Question about Dometic 57915531 Air Conditioner
Need shrouds for model 57915531 - Dometic 57915531 Air Conditioner
  • Dometic Master
  • 6,674 Answers
Any rv dealer either stocks them or can get them for you
Posted on Mar 16, 2014
Need a replacement r v air conditioner shroud polaris by dometic 28inches wide 41 7/8 inches long & 9 1/2 inches high
Can you get model number of bottom of upper unit, from inside the trailer? The roof unit model number will make it easier to find replacement shroud.
Sep 27, 2012 | Dometic Rooftop RV Air Conditioner
I need to replace a broken shroud on a Duo-Therm Brisk Air Model # 59715.531 Where can I purchase a matching shroud?
americanrvcompany.com Once on the site go to air conditioners on left hand side then Dometic A/C. They should have what your looking for.
Jul 05, 2011 | Dometic 57915531 Air Conditioner
My dometic ac model 57915.531 suddenly developed
The 20 amp will be sufficient, you'll just need an adapter to match to your plug.
Jul 31, 2010 | Dometic 57915531 Air Conditioner
Have a Duo Therm 59516.531 15000 BTU blower motor does not run checked cap 5mf ok tried direct power still nothing any thought. thanks
if you tried direct power and still nothing then your fan needs to be replaced . there should be a a/c supply store near you . get the model - serial number on the fan or the unit itself to get the right fan for your unit . hope that helped
Jul 01, 2010 | Dometic 57915531 Air Conditioner
Dometic 57915.531 - high fan does not work
If it is a wall mounted thermostat, then you need to check the control box mounted on the inside of the unit. Remove the inner shroud to access. Check for power on the blue wire entering the control box from the thermostat, this is the high fan circuit. There should also be power on the orange(or tan) wire from the tstat. This is the fan circuit. Both these need to be hot with 12VDC for the fan to run on high. If you have power there, try removing the cover from the inside and access the squirrel cage (fan blade) inside the unit, turn the tstat to High fan and try starting the fan motor by hand. If it starts, then you have a bad fan capacitor. If not, check power to the fan on the top unit and all wiring leading to the fan. If you have power to the fan and it still does not run, you need a new fan motor.
Hope this helps,
Jeff
Jun 08, 2009 | Dometic 57915531 Air Conditioner
How much current (amps) required for duothermo air conditioner?
Most nameplates disclose the max circuit ampacity or knowing the watt rating divided by the voltage gives you amps
Jan 20, 2009 | Dometic 57915531 Air Conditioner
What size generator, watts, doe's it take to start AC unit 57915.531 ?
a 10000 due to the startup surge. also need start kits on any ac started by a generator.
Oct 08, 2008 | Dometic 57915531 Air Conditioner
Dometic ac
remove the lower assembly and tighten the bolts that hold ac down to coach or pull shroud and check to make sure unit is not frezing up due to dirt
Jul 13, 2008 | Dometic 57915531 Air Conditioner
Dometic 57915531 Air Conditioner Logo
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
