Question about VCT Electronics Simran Ac-2000 Step Up Down Voltage Converter Transformer 110v 220v
How to wire a simran THG-15000 inverter - VCT Electronics Simran Ac-2000 Step Up Down Voltage Converter Transformer 110v 220v
Simran av-5000
What Simran? What is the problem you faces with this TV?
If you wish to get some details; check the site linked here. Pull up older posts.
Aug 20, 2016 | Televison & Video
Rpms fluctuates while idling what could be wrong with it
Sounds like a vacuum leak check vacuum hoses including PB hose
Apr 09, 2015 | MagnaFlow 2000 Dodge Ram - 3500, 8.0L V10,...
Toshiba 32RV530U picture comes on for a while disappears for a few seconds and comes back then disappears again and does not come back, but there is sound
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Jan 20, 2015 | Toshiba 32" regza 32rv530u 1080p...
Suburban air conditioning
googled:
"suburban air conditioner 15000-48254C966" and got specs right here:
http://www.adventurerv.net/coleman-15000-btu-roof-air-conditioner-top-unit-p-1332.html
good luck.
Sep 03, 2014 | Electrical Supplies
What kind of Fuse do I need for a THG 1500 power converter?
No idea as not sure what this converter is to start with ,is it a solar 12v to 220v inverter by any chance
May 20, 2012 | Cars & Trucks
WILL A TRACE 2000 WAT INVERTER RUN A RV 15000 BTU AIR CONDITIONER
It can but you are not going to do it off a single deep cycle battery, You will need to have some robust batteries to sustain it. But that will almost need to be the only thing on that inverter.
It might be better to spend a little more and get the Air conditioner that can operate on 12 volts or 120 with the flip of a switch.
Look at the data panel for the 15,000 BTU AC. It's current rating should be right around 12 Amps at 120VAC. Which is 1440 Watts. Startup is when there could be a problem. Especially when the compressor approaches a near lockup condition. Current draw can be double that of normal operation Even though it is within the surge rating of the inverter- the batteries have to be at their peak at all times.
Nov 06, 2011 | Xantrex Technology Trace Series Inverter /...
WILL A TRACE 2012 INVERTER RUN A 15000 BTU RV AIR CONDITIONER
According to specs, they will take a 44 amp AC power surge. Obviously number and type of batteries as well as battery condition , etc, plugged in, not plugged in to outside hydro, or generator all come in to play here, but a 15,000 BTU roof AC will only draw, 15-17Amps AC when compressor kicking in, ( or less on some new models) and should level out at 12 -13 amp draw after. As well, this will depend on proper wiring to and from main panel as well as AC unit, and incoming voltage, AC unit condition ( cleaned and maintained properly) etc.
VCT Electronics Simran Ac-2000 Step Up Down Voltage Converter Transformer 110v 220v Logo
57 people viewed this question
Top VCT Electronics Electronics - Others Experts
Are you a VCT Electronics Electronics - Other Expert? Answer questions, earn points and help others
