Question about Sylvania 6842PE 42 in. HD-Ready Plasma Television
Sanyo dp50740 turns on, with still picture and no sound. then powers off then back on again repeating it's self
Where is reset button on sanyo 50 inch tv model DP50740 The TV will not stay on
There is no reset button on televisions. I see that is a plasma set, if you are just losing the picture that is one thing, if the whole set is shutting down, that is another. Please advise
Feb 02, 2016 | Sanyo Televison & Video
I have a Sanyo DP50740. Had about 2 years. All of a sudden it started shutting off after turning on. Will not turn on again until unplugging and plugging back in. Then it shuts off again right away. Could...
Main board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 17, 2014 | Sanyo DP50740ARB 50 Plasma HD TV 720p...
It clicks on then clicks off
It sounds that the TV switches ON, and switches OFF, after three relay clicks. It is likely to the fault to its main board. Contact any service technician. This is not a user repairable fault.
google.com/+GopakumarGopalan
Nov 05, 2013 | Sanyo DP50747 50 in. Plasma TV
Dp50740 power led goes on and off
What you have is most likely a failed main board. These sets are known for this problem. There are several different variations of the main boards. Make sure you order one that matches yours. The main board part # will start with J4@#. The main board part # should be on a sticker either on the main board itself or on the coax input terminal casing. I hope you got the TV for a good price !!!
Sep 01, 2012 | Sanyo Televison & Video
Sanyo dp50740 will not come on after power surge is there a reset?
Connect TV to a different power outlet and try. Switch off TV manually, remove plug from power outlet after switching off power, and retry after 48 hours. If problem persists, it might need attention by a qualified service technician.
Jul 22, 2012 | Sanyo Televison & Video
Sanyo dp50740 wont come on after power surge
Change power outlet and see. If problem persists, it might need attention by a qualified service technician.
We were just watching tv and it just shut off. Now it won't turn back on. I already unplugged it and still nothing except for the green light will come on for a second then turn right back off. You can...
Now tv on,power LED light indication flashes?Yes.The power supply board is the problems and the causes.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Mar 24, 2011 | Televison & Video
Sylvania 6842PE 42 in. HD-Ready Plasma Television Logo
18 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
