Question about Mitsubishi CS-40505 TV
Mitsubishi replacement tube - Mitsubishi CS-40505 TV
Mitsubishi montero 2003 leaking anifreeze in the rear
There is a set of two steel pipes that carry coolant/antifreeze to the rear mounted heater core for heater operation. These steel pipes/tubes rust out, and you end up with a coolant leak. Mitsubishi has superceded the steel tubes with aluminum tube set. Not an easy job to replace the two pipes since they are routed over and around a few items under the vehicle before attaching to the heater core at the r/r of the vehicle.
May 04, 2012 | Mitsubishi Cars & Trucks
I have a 65" Mitsubishi
Im, not sure what it is that you are wanting to know about this Model# WS65411,But this TV has 3 Tubes Red,Green,Blue their is No Bulbs Just 3 Picture Tubes.
Encompass Parts Distribution List Parts and PN# for this Model 1-800-638-3328
Visit this website for Part Numbers for R/G/B Tubes.
Apr 12, 2011 | Mitsubishi WS-65411 65" Rear Projection...
I have a mitsubishi 45"
This tv have no colors wheel or projection lamp.Tv only have 3 CRTS tubes like R,G,B CRTS tubes guns.Problems of the tv?Will help u diagnose and replaced parts or telling should be repair by a tv Tech.
Mar 16, 2011 | Mitsubishi VS-45609 TV
Blurry mitsubishi projection VS 5041
there a one or more defective tube needs to be replaced is typical efect when is tube end of life.
Jan 02, 2010 | Televison & Video
I purchased a Mitsubishi HD new in 2001 All pictures are now blue and green The red silicone cooling jell tube is no longer lit up. It looks like you can take the tubes out. Please advise if this is...
THE TUBE IS REPLACEABLE, HOWEVER YOU MUST VERIFY IT IS BAD FIRST. THERE ARE 3 OTHER PROBLEMS THAT YOU NEED TO ELIMINATE FIRST BEFORE YOU SPEND $250.00 ON A NEW TUBE.
Dec 07, 2009 | Mitsubishi VS-55707 TV
Replacement of the green lamp(picture tube) in a Mitsubishi 55'' rear projection HD TV. Lamp is out. Other two (red & blue lamps are fine.) How to remove lamp/picture tube? Price and availibilty of...
You can probably purchase a smilar set on Craig's list for $300.00, at least that's what they go for in the Austin Texas area.
A new tube may be too expensive and difficult to replace.
Sep 13, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Replaced all air conditioner parts and still blows cool air NOT COLD. Guy that just replaced evaporator said it could be a sensor that needed to be reset by mitsubishi. Is this true????? this is a 2001...
no dealer has a reset for the a/c system by you mentioning that you replace everything it means the a/c compressor,air dryer,and the most important the orfice tube. if you hadnt replace the orfice tube wich converts the liquid into gas when it gets hot thats your problem.alot of mechanics wont change it as an a/c mechanic will.
Jun 22, 2009 | 2001 Mitsubishi Eclipse
Mitsubishi VS-60705 red lamp replacement
The part you are describing is actually the red picture tube, not a lamp. The tube will come dry and you will need to disassemble the lens assembly on the old tube, drain the coolant (antifreeze), reassemble the parts and seal on the new picture tube, fill with fresh coolant, install the new tube, reconnect all wires including the dangerous high voltage lead, then realign the yoke and entire convergence circuits. This is not something that should be attempted by anyone without experience. If you try it yourself and the seal is not working perfectly, the coolant will drip down on your main boards and the set will be ruined. If you slip while lowering the new tube in the chassis there is a good chance you will crack the tube's neck, and that tube will be useless too.
Jul 30, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Televison & Video Logo
12 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
