Question about Nautilus Nautillus, Trimline, Schwinn Motor Controll Board Part Qq2245 Treadmill
Error message I have a Trim line 7150. It has been a good treadmill. It now shows an "Error" in the message window. Any ideas
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: need user manual for trimline 7150 treadmill
plelase go to www.fitness.manualsonline.com or www.iconservice.com
God bless you
Posted on Sep 01, 2012
Gradient error
Assuming the treadmill doesn't work with these errors, I would look towards your lower board being the issue. Call tech support, they are helpful and will help you diagnose.
Mar 03, 2016 | Exercise & Fitness
Error message 02A0 stays up on the and the treadmill will not start
hi,
Here i have added the list of error codes list for t5x .
Check the same and confirm which error its shows. error 02A0 is not listed any where.
ERROR
Aug 20, 2013 | Matrix Commercial Treadmill: Mx-t5x
Suspect upper panel faultr,shows En9 in r/hand[speed]window at start up
DescriptionError 09 checks lower PCA memory locations during the power up test sequence. If a fault isfound during the power up test sequence, error 09 will be displayed. This error code is only usedon products utilizing the dual microprocessor system.Possible Causes1. This error message almost always indicates a lower PCA problem when it is consistentlydisplayed. Failures causing this error message to be displayed are rare.Possible Remedies1. If the error message is consistently displayed when the unit is powered up, the lower PCAshould be replaced. It is possible to see this error message displayed intermittently due toexternal causes. If the units A.C. input significantly dips during the power up test sequencethe test could fail resulting in this message being displayed. Treadmills operating onnon-dedicated A.C. circuits may see this message displayed on an intermittent basis.God bless you
Apr 03, 2013 | Avanti Fitness AT380 Treadmill
I have an everlast treadmill Jx-269e showing error e09. Any idea what to do about that please?
DescriptionError 09 checks lower PCA memory locations during the power up test sequence. If a fault isfound during the power up test sequence, error 09 will be displayed. This error code is only usedon products utilizing the dual microprocessor system.Possible Causes1. This error message almost always indicates a lower PCA problem when it is consistentlydisplayed. Failures causing this error message to be displayed are rare.Possible Remedies1. If the error message is consistently displayed when the unit is powered up, the lower PCAshould be replaced. It is possible to see this error message displayed intermittently due toexternal causes. If the units A.C. input significantly dips during the power up test sequencethe test could fail resulting in this message being displayed. Treadmills operating onnon-dedicated A.C. circuits may see this message displayed on an intermittent basis.God bless you65723e8e-6bcc-4a02-900e-e9fa117bb428.gif
Apr 03, 2013 | Exercise & Fitness
How do you get into the service menu of a precor 932i treadmill?
Typically on the Precor Treadmills if there are errors on the unit, you can press and hold the stop button for 3-5 seconds and it will go into the error log. Not sure what model you have.
E-2 is not what normally shows up on the screen. Do you mean Error 2 was displayed? From what I have read on Error 2's it could be a upper PCA issue, or possibly a dip in AC input during the power up sequence.
Treadmills require a dedicated line, meaning it is on its own dedicated circuit on your fuse panel/circuit breaker.
What exactly is the treadmill doing? Is it constantly showing Error 2 on the screen? Call up Precor tech support. They will be able to give you advice, and or get you connected with an authorized Precor factory trained technician who will be able to get you back up and running.
Nov 07, 2012 | Precor 932i Treadmill
Error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Feb 17, 2010 | Life Fitness T3 Treadmill with Advanced...
Nautilus Nautillus, Trimline, Schwinn Motor Controll Board Part Qq2245 Treadmill Logo
21 people viewed this question
Top Nautilus Exercise & Fitness Experts
David Payne
David Payne
ray gallant
Techmotionusa.com
Techmotionusa.com
Are you a Nautilus Exercise and Fitnes Expert? Answer questions, earn points and help others
