Question about Dishwashers
Fisher paykel dw681es
I have a fisher&paykel dw681es dishwasher it will fill up after 10secs the reset button flashes
4 Suggested Answers
  • 784 Answers
SOURCE: Fisher & Paykel double dishwasher bottom
F2 is indicating a fault for the motor. This motor has 2 directional operations. One direction of rotating for spraying water for washing. The other for draining at the end of washing cycle. I don't think it is a problem with the motor, but there is some food clogging up its rotation path causing this issue. Need to take out the bottom stainless steel exposing the motor to clean up. I do this some times. Just need to pay attention to remove and put things back properly. Now if you are not comfortable in doing it, then call F&P serviceman. Don't call any handyman, since without knowledge about this dishwasher a person can do more harm than good and you know who will take care of the bill. Good luck.
Posted on Dec 29, 2009
rylee_smith
  • 8619 Answers
SOURCE: Hello I have a Fisher &
Hi
Thanks for using FixYa. If the cycle doesn't complete, then the first thing that should be checked is the Timer and then the heating element. Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 01, 2010
adamg1996
SOURCE: How to reset the flood switch on a fisher & paykel
Well I have a Fisher & Paykel Nautilus single door Dishwasher about 10 years old or more. All of a sudden we started getting F1 error and what sounded like a pump trying to pump out water. I read these posts the poured water in bottom of dishwasher and it sucked the water out, but pump kept running. I took the metal filter out from inside base of machine and cleaned it ...was dirty. oops... then tilted machine and water drained out of somewhere in the bottom of machine....put everything back and its now working perfectly. Thanks for all those that gave me the guidance..YOU ROCK!
Posted on Jul 04, 2012
Fisher & Paykel dishwasher top drawer is filling up with water when bottom drawer is ran.
It is the drain water from bottom drawer that is finding its way to the top drawer. This could be due to incorrect drain hose height. Check in installation manual. Alternatively you will have to buy an air gap kit and connect the two drain hoses separately to the kitchen sink.
http://www.genuineapplianceparts.net/ecart/item.php?item_id=250&category_id=58
Mar 22, 2014 | Fisher and Paykel Dishwashers
Fisher and paykel nautilus dishwasher
Does it fill with water? I would guess a fill/ drain/ heating problem. See if you can eliminate any of those.
Apr 12, 2013 | Fisher and Paykel Dishwashers
F4 message on the top drawer, fisher paykel. I clean the filters and arm every week or two.
There 2 possibilities with this error:
1)
  • Fault with water fill (only on machines with level-controlled fill)
  • Note: Lights blinking, pump running and controls dead indicates an over fill fault
2)--4 Flashes--Draining failure. Drain pump, control board OWI or water indicator defect
God bless you
May 14, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a nautilus dishwasher by fisher and pykel can't find any user guides Flashing F1 and has drained ...do these dishwashers have a reset button?
This video explains how to repair a double and single drawer fisher and paykel dishwasher.
http://www.appliancerepairlesson.com
Jul 11, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher paykel dishwasher DD603 drawer is open but locked
i think you have to press the key/ lock button until the symbol disappears. You will find the exact button for your model in your owners manual.
Nov 25, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
Fisher and paykel DD605SS
I can talk you through finding the fault on live chat. cheers
Mar 15, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher & Paykel DD603 Service manual
i need a parts manual for a fisher & paykel dw681es wh
Nov 10, 2008 | Fisher and Paykel 23 in. DD603H SS...
Dishwashers Logo
21 people viewed this question
Top Dishwashers Experts
Owen Barnes
