Question about Nespresso Citiz D110
Is white vinegar a good solution for desalinating my Nepresso
How do you get rid of scale in the coffee machine
  • nash
    nash May 23, 2017
    No! never use vinegar. buy the solution
    Dedicated:
    Visited the website for 20 consecutive days.
    Passionate:
    Visited the website for 10 consecutive days.
  • 18 Answers
Posted on May 23, 2017
Hi., What causes a white scale on a frangipani leaf and how do I get rid of it? Thanks
The white scale is mineral deposits from hard water, use white vinegar to clean/remove it, run the white vinegar full strength through the machine a couple of times. Do this on a regular basis to stop the scale from building up.
Dec 28, 2016 | Coffee Makers & Espresso Machines
De scale kruig coffe maker
Empty the reservoir of water and fill it with four (4) cups of white vinegar. Run the Keurig WITHOUT a K-Cup until the vinegar has been run through. Rinse out the reservoir with hot water, dry it, then fill with cold water normally used to make coffee. Run the maker 3 times, or until vinegar taste disappears.
Dec 25, 2011 | Keurig B60 Coffee Maker
Coffee maker is on. will not make coffee,will not take more water. just sits there like it is dead. descale light came on first. cannot descale because it will not take or give water. help olease.
I would first empty out any water that is in the machine, and get the grounds out. Then, the machine up with a 50/50 mixture of distilled water and white vinegar. You may need to let this sit in the machine overnight because the vinegar needs time to work it's magic. Then turn it on and run this mixture through, if the machine is descaled enough to run. If it doesn't, do it again. The key to descaling is the vinegar, but like I said, it needs time to dissolve the scale. If it works, then run a couple of pot's of just water to get rid of the vinegar smell. Give it a try!
Feb 13, 2011 | Keurig B100 Coffee Maker
My keurig coffee maker is flashing the words DE SCALE. What does that mean and how do I fix it?
"Scale" is deposits of minerals, etc. normally found in water. Boiling a container of water (in a pot, or coffee maker in this case), leaves small amounts or "deposits" of these minerals on and near the actual heat source. If not removed, they can slow brewing time and more importantly, adversely affect the taste of coffee.
Descaling should be done at regular intervals to prevent this from happening. Your machine lets you know when to perform the descaling task. There are a number of products sold in your supermarket that will do this for you - but one of the least expensive; and just as effective - is to use white vinegar. Here's how to do it:
1) Drain your Keurig coffee machine over a sink.
2) Fill the machine with undiluted white vinegar.
3) Run the brew process at least four times, pouring the cups of vinegar back into the coffee maker.
4) Optionally, let your Keurig coffee maker sit for a few hours, then run the brew cycles again. Pour the vinegar into the sink and drain any remaining vinegar.
5) Fill your coffee maker with fresh water. Run multiple brew cycles with fresh water each time to thoroughly rinse the machine before returning to normal use.
That's it!
I know this will help & good luck. Please rate my reply - thanks!
Feb 06, 2011 | Keurig Ultra B50 1-Cup Coffee Maker
When k cup is placed in machine no coffee comes out, with out k cup water comes out
sfd
Sorry to read about your issue.
also clean the holes at the bottom of the k cup holder
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 24, 2010 | Keurig Platinum B70 Coffee Maker
Lacks pressure when making coffee
Dec 23, 2010 | Keurig B30 Mini Coffee Maker
THE MACHINE ONLY BREW 1/2 OF THE LIQUID.THE WINDOW READS/BREWING/BUT THE LIQUID STOPS.I GOT TO SHUT THE MACHINE OFF,THEN ON,TO GET ANOTHER 1/2 CUP,BUT SOMETIMES DOES WORK AT ALL.
Dec 19, 2010 | Keurig Platinum B70 Coffee Maker
Miele descaling funnel?
DO NOT USE THAT MUCH VINEGAR! Put a tiny bit of vinegar in the carafe and fill carafe the rest of the way with water. Run that vinegar/water through machine. Using another container, fill machine with plain water and run that through. Repeat until the vinegar taste is gone. If you do not run lots of plain water through the machine after, your coffee will taste like...um...disgusting! Also, use a spell-checker before improving this posting.
To clean hard water deposits from a coffee maker use distilled white vinegar. You may need to use as much as a gallon if the scale buildup is really bad. Fill clean coffee pot one half full of vinegar and run through machine as if making coffee. Repeat this process several times using fresh vinegar until it comes out clear. Do this once a week and your maker will work much better. **************
Use citric acid or LEMON JUICE CONCENTRATE instead of vinegar. It cleans just as well but doesn't leave the funky odor that vinegar does. You can run enough water to get rid of the vinegar taste, but the odor will linger for days or weeks. Much better to use lemon juice concentrate (no pulp!!) or one of the commercial products like the one available from Starbucks.
Sep 15, 2009 | Miele Coffee System
Err 2-repeatedly unplugged, turned on/off, pressed all buttons. NOTHING>
Suggestion was Descaling the Coffee Maker from KitchenAid Phoebe (I'm guessing customer support)
http://kitchenaidconversations.com/forums/topic.asp?TOPIC_ID=14441&SearchTerms=err+2
Cleaning scale from coffee maker DO NOT USE THAT MUCH VINEGAR!Put a tiny bit of vinegar in the carafe and fill carafe the rest of theway with water. Run that vinegar/water through machine. Using anothercontainer, fill machine with plain water and run that through. Repeatuntil the vinegar taste is gone. If you do not run lots of plain waterthrough the machine after, your coffee will tastelike...um...disgusting!
To clean hard water deposits from acoffeemaker use distilled white vinegar. You may need to use as much asa gallon if the scale buildup is really bad. Fill clean coffee potone half full of vinegar and run through machine as if makingcoffee. Repeat this process several times using fresh vinegar until itcomes out clear. Do this once a week and your maker will work muchbetter.
May 30, 2008 | KitchenAid KCM511 Coffee Maker
Keurig Special Edition B60
I assume your coffe maker used to produce more coffee for each use. Roughly 6 ounces per large cup, and now is only making 3 oz. cups.
If your coffee maker is sputtering and not able to "suck" enough water to fill your cups of coffee it is most likely due to cavitation caused in the little pump due to a stoppage, which is most likely lime or scale buildup somewhere in the pump line.
To fix it, don't take your coffee maker apart. Get a bottle of distilled white vinegar, and pour it straight into the empty water resevoir. Press brew with no coffee pod so you are just running the vinegar through the system. Pour the vinegar out of the cup and back into the resevoir. Add some ice to cool it off. Repeat about 10 times. This should clear out the toughest lime scale clog.
After you notice the cups are filling full of water, Replace the vinegar with fresh water. Run about 5 or 6 cups of fresh water through the system to get rid of the vinegar.
Make coffee/tea/whatever.
Jade
Oct 06, 2007 | Keurig Special Edition B60 Coffee Maker
Nespresso Citiz D110 Logo
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
