Question about ViewSonic Computers & Internet
Speaker static speaker noise
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 149 Answers
Separate wiring so there is no cross-talk of signals. If speakers fail, buy new set <$20.00 (walmart), and hook up, then you have great sound.
Posted on Jun 22, 2014
How to fix speaker in Sylvania projection clock radio SA 85018 2
if it is too loud it will make static and make a weird noise in the speaker my arlarm clock(very old) does that but when i turn it down it stops the static and the noise.
May 03, 2016 | Sylvania Audio Players & Recorders
Dm605 s2 speakers have static noise
If the noise you hear comes from the tweeter or the midrange speakers, it means your amplifier is noisy; if the noise comes from the woofer, then the internal amplifier (it has its own) of the speaker is noisy. If both speakers are noisy, it is most probable that the "static noise" you hear comes from the external amplifier, which you will have to check or change.
Feb 12, 2014 | B&W DM605 S2 Speaker
When I turned on the power for my 'Logitech X-240' speakers, there was a loud static noise coming from the speakers. I unplugged the speakers from the subwoofer, and as I began to plug them back...
clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Aug 31, 2011 | Logitech X-240 Computer Speakers
I have been experiencing static noise/crackling from my front left and right speakers just recently. (I have a 5.1 dell system - the front center - attached to the monitor and rear speakers do not emit...
This seems like at cables have gone bad or either the connections in the speakers went bad. Its best to replace them unless you know how to disassemble and re-soder the connections.
Mar 01, 2011 | Dell WL6000 Computer Speakers
Static only in one speaker
When you say static that they both work but one is noisy or are you saying that the only one is making a noise and nocoherent sounds coming from either
Aug 03, 2009 | Genius SP-F350 Computer Speakers
Insignia PC speakers - give a weird static feedback noise
I'm going to vote for the haunted option.
Sound like you have some noise on your power lines. This can be caused from many different things. Normaly it is a motor going bad or a compressor starting up. From the AC unit or refrigerator.
See if you can correspond the noise to anything else happening in the house. Fridge starting up, AC or heat cycling on...etc.
It may be that you just have speakers and a cordless phone going bad at the same time.
It might just be Casper the friendly ghost playing tricks... ha!
Jan 23, 2009 | Insignia 2.0 Speaker System (2-Piece)
Static noise coming from interior rear by speakers
CHECK REAR AMPLIFIER (INSIDE TRUNK) BAD CAPACITOR OR BAD CONNECTION. REPAIRED MINE TODAY.
COST $30.00-
Jan 08, 2009 | 2003 Jaguar S-Type
Static noise coming out of speakers
What sort of computer do you have? Is it a laptop or desktop? Many laptops have this problem and it is quite widespread in laptops. The crackling or humming noise could be a result of interference from the mains power signal.
If it's a laptop, try running it on battery alone (take out the mains power cord). My laptop has this kind of noise in speakers when running on mains electrical supply, but it goes away like magic when I run it on battery.
A more long-term solution is to buy a 'Ground Loop Isolator' and insert it between your computer and the speakers/earphones. They are quite cheap and you could get it for under £10. It removes all static noise and you'll hear crystal clear sound.
Jan 01, 2009 | Dell A215 Computer Speakers
Static noise
Check for the Third earth wire of your computer else check for the motherboard taking earth for the cabinet.
Good luck
Oct 09, 2007 | Dell WL6000 Computer Speakers
Static/White Noise
Scroll down to the speaker set option. activate it then push the > button. You will see the test below the speaker diagram.
Feb 08, 2007 | Zenith XBS344 System
Computers & Internet Logo
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
