/xlr combos that can be used to take a signal to the focusrite box. Then you get the firewire side for the PC and digital outputs as well which will not be of use with your mixer.
Posted on Apr 15, 2014
I'm Ziro. I need a part list for the main power supply board for behringer pmp4000 mixer, two transistors were removed from it and I need to know the part numbers of each in order to install them.
In my opinion, due to the physical appearance of pmp4000 and pmp3000 look the same, it will most likely also have a common circuit and parts list (at least, most).
Usually Behringer (and all the manufacturers), with the same series / sequence, using the same circuit, the difference is the number of channels only. You can compare the parts list on PMP3000 schematic, with your PMP4000.
PMP4000.
PMP3000
You can download from this link.
http://elektrotanya.com/behringer_pmp3000_sch.rar/download.html
Hope this helps.
Regards.
Oct 05, 2015 | Behringer Music
How to uste focusrite with europower pmp 4000
You will need to give more information for a proper reply, which unit you have and what you want to do with it, what into it and what out etc. In principle you can treat it as a pre/post mixer using it's ins from either the aux or group outs of the mixer or conceivably the inserts depending on what you want to do. You could use it in front of the mixer or as an adjunct. Please tell me what you are trying to do.
Feb 04, 2014 | Behringer Sx2442fx Eurodesk 24channel...
Behringer pmp4000 keeps dropping an ouput channel while playing live!
The PMP has an electronic overload protection. If you overload one or the other of the outputs, it trips the protector and you have to cycle the power off for a bit to reset it. You haven't mentioned what speakers you have. Be aware that the impedance can be no lower than 4 ohms on either channel. In addition, I have seen some particular speakers that have transformer attentuators in them that this amp is NOT happy driving. You could not attach more than two 8 ohm speakers to each of the outputs without tripping the protector.
Feb 21, 2012 | Behringer Europower Pmp5000 Powered Mixer...
Pmp4000 unit. can i designate different effects to different channels at the same time?
only 2 effects can be used at a time. you assign the effects in your lil digital section in the master part of the board by turning the black knobs so the lit up numbers change to the effect you want then push the black button to lock it in. at which 2 of your aux's ( the last 2 i think its 5 and 6 ) control the SEND to your EFFECTS and the fader below the selections control the amount of effects goes into the MIX.
Aug 31, 2011 | Behringer PMP4000/B1520 PRO Mains &...
I need know; what is the componnet OP1 (R3B 303)? thanks,,,
Look for numbers on the chip... It appears that in other gear that I can get schematics for Focusrite likes the NE5532 and the NE 5534 chips for op amp service.
Jul 15, 2011 | Focusrite Twintrak Pro
I have a Focusrite Pro 10 i/o Firewire Interface and am experiencing 60 Hz hum through the mic pres when phantom power is switched on with the power supply attached. Phantom power running from 6-pin...
I assume you are using condenser mics as you would NOT be using phantom power with any other type connected or other devices plugged in while you have phantom power. It is important to have ALL interconnected equipment, including the computer, powered from the SAME receptacle or power source. Make sure the power supply you are using is SPECIFICALLY for the unit from Focusrite as some supplies have filtering within the wall transformer module and others do not. The power supply MAY be generating magnetic fields... try moving it around and see if hum is affected. The capcitive coupling in a power supply can let in higher frequency components from lamp dimmers. Make sure you have no lamp dimmers anywhere near the equipment.
Apr 25, 2011 | Focusrite Saffire Pro 26I/O 26 In/26 Out...
My Focusrite ISA428 has some consistent issues where channel 1 buzzes, and channel 4 is unusable for 2 hours after power up. Channel 4's needle goes right up to the meter and stutters there for an hour,...
Does this happen with no mics AND outputs connected? If it doesn't, you have a severe ground loop problem. Make sure ALL interconnected equipment is powered from teh same receptacle or power source. Use ONLY balanced lines, XLR or TRS cables. A possible problem MIGHT be supersonic feedback that you can't hear but is saturating the amp. Thats is why we disconnect all inouts and outputs and observe if symtoms are still there.
Apr 06, 2011 | Focusrite ISA428 Pre Pack quad microphone...
Behringer pmp4000; not getting much volume from system 2 speakers going through main 1 out both L R A/B switch is to the top main L R tried guitar computer in channels 9/10 via rca still minimal...
You would get about 200 Watts RMS per side using 8 ohm speakers. "Not much volume" is very relative. With the two 12 inch speakers you should be able to fill a 600 to 1000 sq ft room nocely.
Mar 05, 2011 | Behringer PMP4000/B212XL Mains & Monitors...
Behringer Europower Pmp5000 Powered Mixer Pmp5000 Logo
59 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
