Question about Kyocera Mita Office Equipment & Supplies
Kyocera mita 1530 reset - Kyocera Mita Office Equipment & Supplies
4 Suggested Answers
SOURCE: I need to reset ID Code on Kyocera Mita KM-5530
The solution is easy! Push the Default Setting/Counter button on the top right side of the keyboard. Press the the Managment icon on the diplay. Enter 6-4-8-2 on the keyboard and select the Managment icon in the OFF position. Close all windows on the display and you should be ready to go.
Posted on Jun 18, 2009
n25an
  • 622 Answers
SOURCE: Kyocera mita maintenance light is on and lines
check the rectangular **** glas and table for any white out or particles... clean thoroughly... make copies... clean again... make copies... if same issue... then replace drum... but in most cases its the optics... which I advised you to clean thats causing the issue... if the issue occurs when you print an internal report then its definitely drum... if reports are clear... there is something on the glass... or on the part above it... even a little bit of black toner or ink or whiteout anywhere out there can cause a line
Posted on Dec 23, 2009
  • 70 Answers
SOURCE: Possible solution for kyocera mita km-1530 c610 error?
This is temperature error code. For causes and solutions see this: C6100, How to reset
Posted on Feb 16, 2012
Call for Service ...... C710
Hi there
I have found various documents which may help you with this problem and possible future problems. This page:
Error Codes Kyocera Mita KM1530 Code C710
can find any code connected with Kyocera mita machines by changing the machine and the error code in the appropriate drop down menus. C710 is identified as:
Description Toner sensor problem
• The sensor output voltage is outside the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run. Causes Defective toner sensor. Poor contact of the toner sensor connector terminals. Developer problem.
Another page showing error codes and their meanings is here;
Kyocera Mita Error Code Messages
and this confirms the above.
Also the link below takes you to a Kyocera web page where you can download various manuals for this machine (KM-1530). By changing the product in the drop down menu to KN-2030 you can get similar manuals for this machine.
Download Center
In your question you mention "Compatible KP23153 Black Toner Cartridge 106153" and that led me to wonder if the compatible cartridge is the cause of your C710 error since that is toner related.
Might be worth trying an original cartridge to see if the error goes away.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 24, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
How do I clean spilled toner from the inside of a Kyocera mita copier?
Try using a small soft brush to brush it off while using a good hepa filter vacuum to remove the toner at the same time. Wear a good breathing mask to protect your lungs!
Aug 06, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
I have a Kyocera Mita KM 1530. User maintenance, the lights are now lit. Now I know I need to replace the drum, but someone can tell me later if you need to reset some or mute only the drum and is already...
press in sequence 10871087...
Go to U251 using cursor keys.
Check and clear PM count(copies since from last PM and PM reset).Press start to display six digit PM cycle. Select "Clear" w/ cursor up/down to clear count back to ..
Go back to U001 and press Start key to exit.
Sep 16, 2013 | Kyocera Mita Km 1530 2030 Copystar Cs 1530...
Km 1530 displaying ap on screen
Please click here to download the technical guide and user manual.
http://www.kyoceramita.eu/index/service/dlc.false.driver.KM1530._.EN.html#
Sep 06, 2012 | Kyocera Mita Office Equipment & Supplies
Feb 16, 2012 | Office Equipment & Supplies
Dear sir i need to service manual for mita km-1530 with regards oskooie
pls go on this site
www.azmanual.com/manual/.../kyocera-mita-km-1530-manual
Dec 12, 2010 | Kyocera Mita Office Equipment & Supplies
I have a KM 1530 THE MONITOR IS DISPLAYING AN ERROR CODE WHCH IS C 610 PLEASE LET ME KNOW IF YOU CAN HELP
Hello sir; Try to do a reset, the procedure is ; enter 10871087then up/down or the zoom , press start , press execute to clear, press start
Feb 05, 2010 | Kyocera Mita Office Equipment & Supplies
43 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
