Question about HP Compaq Business Desktop dx7400 - Core 2 Duo E6550 2.33GHz
Dx7400 bios update - HP Compaq Business Desktop dx7400 - Core 2 Duo E6550 2.33GHz
How can recovery Hp bios when it has crashed
Mugisha,
This could be a memory probably but very unlikely depending on the timing of your restart. If you restarted in the middle of running the BIOS update then the problem is very likely that you have the BIOS in a non-recoverable state. There are lots of warnings that say don't restart the computer and unlike 99.9% of software, this one can break your hardware. Your BIOS the part of your motherboard that sees all of the connected hardware and if it isn't working then nothing is going to work ever. The good thing is that motherboards aren't that expensive for desktops. Also your HD is still readable so you will be able to get your data off it if you need to.
If you didn't restart early and did it when the installer said it was OK to then it could actually be an issue with RAM. Bad memory can/will cause your computer to not POST which is that screen you first get when powering up your computer, behind the HP splash screen. A quick easy way to test if you have bad RAM is to swap it out. Unplug your computer and open it up. Hopefully on the motherboard you will see multiple sticks of RAM. You can google search SD or DDR RAM to get an idea of what you are looking for. Next take one of the sticks out then plug the computer back in and power it up. See if it works and if it doesn't do the same thing with the other stick. If you only have 1 stick then you can't test this because you need at least one plugged in for your computer to work.
If that doesn't work then you might have a dead motherboard from a bad BIOS update. Running BIOS updates always make me nervous because if anything goes wrong your motherboard is dead in the water.
You can bring it to a computer repair shop to see if they can get it working again. Like the issue with the RAM there are other pieces of hardware that could be bad but people don't normally have the hardware laying around to swap out. Also they can take your hard drive out to backup the files needed if you do have a bad motherboard.
Oct 21, 2012 | HP Compaq Business Desktop dx7400 - Core 2...
Network driver for windows 2003 server
Need driver and bios updates?
Always get your drivers and specific software from the manufacturer of your Laptop, Notebook or Desktop. They are usually free of charge.
If you were to log on to the manufacturer's web site, usually one is able to download if available, by model number, All available Driver downloads as required.
If the driver is not available, perhaps your manufacturer does not support the OS you are installing.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
I hope this helps.
Mar 01, 2011 | HP Compaq Business Desktop dx7400 - Core 2...
Have epson stylus dx7400 without cd. Want to
I have an Epson stylus DX7400 for some reason when I installed the printer language is in German. My disc is broken therefore I am unable to reinstall. What can I do?
Sep 21, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Im face the some problem in hp dx7400 pc.i have
You can install Windows XP professional's network driver for windows server 2003.
To download the desire driver CLICK HERE
Thanks
Feb 24, 2009 | HP Compaq Business Desktop dx7400 - Core 2...
Changing inks
Visit this page and download the manual for your printer: www.techfuels.com/printer/11727-epson-stylus-dx7400-all-one-inkjet-colour-printer.html - 53k -
Jan 23, 2009 | HP Compaq Business Desktop dx7400 - Core 2...
Epson DX7400 only printing Blue + Black
I'm sorry you have received no response on this , it's probably because you have posted it in the C86 printer group rather than the DX7400 group. I presume you have now solved this problem. If not, please re-open it (in the DX7400 group) for help.
Dec 15, 2008 | Epson Stylus C86 InkJet Printer
Hi. I need to download a drivers for win2003, which i had installed OS, for this below system. hp compaq dx7400 small form factor .
Win2003, is a OS, and you get update for that OS on Microsofts homepage.
HP Compaq dx7400 sff is a computer with hardware you can find drivers for to Vista and XP, - here:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3459275&lang=en&cc=us&prodTypeId=12454&prodSeriesId=3459271&taskId=135
was this helpful, then dont forget to vote
/Teis
Dec 10, 2008 | Computers & Internet
Epson stylus dx7400
Apart from the fact this DX7400 problem is mis-filed under Epson Stylus C86, it seems probable the poster has sorted it by now!
Aug 21, 2008 | Epson Stylus C86 InkJet Printer
HP Compaq Business Desktop dx7400 - Core 2 Duo E6550 2.33GHz  Logo
123 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
