Question about Sony Handycam HDR-UX5 DVD Camcorder
Hdr-ux5 screen black but touch function still works
Replaced mother board and still has black screen but the touch screen features work.have have to open lcd,then close then look in view finder, touch ,then close and repeat.
CrazyLarry
  • 173 Answers
SOURCE: distorted picture when looking through view finder or lcd screen
the video playback is sampled off the video out and independently processed sorta like a TV signal to project on the lcd screen.
horizontal lines means you lost sync circuit and needs troubleshooting. Hopefully maybe a bad connection with a ribbon cable for the ICs and components are hard to change and jammed tight. I would order a video board.
Posted on May 14, 2008
SOURCE: Hi, My SOny Hc42 camera LCD gone blank, I can see
problem seems to be in most cases a flexible 'cable' between the recorder and the LCD screen...
Posted on Jun 12, 2009
aneesh ch
  • 73 Answers
SOURCE: My Sony Hc42 camera LCD, view finder gone blank
cheak ur lcd srip and there is a samll switch that chaing over switch cheak it
Posted on Jul 09, 2009
SOURCE: Black LCD and out of focus
My LCD screen has also malfunctioned - some-one else has also posted a similar problem and has been told its to do with a carbon cable connecting the LCD screen to the camera that needs replacing.
Not sure about the viewfinder problem - is there a control to adjust the focus, or is that what you mean by the viewfinder lever?
Go to http://www.sony.co.uk/article/id/1218032872969 to register with sony for repairs.
Posted on Aug 11, 2009
welcomejee
  • 10594 Answers
SOURCE: LCD on Sony HDR HC1 not working
This happens when flexible wire between LCD board and camcorder board got broken or cracked.
Camcorder needs that connecting flexible wire replacement, let me know exact model of Sony camcorder if you need part number of flexible wire.
Thanks.
Posted on Sep 22, 2009
Bernina 180E Touch Screen Dark, machine light won't come on.
I don't know the circuit of this sewing machine but it gives me the impression the light and the board are in series with a fuse. If this is true the light will burn out and cause the screen to go black as well. If the fuse would go out the same thing would be true. Anyway, change the light first. If this doesn't work you will need to replace the fuse. If there are still problems it will need the mother board to be replaced. Tell me how this worked out.
Oct 24, 2014 | Bernina Artista 180
HDR-SR12 - LCD Touch screen very dim , screen works but almost completely dark. tried increased brightness etc no help
My camera's backlight went dark. Occasionally it would work if I pressed just the right way, but it was basically toast.
Search ebay for an HDR-SR11 or HDR-SR12 flex cable similar to this one:
http://r.ebay.com/L4dWDQ
It's not impossible to replace, but it's definitely not for the faint of heart. Some offer a replacement service with it. I'm doing mine myself. Results to follow, maybe, if I remember to post following the repair.
Jul 15, 2011 | Sony HDR-SR12 HDD Camcorder
The touch screen display does not work. It turns on but you cannot give the unit a command through the input panel.
Is the lcd screen completely blank? Or does is it just the touch functionality that is not working?
If the screen is blank, though the copier still turns on and appears to function (test it by printing to it,) then you most likely have a failed power inverter board. This board provides the current needed to operate the lcd screen and is a rather common failure. However, if it is just the touch feature that is not working though the screen lights up, then you most likely have a ripped ribbon cable that connects the lcd touch function to the main board on the lcd screen.
Keep my updated.
David R.
Dec 11, 2010 | Xerox WorkCentre M-24 Color Copier
The Touch screen on my Sony HDR-SR12 stopped working. Is there a diy fix? screen now shows as it should but does not respond to touch
A flexible board (seems like a strip in pale yellow color) worn out and it needs replacement.
The detail of part is given below:
187480611 PWB, FP-807 FLEXIBLE
This part number needs replacement.
Thanks
Mar 02, 2010 | Sony HDR-SR12 HDD Camcorder
Thanks.
Sep 22, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
Sony HC7 flip out screen video rolls and no or limited touch scre
You can purchase a new LCD Flex cable for a Sony HDR-HC3 (Same as HDR HC7) from e-bay for 27 US$.
You can also download free service manual from internet that explains simple repair.
Sep 17, 2009 | Sony Handycam HDR-HC7 Mini DV Digital...
Sony HDR-HC3 LCD touchscreen blacked-out.
Hi, I have the same Problem with my HC3. This July the screen started to go funny and then now only works once its fully opend and flipped against the body. the touch screen did not work, As I had tapes to be transfered I needed to get the camera in to play mode and access the menu. I had no choice but to gentnly removed the LCD cover and tightend the connections and the touch screen now started to work. As I move the creen forward the image goes off and once? Looks like its a common problem as I see many having thesame issue. I feel it could be a loose connection inside but cant open and loose whats left working as it is still usable without the screen.
Thanks
BUD
Jun 09, 2009 | Sony Handycam HDR-HC3 HDV Digital...
Says disc is dirty or scratched ...it's not
Eject the DVD disc and push Optical Lens inward-outward for 2-3 times carefully. Please dont touch lens surface. Lens should reach completely at both ends.
Hope problem will be solved.
Jun 01, 2008 | Sony Handycam HDR-UX5 DVD Camcorder
Sony Handycam HDR-UX5 DVD Camcorder Logo
26 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
