Question about Toys
Robosapien II model # ww252 I need to remove the outer covering too expose the inside wireing . How do I do that?
aborcass
  • 2651 Answers
SOURCE: i need to take outer cover off dryer to lubricate pulley
if indeed you have an amana NDE2300, hter eshould be 2 5/16 screws across the lower bottom panel, after removing them 2 more screws will release the next bulkhead, and more screwws will become evident as you remove them
Posted on Jan 20, 2009
  • 228 Answers
SOURCE: Connection
the screws used are tamper proof torx 20 any hardware shop can supply you they are often included with electric drills etc as well remove all back panel screws this will give you access to cooling fans and all elements remove top for access to stata and neons etc.
hope this helps
Posted on Jul 20, 2009
  • 3600 Answers
SOURCE: need to remove fender trim to get to wheel well to
There are several screws inside the fender well that have to be removed and one in the pinch molding of the car that has to be removed the ones near the engine are snap in plugs and can be removed if you use a flat tip screw driver to remove the plastic push in locks. Remove them to get to the antenna.
Posted on Sep 05, 2009
bammbammfran
  • 159 Answers
SOURCE: Need to remove the outer cover on a Gateway
If you get power to the controls and you don’t have the startup sound or see the gateway logo when you plug it in, the main board may be bad.
If your picture was pinkish or dark at the top or bottom when it was working then you may have 1 or more of the bulbs failing.
If you have the startup sound and see the gateway logo and the screen just flashes and the power buttons stay lit, then it sounds like probably the inverter may have went.
Take the screws out of the bottom rear edge (these hold the front trim), and the 4 big black ones at the middle of the back that hold the stand bracket.
The trim then unsnaps. {Be aware of the small ribbon to the power button board on the right edge}Start at the bottom and release the trim (pulling up the trim on the screen side usually starts it off), then work your way up each side bottom to top ((a pocket knife or thin putty knife even a credit card, will help release the catches as you work your way up)
Then unsnap the top edge (rocking it while lifting helps)
Disconnect the ribbon at the power button board, (Tiny latch lifts up on a hinge and ribbon slides out)
Once trim is off, remove the 4 corner screws that hold the screen in. Then the screen will lift out with all the guts. You may have to pry up on a corner with a screw driver to get it started.
The inverter is under the medium size metal case.
The power board and main board are under the large cover.
You’ll then have to remove a bunch of screws including the usb board ones and unplug the bulbs and wire to the screen
then the power board and control board is under the center area under the metal cover
Shout if you need more info.
If you email me a good picture of the board , I may be able to get a better idea if it is the inverter from a visual.
Thanks Fran
Posted on Mar 07, 2010
  • 4102 Answers
SOURCE: How do I change the stop light bulb ?
hi you remove the lights from the inside of the car you need to remove the carpeted panel that covers the back of the lights in the boot/trunk and then you should see the bolts that hold the tail light unit in place once you have undone these and unplugged the wire connector you should then be able to pull the light unit out and then this gives you access to the bulbs.
let me know if you have any problems ok
Posted on May 23, 2010
How replace light bulb in model 3211rfd
Most likely the outer cover will have to be removed but be aware that dangerous, even lethal, voltages are exposed with cover removed.
Jan 09, 2018 | In Microwave Ovens
How do you replace the ovenlight in an Hinari Lifestyle Microwave Oven MX745GLSL?
Most microwave ovens require removal of the outer cover to access the light but be aware that you will expose yourself to potentially lethal voltages, even with power disconnected.
Sep 19, 2016 | In Microwave Ovens
Model 1880LS. How do I replace the fuse?
You will have to remove the outer cover. You should be aware that doing so exposes you to potentially lethal voltages, even with power disconnected.
Dec 24, 2015 | Sharp Microwave Ovens
Model r-9h55. Where is lamp located and how do I replace it?
The lamp is located inside the oven. It is accessed for replacement by removing the outer cover. Be aware that potentially lethal voltages are exposed, even with power disconnected.
Nov 26, 2015 | Sharp Microwave Ovens
How do I change the lamp in my Kenwood Simplicity microwave?
The lamp is accessed by removing the outer cover of the microwave oven. Hazardous voltages are exposed by removing the cover. Remove the lamp and install the replacement.
Feb 15, 2015 | Kenwood Microwave Ovens
How do I replace cord jack on a Peavey bass guitar?
You'll need needle nose pliers, small phillips head screwdriver, soldering iron, electronics-grade solder, socket screwdriver or 1/4" wrench, black electrical tape. Purchase necessary replacement jack. Remove plastic electronics cover plate, located on the back of the body, behind control knobs. This will expose the electronics cavity. Locate existing jack and its wire connections inside the exposed cavity. Remove any electrical tape covering the jack connections. Using a hot soldering iron, touch each of the two soldered input jack connections, one at a time, just until the soldered connection melts. Then, disconnect the associated wires (taking note of which wire connects where!). Once disconnected, loosen and remove the nut on the outer part of the jack that holds it onto the guitar body. Remove the old jack. Insert the new jack (with the nut removed) into the existing hole, from inside the electronics cavity and tighten it in place, on the outside of the guitar body, with the nut. Re-attach the wires to the new jack, by using needle nose pliers to wrap them tightly around the correct posts. Touch the hot soldering iron to each post and apply a small amount of solder to the post as it's being heated. Once the molten solder runs over the connection and looks shiny, remove the tip of the soldering gun. This process takes only 2 to 3 seconds. Let the connections cool for a few seconds. To insulate, wrap connections with black electrical tape. Replace cover plate.
Apr 27, 2014 | Peavey Music
The puppy chewed the cord of our chi. Can I find a replacement cord and repair it myself?
Depending on where your tear is, you can follow just a few steps to help you out. If your tear is a couple inches from either end (like in the middle or close to it) all you need to do is cut out the part that is torn. Once that is done, carefully cut some of the outer plastic back (so that it reveals the actual wires on the inside). Make sure you take that step slow, as to not cut all the way through, just cut through the outer layer. After that, twist the metal wires on the inside together, then cover the exposed metal wires with electrical tape (be generous with the tape so you don't shock yourself in the future. Wrap around 3 to 4+ times)
Tools: Electrical tape Scissors
Hope this helps! :] Good luck!
May 24, 2011 | Health & Beauty
I am Trying to Service a Vienna Saeco Coffee machine. I have removed the top covers and am trying to access the wiring under the heater and other parts for which I need to remove the chassis from the body....
-2 Phillips screws on the front (left and right under the fascia)
-1 torx in the back of the machine, under the water tank
-Hot water/steam knob that has to be removed: There is a clip that can be pressed with a tiny screwdriver (with the front door opened) which will let you pull the knob out.
Once this is all removed, you need to push with a screwdriver in a small whole from under the machine, beside the power cord. Pushing hard from one hand and pulling the whole thing up with the other should do it.
Jan 12, 2011 | Saeco Vienna SuperAutomatica Coffee...
How do I change the stop light bulb ? The outer cover has no exposed fasteners.
May 23, 2010 | 2005 Chevrolet Equinox
How do you strip insulation form uf electrical wire
I use a sharp knife and slice off the outer covering on each side of the cable. With practice you can "feel" the outer insulation of the conductor and make the knife slide along it without damage. At that point I simply pull the two conductors out of the covering and use my wire stripper to expose the bare ground wire. When stripping the ground, I use a oversized hole on the wire stripper to keep from scoring the wire.
2 conductor is easier to strip than 3 conductor.
here's another
I've never tried tearing it apart. That sounds like it would be hard on the conductors to me.
steve
Dec 13, 2009 | Hardware & Accessories
Toys Logo
32 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
