Question about Refrigerators
Viking Fridge (DDSF136DSS02) - Ice Dispensing Problem! HELP!
We have an issue with our Viking fridge (DDSF136DSS02) not dispensing ice. It makes ice not problem but when we try to dispense ice...nothing comes out. It appears to me that there may be ice in the gears/motor which could be causing this problem. Reason being is because when we totally defrosted the freezer, the motor for the ice dispenser turns. I did this as a preliminary troubleshooting step. When I plugged it back in and the freezer was at freezing temperature, the motor would no longer turn. Have any of you seen this issue before? Thank You
  • 184 Answers
SOURCE: Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Posted on Apr 10, 2008
  • 111 Answers
SOURCE: GE GSS25LGM Ice maker not dispensing ice
You have one of three things wrong. The auger motor is frozen up, the ice bucket is broken or you need to dump out any ice, run warm water through the entire ice bucket, dry it out and try again with fresh cubes. My guess is the auger motor is frozen. You can buy a vinyl boot that covers the auger motor to prevent moisture buildup and freezing from GE Parts at 1-800-626-2002
Posted on Dec 16, 2008
tborn6
  • 700 Answers
SOURCE: My whirlpool fridge, ice makerMy Whirlpool is not making ice. It has an in door ice dispensing system. It stopped making ice yesterday - what could be wrong?
lift the bar up to shut the maker offf and then turn it bakck on and wait.
Posted on May 27, 2009
woodchuck789
  • 4070 Answers
SOURCE: LG fridge freezer GR-L207QVJA.
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Posted on Jul 01, 2009
  • 10865 Answers
SOURCE: 25 ft side by side fridge which does not dispense ice
use a hair blow dryer to warm up the chute and dry up any moisture then lube the chute with a cooking spray, pam is a good one.
Posted on Aug 16, 2009
Daewoo frsu20dci fridge freezer, hiya, hope you can help. Our fridge freezer is making ice and dispensing ice but no water is coming out of the water dispenser when pressed. Help!!!
Check your water filter. They are known for clogging up. If that doesn't work...check your water inlet valve.. if that doesn't work check to see if you have a pinch in your waterline.
Jun 25, 2015 | Daewoo Refrigerators
LG fridge LFX25991st Ice dispenser panel keeps getting stuck
Of course it's under warranty. Call back & kick up a storm. Every singe item on that fridge is under total warranty.
Nov 20, 2013 | Refrigerators
Not make ice, not cold? please help? is this a problem with thermostat
i am not a expert just trying to help,,try cleaning the bottom of fridge of dust cause dust can cause the fridge to heat up,, make sure to clean all under the fridge pull out and take plate off to clean ,, hope this help you
Oct 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Not making ice or dispensing water
Does your fridge have a inline water filter or one inside the fridge? If so, try replacing the wate filter, as it could be obstructed and old and causing the loss of water flow.
It's a good idea to keep track of the date when any filter is installed so you can replace it before it losses it ability to filter properly, both from a issue of conveinence and for health reasons.
A dirty, old filter can allow some nasty contaminants to pass through after a fixed amount of time or set amount of water has passed through it.
If there is no filter, you might have to replace the water inlet valve that supplys water to the fridge. Just be sure to turn of the water line the fridge is connected to, before servicing the water supply valve that supplies the fridge.
Hope that helps, Best regards!
Jul 30, 2009 | Frigidaire Refrigerators
My GE side by side fridge/freezer is working, water dispensing ok, but not making ice. I switch off the fridge, than ice maker but still not making ice. I try all the hints from Manual but no luck. Water...
fill the ice maker with water manually, if you have ice in the bucket you know that the ice maker is working , after check the water valve if is opening , if it is replace main board
Jun 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser will only dispense crushed ice
Ihave zannusi ZX99/5SI fridge freezer. Top-freezer compartment is not cooling. I have done as before, defrosted and cleaned both fridge and freezer but, with no luck. Freezer is working OK but top-fridge  is not cooling. Could you please help with advice in what to de next.
Thank you
GAZ
May 12, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Will not dispense ice
i have changed filter and it still is not making or dispensing ice what could be the problem
Mar 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
