Display quit working on Onkyo TX-SV50PRO
Appears to be a power problem
  • 21 Answers
SOURCE: Subtitle Problem: Onkyo TX-sr605
The only remote that will definitely turn the sat subtitles on/off is the sat remote. The other subtitle buttons on the other remotes refer to the DVD subtitles and the subtitles generated by the tuner in the tv. The subtitle option is greyed out on the tv because you are not on the tv tuner.
Posted on Sep 03, 2007
SOURCE: Onkyo Tx-v940 Receiver/Amplifier Protection Mode
Audio amplifier IC's damaged you need to change it.Good luck
Posted on Jun 11, 2008
lynchms
  • 93 Answers
SOURCE: Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Posted on Jan 28, 2009
SOURCE: Onkyo AV Receiver TX-SR 805 no display on the receiver
Finally one of us found the solution - thanks to cambrian
Please follow the link
http://www.avsforum.com/avs-vb/showthread.php?t=857502&page=579
BTW: My knowledge of electronics is very limited, but nevertheless I could fix the problem. I hope you can do it too.
Posted on Mar 12, 2009
mjjdesigns
  • 98 Answers
SOURCE: Onkyo TX-SV 727 PROTECT mode
Generally, this happens when there's a loose connection somewhere, either internally, or with the connections. It usually happens when the volume's too loud, and it tries to protect itself.
I'd suggest you unplug everything from it, check all the speaker wires, and then try turning it on, without any devices connected to it.
If it works, turn it off, and reconnect devices, one by one. That should fix it.
If not, it's likely that there's a loose solder inside, and it needs to be sent out for service.
Posted on Mar 19, 2009
Onkyo tx-ds656 stand by power light comes on volume control knob rotates to max but display or unit wont start
Try factory reset: while holding the(CD) button on front panel,press (POWER) button.
After "Clear" is displayed the unit should be back to its factory default. :) If this dont work for you take the unit to be checked by service . :)
Jan 24, 2014 | Onkyo TX-DS656 Receiver
Onkyo TX-SR606 power on default input setting and hissing sound
I had the same problem for more than a year but just lived with it. The solution is to reset the receiver to factory defaults. Page 96 of the owners manual, "turn the unit on and while holding down the VCR/DVR button, press the ON/STANDBY button. CLEAT will appear on the display and the unit will turn off". Problem solved!
Sep 21, 2009 | Onkyo TX-SR606 Receiver
Onkyo tx-sv828thx
Audio amplifier IC damaged need to be replaced
Aug 30, 2009 | Onkyo TX-SV828THX Receiver
Onkyo tx-sr500; power goes out; standby light blinks
Remove all Wires form speakers
Power on
Push Video1 + StandBy /On
appears Clear on display
Dec 22, 2008 | Onkyo TX-SR501 Receiver
Display on receiver no longer visible
from display power by ac voltage 5.6vac pins 1and2 and 65and66 should be from power transformer there is no fuse for this display light
Nov 10, 2008 | Onkyo TX-DS595 Receiver
Onkyo TX-SV414Pro Display Language
Onkyo.com
has the owners manual in full.
Mar 17, 2008 | Onkyo TX-SV414Pro Receiver
Front buttons won't work
The microprocessor may be locked up. While pressing and holding "video 1", press "speaker A". When "clear" appears in the display, the micro has been reset to the factory default condition. To do a full reset without taking it apart, it may have to sit up to 3 weeks for the backup battery to run down.
Dec 21, 2007 | Onkyo TX-DS474 Receiver
Brand new Onkyo Tx-sr605 won't leave stand by
If the unit will not leave standby I would remove all power, disconnect *all* connections at the back, reconnect to a power source and try powering on. This will eliminate any connection causing the Onkyo to stay in standby due to a short. If it still will not enter power-on mode, you may want to look at the power source (is it properly grounded?), but beyond that the unit probably needs to go back.
Nov 03, 2007 | Onkyo TX-SR605 Receiver
Dec 31, 2006 | Onkyo TX-V940 Receiver
18 people viewed this question
 Grubhead
Grubhead
