Question about HP ProBook 4540s Notebook PC ENERGY STAR
Hp probook 4540s shuts down at start up and fan runs at high speed
It starts up for 5 seconds and then shut down by itself all the while the fan is running at full blast. pc isn't hot. What now?
5 Suggested Answers
  • 78 Answers
SOURCE: HP Pavilion dv6000...startup and shut down...over and over !
there is two screws under the touch bad but they don't look like a screw i don't no the name of it in english but they are somthing that the srew goes into it you must remove them and every thing will be easy to open and replace the motherboard
Posted on Oct 25, 2009
ginko
  • 19396 Answers
SOURCE: hp paviolon dv2000 shuts down by itself
Hi.
If computer turns off when idle, then check power saving settings, accessible from control panel.
If laptop turns off while you are using it, try first reinstalling the system to exclude system problems, or test the laptop starting OS from CD or staying in Bios settings mode, so to exclude installed system.
If laptop is still shutting down, then problem may be overheating.
Overheating usually happens when the fan is not coming , therefore when the computer overheats.Or the fan is not cooling enough and computer is overheating.
Monitor computer temperature using a software, check if Fan is coming up when temperature gets critical.
If fan comes up but does not cool enough, then replace the fan, it is not efficient anymore because of a bad bearing or dust. ~Also ensure that fan is well mounted, if fan has poor contact with CPU surface , cooling will be poor.
If fan does not come up, and critical temp is not detected, then the sensor on motherboard is bad, this is very uncommon. When this happens the problem is usually related to system or power settiings , rather than overheating.
If fan does not come up and temp is critical, then fan is faulty, replace it.
There are also more than one fan on many laptops, check that one of the fans (CPU fan, video fan) is not completely ded, and therefore cause for the problem.
By using the software below you can also find out if the problem is really overheating. If temperature results within normal range, then usually it is not overheating.In that case test systtem and check power saving settings.
Here is the software to control your fan and temp. sensor state:
Download SpeedFan - Access temperature sensor in your computer
Download SpeedFan 4.38
SpeedFan - Free software download
  • 3 Answers
SOURCE: HP nc8000 shuts down after 10 seconds
try pushing on the upper right corner of your laptop, above the home key, does it start up again?
If so its the maxim chip
if not take one so dimm out and dissable wireless.
Could also be your battery not charging because a battery or power cord malfunction.
Posted on Jan 11, 2010
SOURCE: why windows xp won't shut down in hp probook 4510s
Just delete webcamera software or use default driver for it
И будет тебе счастье
Posted on Mar 25, 2010
Sudden shut down
Usually the notebooks shut down when increase the temperature of cpu. For thst reason we must open and clean the heating sink and apply new thermal paste on cpu and graphics card gpu chip every 2 with 3 years.
Jan 11, 2014 | HP B5P37UTABA probook 4540s notebook pc...
HP probook 4540s plugged in not charging
Simply unplug the power from the adapter, leave for some minutes then reconnect.
Dec 23, 2013 | HP ProBook 4540s Notebook PC ENERGY STAR
HP M370n System fan failure will shut down in 5 seconds,
Return to the person that replaced the fan. Obviously it's not fixed.
Feb 20, 2013 | HP Pavilion Computers & Internet
Blue Screen Error
What were you doing ,just prior to the shut down? Take a look at this:http://pcsupport.about.com/od/fixtheproblem/ht/stoperrors.htm
Dec 07, 2012 | HP ProBook 4540s Notebook PC ENERGY STAR
A/C starts up/Cools/Fan Slows, Unit Shuts down in 4 minutes
Ensure proper voltage to the unit. Check for overheated/damaged wires and/or connections in the control panel as well as at the fan motor and compressor.
Apr 03, 2010 | Dometic Rooftop RV Air Conditioner
Starts and runs 3-5 seconds and shuts down
Sounds like your security system is shutting the car down. You should be able to leave the key on for 15 minutes and it will reset itself. Make sure you are using factory keys, and they are in good condition.
May 28, 2009 | 2002 Pontiac Grand Prix
Turns itself off & gets hot -don't think fan is kicking on
Since you do not hear the fan anymore I would start by opening up the case and seeing if power is going to the fan and make sure any connectors for it have not come loose. If the connectors are still hooked up chances are the fan is shot and needs to be replaced.
If you are not familiar with working around electronics and parts under power I would highly suggest you have some one who is familiar with this do it.
May 06, 2009 | Computers & Internet
RE HP Pavillion ZE4800 Laptop When I switch on I here the fan start, the lights come on then it appears to shut down and re attempt to start again This occurs over and over and the PC never boots fully....
I have same notebook and similiar problem. Mine runs for 30 min then shuts off completely in like 20 seconds. I added a $10 usb powered laptop cooler pad and bingo, runs now for hours no problem. On all computers I know the cpu heat temperature has a threshold, if it goes too high it will shut off. I think my fan doesn't kick on fast enough to lower the temperature and cool the processor. On yours it may be a fan that doesn't work or is working at the wrong time and the circuit shuts off the system. Shouldn't be terribly expensive maybe $60 to repair from a good technician..good luck
Aug 15, 2008 | HP Computers & Internet
HP ProBook 4540s Notebook PC ENERGY STAR Logo
74 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
