Question about L.L.Bean Measuring Tools & Sensors
Need manual for l l bean 0GJU5 weather station
0GJU5 weather station unit is a bit complicated and I need a manual to help figure out how to work it.
2 Suggested Answers
SOURCE: I need instructions for L.L.Bean Weather Station model BAR186A
The manual is available from Oregon Scientific at this site:
http://www2.oregonscientific.com/ulimages/manuals2/BAR186A.pdf
Posted on Jun 22, 2013
I need the instructions for a KOKODA Oceanic Tide & Sky Weather station
It doesn't seem to be available. It may be a badged unit made by another company and badged 'Kokoda'.
Try this company with the model number as they seem to be the brand leaders.
Product Manuals - ClimeMET
https://www.climemet.com/pages/product-manualsLooking for a copy of the user manual for a ClimeMET product? Simply choose your weather station or weather dial from the list below and click to open.
KOKODA Oceanic Tide Sky Weather station manual Google Search
Nov 07, 2017 | Sky Measuring Tools & Sensors
Nexx Tech professional Atomic Weather station Model#8001231 Outdoor unit reads -15.8 C but it's +17 C .Batteries are NEW Tried resetting BOTH units, no luck.HELP There's a difference of at least 30 C.
You should checked if the unit has a offset for the reading of the temperature.Also, could be that the temperature sensors are way apart from the main unit, this could cause attenuation of the signal. You can check the user manual here:
http://downloads.thesource.ca/800/8001231/Manuals/manual.pdf
Jul 27, 2017 | ATOMIC Measuring Tools & Sensors
I have a new weathr station and can not get the outside temp. to display what can I do?
I assume it is a wireless station. If so, there is a procedure to go through to get the temperature sender and the base station to sync up and work. You need to check your owners manual to get the exact procedure for your unit. On my station, I have to remove the battery from the base station, let it power up and within 5 minutes, install the battery in the remote station(s) (temperature, rain gauge, wind gauge, etc.). Also, you must keep the remote station within a certain range for the base to get a good signal. Probably 25 feet, but the owners manual will have the right number. Also, use new batteries.
Aug 02, 2016 | Oregon Scientific WMR86 - Backyard Pro...
Will not transmit outdoor info. Batteries good- LED lights. Monitor shows indoor temp only.
There are a couple of possibilities for the failure to transmit/receive outdoor data. First, resynch the two units. This will depend on the manufacturer. For some brands, you need to take the batteries out of both the indoor and outdoor units for 10 minutes. Then put the batteries into the devices with both side by side (working inside is easier). Wait until the outdoor data is displayed. There are some weather station systems where the outdoor unit isn't weather-proof. You may need to dry the outdoor unit for several days after removing the batteries before resynching it to indoor sensor.
If the data displays properly when the outdoor unit is inside, you may have the outdoor sensor too far away from the indoor unit. (The distance will depend on the number of walls and the composition of the wall studs/siding.) Try keeping the two units closer together.
If the outdoor data isn't displayed when the two units are side by side and the reset procedure doesn't work. One device has an internal malfunction (transmitter or receiver failed). It's probably best to replace the unit. If it is under warranty, contact the manufacturer.
I hope this helps. For specific details on resetting the indoor and outdoor units to synch them, please add a comment with the make/model of your weather station.
(I've seen Davis Weather stations damaged by a close lightning strike. The outdoor unit had to be replaced.)
May 23, 2015 | Measuring Tools & Sensors
I have a wweather station model no. CE0681The outdoor control no longer tranmits infromation on tempereture to the inside weather station. How do I solve this problem?
There are a couple of reasons that this can happen. First try replacing the batteries in the outdoor control. Also replace the batteries in the base (inside unit).
You may also need to resynch the two units. (For some models, this requires bringing the outdoor unit inside and removing the batteries. Then add the batteries and let the base station look for the outdoor unit.) With the Davis instruments weather station with the solar powered unit, clean the solar panel. You may need to replace the rechargeable battery.
Sometimes, lightning strikes near the weather station external unit causes a surge that damages the unit. In that case, the entire board may need to be replaced to fix the problem.
Please add a comment with the manufacturer for additional information.
I hope this helps.
Mar 18, 2013 | Measuring Tools & Sensors
Feb 18, 2013 | Measuring Tools & Sensors
Weather station won't work
i have the same problem and have had 2 of these now. outside unit blinks like it is transmitting but nothing on base. SYNC per manual does not fix it.
Jan 29, 2013 | Brookstone Wireless Weather Forecaster
Cannot get the weather station model ws-916ou-it to show outside temperature
I have three of these WS-916OU-IT units. After a few years, the outside sensor just fails. You will get dashes and a "TR" low battery signal, even if the batteries are good
just buy another whole weather station (short money) and set both the old and new weather station unit to receive from the single new outdoor sensor.
To do this - just follow the procedure for a single sensor - that is - put the batteries in the new sensor - then within 30 seconds - put the batteries in all the weather stations - they will all pick up the same outdoor sensor.
I now have three units running off of one outdoor sensor.
Seems a bit silly, but it works.
Feb 27, 2012 | Measuring Tools & Sensors
Outside temperature not showing on ll bean model # 9021u-it
Try removing the batteries from both the outdoor sensor and the indoor unit. I had the same problem and fixed it by doing this.
Sep 28, 2010 | Taylor 1528 Wireless Digital Indoor...
Measuring Tools & Sensors Logo
216 people viewed this question
Top L.L.Bean Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a L.L.Bean Measuring Tool and Sensor Expert? Answer questions, earn points and help others
