Question about Zhone (6218-I2-200) Router
I am trying to port forward a new game, but am having problems
Looking at router settings page, but NAT is nonexistent
2 Suggested Answers
SOURCE: NAT? Where?!
I do not think you are logged in as the admin. If you are only logged in as a user then the NAT will not even show up in your menu. Try logging in with admin - admin or admin - cciadmin or possibly some other modified version customized by your isp.
Posted on Jun 05, 2008
How do I get two xbox 360s to have an open NAT on a Cisco Linksys WRT160N V2 wireless router?
you need to setup both your xboxes with a static IP address for example
192.168.1.50 xbox 1 192.168.1.51 xbox 2
on your linksys router you will need to setup port forwards for both xboxes
Click the Applications & Gaming link near the top of the page.
You should now see a new menu. In this new menu, click Port Range Forward.
requires you to forward the following ports: 53,80,88,1863,3074
Mar 30, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Hello. I need to change my NAT type on my Xbox 360 from moderate to open using a Westell Versalink 7500 router.
Hello
Your router does not have moderate or open nat options.
Options that it does have are Public Lan - nat type and Private Lan -nat type.
Your router also has a DMZ feature and port forwarding options.
User manual for your router is available at http://www22.verizon.com/ResidentialHelp/HighSpeed/Networking/User+Guides/User+Guides.htm
To get your xbox live working properly, you can try using the public nat type, if that does not solve the problem, turn on DMZ for the address of the Xbox360. Now if that still does not solve the problem, then you would need to set up port forwarding for all the ports that xbox live uses.
I would personally recommend that you enable port forwarding for the required ports.
Ports that need to be open are
TCP 80 • UDP 88 • UDP 3074 • TCP 3074 • UDP 53 • TCP 53
Together with the user manual and xbox360 portforwarding guides that are available here http://portforward.com/english/applications/port_forwarding/Xbox_Live_360/Xbox_Live_360index.htm
You will be able to get it working.
But since that is a lot of information for anyone that has not used port forwarding before I'll write down step by step how to get started.
First get on your computer, You need to connect to the routers own configuration page. By default this is http://192.168.1.1
So, open your internet browser and write HTTP://192.168.1.1 and press enter.
Now you get a a user and password prompt. the username is admin and the password is password. all lower case.
Now on the top menu, click on Firewall settings.
Now select Port forwarding. more information and pictures on the user manual page 98 and forward. You need to create a new rule or rules that forward the above ports - allow them to be open to the internet for the xbox 360.
Looking at page 112. You would create a new port forwarding service, you need to add all the ports one by one. And the host device would be the IP address of the xbox.
Now the DMZ option will be simpler, that is on page 118. You just need to find the xbox ip address from its network options and put it there, and turn on the DMZ. That will allow all traffic for that machine.
Let me know how far you get. I'll help if you get stuck, sorry if this post is a bit unclear, this is a very small box to write in, I can't easily see everything I've already written here.
Sep 27, 2010 | Computers & Internet
How do i change my nat type on linksys wcg200 router device page?
The NAT type on this wcg200 cannot be change. Its either you turn off the nat, Which will disable the routing feature of it.
If you having a hard time connecting to an online game or having problem with a certain application ,l would advice you to just perform port forwarding on this router.
In doing port forwarding you need to get the ports that is needed to open for that certain application to work.
I hope i answer your questions
Cheers,
KJ
Jul 04, 2010 | Linksys WCG200 Router
My wireless router is set has a strict NAT type how do i change this to an open NAT type
For setting up port forwarding, look in your manual on page 5-7.
If you don't have a manual, you can download it here. (It's on page 69 of the .pdf file).
If your application (or game) is not in the list, you will need the port numbers used by that application.
Check that manual or try to find the numbers you need in one of the applications listed here.
You did not mention which version (1-9) your router is, so there might be specific rules to it. Look at this page and find the exact model of your router in the list. (Click "Skip advertisement" on the second page. It's a little bit annoying, but that's how they keep the page up and running. You find great tutorials here.)
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Sep 25, 2009 | NetGear WGR614 Wireless Router
Nat settings on a linksys wireless router
NAT Configuration is also called Port Forwarding. You can simply open the ports by going to the router's setup page http://192.168.1.1 no username and password is admin. You can do it under Applications and Gaming tab, Port Range Forwarding.
Jun 20, 2009 | Linksys Wireless-G Broadband Router
Change NAT from strict to open
You need to do port forwarding on your router. First, you must setup a static IP address on your XBOX. Then You must open these ports on your router setup page using Port Forwarding feature. 80 TCP and UDP, 53 TCP and UDP, 3074 TCP and UDP.
Jun 01, 2009 | Zyxel P660HW-D1 Router
Changing NAT setting
You need to do port forwarding. Search for the port number of that specific game and forward it on the router's admin page.
Apr 26, 2009 | Siemens SpeedStream 6300 (33A6300001)...
Changing nat on xbox live
I had this issue, and solved it recently. Everyone on the internet will tell you to forward ports, or disable the NAT setting, but these never worked for me. As I was about to give up and buy a new router, as a last resort I decided to call tech support. In about 3 minutes they fixed my problem, and it is much easier then port forwarding.
-First go into your 360 network settings and find its mac address.
-In the router settings move to the LAN tab.
-Then go to "dhcp leases".
-Under "current dhcp leases" your 360 should be listed (match the mac address)
-Make a note of the IP address listed for the 360, then delete that lease.
-Now Reserve a new IP address, enter in the MAC address and IP address you wrote down for the 360.
-Check the bypass firewall option (and give it a name if you want) and then add the new entry.
-On the same page, move up to "DMZ Host" find your new entry and click "apply"
-Click the option to reboot your SBG900, then restart your 360, and the NAT should be open.
I hope this helps, if I described it correctly it should be much easier then port forwarding, and more importantly, it should work.
Sep 14, 2008 | Arris SURFboard SBG900 Wireless Router...
NAT? Where?!
Perhaps you are using a different firmware than the one they are using in the guide. If they are using an older one then you may just need to figure it out. Look through your router's settings again for anything that mentions NAT, Port Forwarding, or Virtual Server. Then just pick the port (or ports) that you want to forward and which machine to forward them to.
One last thing that may be causing your issue is that you are not connecting to your router. Does the configuration page that you visit display your routers make or model? If you have a modem and a router, then it's possible you are actually connecting to your modem instead.
May 13, 2008 | Zhone (6218-I2-200) Router
Change NAT to open
I have this router and have just enabled the NAT settings from Strict to Open:-
1. Log into router's IP address (192.168.1.1) and enter password. Select "Advanced Setup".
2. Click on Advanced on left hand menu and select UPnP
3. Check all three boxes in window and click on Apply
4. Close router configuration window and run XBox test again. Worked for me!
Oct 08, 2007 | Zyxel P660HW-D1 Router
Zhone (6218-I2-200) Router Logo
16 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Joe Goldman
Joe Goldman
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
