Question about Panasonic CS-PS24MKH Econavi Inverter Standard Air Conditioner FOR 220 VOLTS
Need to know how to pull apart indoor unit to clean
Can not blowing as hard as it should. Compressor kicking on but freezing up easily. Any ideas?
Check your filters and make sure that there is adequate airflow, also make sure that any drain tubes are not plugged.
Jul 03, 2015 | Heating & Cooling
We have a fujitsuAST30RGA-W airconditioner, it is leaking into the room. can a new indoor unit be purchased, does anyone know? the unit works well, apart from dribbling all over the place.
it has to be set on a tilt in order to drain out the rear if it's condensating really bad it may need a freon charge you should take it out and wash it real good
Feb 26, 2015 | Heating & Cooling
Why is there a ***** smell?
I worked extensively on GE Zoneline AZ Air Conditioners and Heat Pumps while a Maintenance Superintendent at a Senior Citizen's Apartment Complex. Not knowing what type of smell to which you are referring, I can assure you that other than "burnt electrical" smells, the only smell that could possibly be produced would be that from within the INDOOR SPACE. Perhaps something has made its way into the INDOOR AIR FILTER? Perhaps that INDOOR AIR FILTER needs to be cleaned. To clean the INDOOR AIR FILTER, simply lift both of the filters from the front cover, take to your clean bath tub. Run EXTREMELY HOT WATER from the back of the filter to the front of the filter. Then, fill your bathtub 1/4 way with EXTREMELY HOT WATER. Add 1 cup of Hydrogen Peroxide and 1 cup of Real Lemon Juice. Set both filters in this solution for 30 minutes; then rinse with clear water. Set filters up to dry for at least 2 hours in the sun or an air breeze. Replace filters into the GE Zoneline.
Also, not knowing how OLD your GE Zoneline system is, the COILS may need to be cleaned. To do this, simply turn OFF your GE Zoneline unit and remove the front COVER of the unit. Next, mix in a spray bottle 4 packets of LEMON flavored KOOL-AID (without SUGAR) and water. Shake well. Spray the INDOOR COILS of your GE Zoneline unit with the entire contents of this mixture. Let set for at least 10 minutes. Then turn your GE Zoneline to the COOL position. The citric acid in the lemon kool-aid will be forced through the coils to continue to remove any dirt, dust, debris and effectively CLEAN those coils. This will also provide you a LEMONLY odor within your room. Simple and cheap.
Enjoy your GE Zoneline unit.
Aug 30, 2014 | GE Zoneline AZ55H07D Air Conditioner
Non return isolating valve dripping water tinuously
you have trash in the valve .shut it down take the valve apart clean it . also maintenance on this unit is needed.seal can be bad also. hope it helps.send pictures of the unit and age and model serial number.
Apr 06, 2014 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Need set up manual for The Weather Channel indoor outdoor thermometer model #WS-7034TWC-IT
The manual for the thermometer is available on the LaCrosse site: http://www.lacrossetechnology.com/7034twcit/index.php . The direct link is http://www.lacrossetechnology.com/7034twcit/manual.pdf .
Put the batteries in the remote(s) first. (If you need to reset the units, pull the batteries from the indoor temperature sensor and the remotes for 10 minutes before restarting.) With the remotes and indoor sensor 3 to 5 feet apart, put the batteries in the indoor temperature sensor. Then wait 10 minutes before pressing any buttons. Once you have confirmed communication between the units, then move the remotes to their final location (not more than 330 feet away minus 30 feet for external walls or windows and 20 feet for each internal wall between the units.)
I hope this helps.
Jul 08, 2011 | La Crosse Measuring Tools & Sensors
Do you add freon to your indoor unit or your outdoor unit? I have A new 2 ton first co unit indoors unsure what I have outside. Where does the freon go?
I would highly recommend that you get a friend or hire a pro, to deal with this. You dont just add freon, is it -R22 or the new 410A type? You always charge a system from the outdoor unit! If this is a new outdoor condensor, it will be pre charged for the unit, indoor coil and roughly 15 to 25 foot of line set. But after the brazing is done,,, NEVER SOLDERING! You need to use a Vac-Pump and pull the indoor coil and lineset down to 500 microns, before you open the king valves.
If this outdoor unit was used, then does i match the indoor coil? In sizing and type of refrigerant? Need to reclaim the existig refrigerant, pull a deep vacummn on the whole system and then weigh the charge in, according to the tag on the outdoor unit. You should have a CFC license t work with any type of refrigerant, if someone turned you in, it starts with a $ 10,000.00 fine for a start, You need allof the right type of tools and knowlege, save time and money,,,, get a CFC licensed tech,he will know all of this.
Sincerely,
Paul
May 18, 2010 | Heating & Cooling
My unit was'nt cooling the room like it use to and then this morning it was leaking water in the room
Hi, it sounds like the evaporator coil that is located on the inside as built up with ice, and has blocked most of the air flow. What can cause this is a very dirty filter, indoor coil that's iced up, and if the filter and coil are clean, make sure the indoor blower is up to speed. Turn it off and let it defrost. It will take some time. Turn it on fan only. If all is clean and motor is fine and it continues to ice, you are low on freon, and have a small leak causing it to ice up. It is probably a very small leak that may have taken a few years to leak to this point. I would make sure the filter is clean, coil indoors is clean, and blower is up to speed. If this is all good, you will need to get it charged. This unit holds less then 2 pounds of R-22.
Keep me posted on the out come. You can pull the indoor cover and see if you have ice on it. Let me know.
Shastalaker7
Apr 20, 2010 | Cfm Klimaire KSWG009H113 Split System Air...
On my indoor unit the fan just humms will not spin while energize
Did you change the capacitor on the fan motor. Could be bad if not bad fan motor. But sounds like a cap. Russ
Jul 19, 2009 | Heating & Cooling
I have a central air conditioning unit in the apartment where I live. It is a split unit - somewhere outside is my outdoor unit (and everybody elses too). Anyway I seem to get way too much humidity in my...
the humidity problem is from the condesation drain. It is more than likely to be clogged up keeping water in the condensation pan causing the humidity problem. This can be cured by a wet vac put onto the outside drain for the inside condensation pan and turned on. this removes the algae that builds up in the a/c condensation pans. Also, an a/c unit is designed to last 25 to 30 years depending on the location of the outside unit. Inside unit being an apartment, has other issues, it just may need to have some preventive maintenance done such as coil cleaned filter changed, motor oiled, etc....
Jul 08, 2009 | Carrier 38CKC030 Air Conditioner
How to Clean 1984 TRANE Cooling VENTS inside house No Manuals
The Outdoor unit will be easy 1st diconeect power at panel, or disconnect box near unit. Remove top of unit, be careful not to damage fan blades. Spray coils (fins) with a light degreaser let is soak for 5 mins. wash out coils from inside the unit out. Spray straight on so you push the dirt out the other side.
Re assemble and start up.
Indoor coil will be accessed by removing front cover and you may have another cover to expose the inside of the coil fins. That is where you need to clean. Spray degreaser on coils and rinse off. If its gunked up then use a wire brush 1st. Carefull not to bend the fins over.
Check the drain pan at bottom of the coil to be sure it's not full of stuff. Blow out if needed.
You should be clean and ready for the season
Jul 02, 2009 | Ruud Central System Air Conditioner
Panasonic CS-PS24MKH Econavi Inverter Standard Air Conditioner FOR 220 VOLTS Logo
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
