Connection from TV to stereo system for audio
4 Suggested Answers
SOURCE: problem hooking tv to stereo
lwsmith91 you need to make sure that there is only one audio output on your stereo. if more than one try plugging it in to both outputs. also make sure that you do not hear any sound when you plug it in or its the wrong one. on the back of your tv make sure you dont have them plugged in to an HD input or output for that matter
Posted on Feb 28, 2008
jsinex2421
  • 62 Answers
SOURCE: CONNECTING MY TV TO MY STEREO
Make sure the output in your tv menu is set to external speakers. Any digital optical cable, or RCA jacks hooked up properly from the TV's out put to the receivers input should work just fine. Take your time, retrace your steps, and make sure each cable is in the correct input/output. And make sure the receiver and TV are on the proper settings. Good Luck, and thanks for using FixYa!
Posted on Jan 13, 2009
  • 83 Answers
SOURCE: AM/FM Stereo Hookup problems
Make sure your audio outputs are turned on.Also try a connection from the tv straight to the stereo to see if you have sound !! If so then the problem is somewhere in between!! Check the settings for audio on these devices as well !! Good Luck !!1 Swampratt200 AAAAAAAAAAAAAAEEEEEEEEEE!!!!
Posted on Jul 21, 2009
How do i connect my stereo system's speakers to my televison
audio out tv to stereo audio in or aux
tv out (rca or headphone jack)
to
audio in on stereo or aux in
May 28, 2016 | home Audio Players & Recorders
How do I hook up my 55 inch led tv to a stereo for better sound
In many cases newer tv's do not have an audio out, some have a headphone jack on the side (Small usually blue)
Otherwise if you are wanting to get better sound from a DVD / Blueray / Satellite / Cable box, You can put the audio from these devices into your sound system, then plug your sound systems audio out into the tv.
The video out from your devices will need to connect directly into the tv.
If using HDMI or S-Video that carries both audio and video, slitter / separation boxes are available, but usually degrade sound and audio quality.
The above would look something like
Cable box audio out (red / white) to Stereo audio IN. >> Stereo Audio OUT to TV audio in.
Yellow (Video) Cable from cable box then goes directly to the TV Video IN. Just make sure the audio and video cables are going to the same section (Some tv's may have multiple audio / video in's
Nov 17, 2014 | Haier LE55B1381 55 Class LED HDTV - 1080p,...
I want to connect my XL-DK255 to my TV (Sanyo DP26671). Please help!!!!
http://www.manualowl.com/m/Sanyo/DP26671/Manual/211922
the only way to connect them is audio ...and you can either connect the Tv to the system ..(for better sound ) ..and in this case use the rca (left /right ) to rca (left right ) on the sharp ..if it supports..or ..use a double rca stereo cable ..with a jack 3.5 end ..and insert it in the audio input of teh sharp system ..
The signal from the Tv it will have to be taken from the audio out like in th epage 13 of the manual ..(it has a mono exit ..on rca probably ) and a left and right stereo one ..
If the sharp supports rca stereo in ...use it ..or ...just use the jack (3,5 stereo ) in ...and do not forget to select the proper channel ..
if the sharp system has a TV input channel for sound..on the receiver..use it ..and select the TV to playback the sound ..if it do not ..use the aux.. and selct the aux for control it ..
I do not believe you need to connect it in the other way cause it is not make any sense ..but the procedure is the same ..get audio signal from the system and insert into the audio in of the TV ..it is in the same place and also available mono and stereo ..You will have to select the input in the tv menu..
The cable you need for a stereo connection I think will look like thi s..
http://www.alibaba.com/product-gs/369945799/Factory_direct_supply_Adapter_Cable_jack.html
Jul 20, 2011 | Sharp XL-DK225 Shelf System
I have a 50"tv , It has stereo audio out (L/R
If the labels say Audio Out with RCA jacks, then you don't connect speakers to those. You must connect those to a audio amplifier ( home stereo system )
If you have speaker clip jacks like on the rear of a stereo system, then just connect them as you would any other.
Nov 24, 2010 | Sanyo DP50747 50 in. Plasma TV
I connected my Sony stereo system to the philips
Make sure you turn the tv audio outputs on, use the menu on the tv to do this. Make sure you connect the audio out of the tv to the audio in on the stereo system.
May 01, 2010 | Televison & Video
Installed new 1080 plasma tv can't get sound from home theater system
A home theater system usually consists of a dolby digital stereo amplifier and 5 to 7 speakers.
Turn your stereo on and select the source that delivers video to the TV (DVD, VHS, Game, etc.). The video may be connected directly from the device to the TV, but the audio should connect to the stereo system (DVD, VHS, or other input). This way, the source audio is sent to the stereo and it provides the big sound to match the picture. Otherwise, you'd have to connect the source audio to the TV and let it's comparably tiny amplifier and speakers provide sound - that comes up short.
When playing a DVD, select the DVD input on the TV *and* the DVD input on the stereo. If you do not connect the audio to the DVD input on the stereo system, you'll have to connect to the TV, otherwise nothing will be heard.
Sep 17, 2009 | Audio Players & Recorders
Connect to TV
Check the user manual for the TV to make sure that the TV has the option to allow an external audio system to be connected. If applicable, then check that any necessary mode setting have been done in the TV set to allow an external audio system. Make sure that you are using compatible connectors between the TV and the sound system. Also, the sound system has to be compatible to the TV.
Jerry G.
Apr 26, 2009 | JVC FS-SD1000 CD Shelf System
TV Sound through stereo speakers while watching tv.
All the above connected method is correct. Need to change the option in the stereo system as md or auillary depends upon the model. Go through user manual for stereo system.
May 27, 2008 | Sony KV-35S42 35" TV
Nov 03, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
