Question about Maytag MAH9700AWM Neptune Front Load Washer
P2 message in my philco 18l dehumidifier
My 18l philco dehumidifier shows a P2 message and has stopped functioning. Please help.
I just sent u an email about my danby showing a P2 sorry it was a P1.
P1- means the dehumidifier is in a defrost mode. This occurs when the temperature on the evaporator gets too cold and the unit shuts down to defrost (a defrost cycle).
P2- means the internal bucket is full of water.
Hope this helps!
Jan 25, 2014 | Danby Humidifiers
The unit is showing "full
Two things generally cause this problem. If your unit has a Float Valve inside the bucket, it's stuck in the 'Up' position, which under normal conditions, indicates to the unit, that the bucket is FULL. If you don't have that, then when the bucket was last inserted into the bucket holder, it did not trip the bucket removal safety switch. Remove the bucket and reinstall it, making sure that it fits squarely into the hole from top to bottom. Leave the unit ON when you do this, because if you do it correctly, the unit will automatically start and run. Also, be sure that humidity extraction level is set on 32 - 35 %.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 13, 2011 | Comfort-Aire BHD-651 Dehumidifier
I have an asko T760 Butterfly dryer. It is stuck on P2 but will not run. I shut off the unit, turned back on. The LCD flashes between P1-P4 and what they are, such as extra dry, dry, normal dry, & iron...
Hi.
The machine is telling you that there is overfill, f2 and 4 are faults with overfill system. Lights blinking, pump running and controls dead also indicate an over fill fault :
"1. Disconnect the power to the unit
2. Remove the lower access panels and check the tray under the dishwasher (you will probably find it is full of water)
3. Use a towel or a sponge to remove the water
4. There is a float that should stop the operation of the dishwasher and run the pump if water is in this tray. Check this pump to see if it is functional
5. Test the dishwasher
6. If there are no leaks from the dishwasher into the pan, check the drain hose under the sink
7. THE DRAIN HOSE MUST RUN UP TO THE TOP OF THE UNDERSIDE OF THE COUNTERTOP THEN DOWN TO THE DRAIN. (If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray"
Here all diagrams.
Regards.
Ginko.
Apr 26, 2011 | Asko T761 Electric Dryer
Hello, my dehumidifier has a problem, it functions but it does not withdraw water in the tank, it functions without stop and moisture do not go down? it does not have there water in the tank. how to cure...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Oct 10, 2010 | LG LHD45EL Dehumidifier
Can you tell me about the "P" readouts?
Here is a tip that I wrote to help people with just that dehumidifier2_bing.gif problem..
Dehumidifier Problem It shows Bucket Full
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
May 02, 2010 | Danby DDR601 Dehumidifier
Hobart AM15T ML-130039 with p2 message, what does this code mean
p2 would mean your rinse thermistor is open or shorted. its located on top near the the right side, after the vac. brkr. part# is 328994. remove old, istall new . dont forget to vote,hope this helps , monomoy
Jan 29, 2010 | Hobart 29 in. AM15-1 Free-Standing...
Polar wind dehumidifier: p1 or p2 code after emptying tank.
P1 error indicates that:
  1. The water tank on the side of the unit is full.
  2. The water tank in not properly seated in the housing.
  3. The switch at the back of the water tank housing is not engaged or is loose
Jul 24, 2009 | Kenmore 54501 Dehumidifier
P1 and P2 error codes
Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
The Service Rep. described the following code for my dehumidifier model (DDR657EE):
P1 = Defrosting: the unit will go into Defrost mode periodically to ensure that the parts are working at the right operating temperature. It should be in Defrost (P1) mode for only a brief period of time. If the unit is in Defrost (P1) mode continuously for a couple of hours (or more), then you should call Danby Service for further assistance.
He had no documentation of a P2 code for my model.
He also described other General Codes (applicable to most Dehumidifier/Humidifier models):
E1 = Not enough water
E2 = Not draining
E3 = Water temperature too cool
E4 = Overflow Switch activated
E6 / E7 = Problem with Temperature Sensor
I hope that helps.
May 25, 2008 | Danby DDR2506 Dehumidifier
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
