Question about Canon NP 6050 Copier
E020 switch the power off and on again - Canon NP 6050 Copier
  • 1602 Answers
SOURCE: canon clc 900 Error E020
go on line type in
canon printer error e020 and look at all the ideas to help you fix your problems
rod
Posted on Feb 03, 2009
SOURCE: Canon NP 6545 - Error E020
E020 try by push reset button until show $ upper left
then press key *4* and you will in service mode.
find code error 1 in LCD then press *
copier will restart.
Posted on Mar 11, 2009
  • 1294 Answers
SOURCE: I get a message that says:
Vacuum cleanig the suction fan motors and filters.
Posted on Aug 01, 2009
canontech
  • 1219 Answers
SOURCE: Pls Solve my problem : Canon CLC 1180 Copier error
The probable causes for error :
The developer has deteriorated.
• The developing cylinder fails to
rotate.
• The developing assembly is not
locked.
• The toner concentration (patch
detection) sensor is faulty.
• The developer inside the
developing assembly is faulty.
• The toner level sensor is faulty.
• The concentration sensor is
subjected to stray light (no cover,
front cover open).
• The photosensitive drum has
deteriorated.
In error code E020-0481, means that the problem is in black developer. So I would first try to replace Bk developer, check the developer station for malfunctions ( broken gears, broken developing roller bushings,... ).
Hope that helps!
Posted on Jun 20, 2011
n1yap
  • 3 Answers
SOURCE: e020 00a3
needs fuser assembly. probably bad thermistor.
Posted on Nov 14, 2012
E020 00a3
Nov 14, 2012 | Canon CLC 1140 Copier
Pls Solve my problem : Canon CLC 1180 Copier error Switch power Off and On again. E020 0481 Mr. Santosh Kolte. Pune.
rotate.
locked.
front cover open).
deteriorated.
Hope that helps!
Jun 20, 2011 | Canon CLC 1180 Copier
I am getting e020 error switch main off and on again and again
e020 error is of the main fuser unit u can solve it by press *28* then goto copier then function then clear and clear err dc-con err-hist jam-hist and pull both 1st and 2nd drawer now restart and when the screen is ok again restart then on main screen insert both drawers ur err will be removed -tushar sharma tushar@easy.com -9403343433
Mar 22, 2011 | Canon imageRUNNER 600 Printer
Please help e0020-00ff black toner supply????? comes and goes
Check for blockage in toner supply ,located at rear of hopper. Also is the toner ok
Jun 26, 2010 | Canon imageRUNNER C6800 Copier
I have an older Canon clc 900 Error E020 Switch power on and off again"displays when trying to copy. When I turn the copyer off and on again the same message displays.What to do ?
Error :
Intermittent E020 / E061 codes.
Workaround :
It's possible that there is a poor drum ground from the static eliminator brush. You may need to replace the static brush with the drum grounding leaf spring from a CLC 350 (part numberFA5-9308-000). Follow the procedure in technical publication CTP.NO 700/800-69.
Error :
E020 sub code 0440 and light density on all colors
Workaround :
Check the developer assembly movement, i.e. up & down and that the magnetic roller is turning. Check the EPC readings, laser output, fold back mirror, and the connectors for the developer and the developer bias contacts. If all the above checks are good, then the problem can be with the AC voltage output of the developer bias HVT. The DC-voltage for the developer bias is split between two colors ( magenta & yellow ) or ( cyan & black ). The AC voltage is supplied for all four colors and it's loss will be seen in all the colors whereas the loss of the DC voltage would affect only two colors. To fix the problem replace the developer bias HVT part # FG5-3068-060.
Oct 18, 2009 | Canon CLC 1150 Color Copier
E020-01A8 - clears after swithcing on and off but
iassume this is a color copier if its a 3200 3220 its your yellow drum
Aug 18, 2009 | Canon Office Equipment & Supplies
Canon Ir 550 E020 error
When the scanner motor is started up, the BD input signal does not arrive within a specific period of time.
When the scanner motor is started up, the motor rotation is too fast, and fails to reach a specific revolution within 20 sec at time of deceleration.
While the scanner motor is rotating at a specific speed, the BD input signal cycle is not within a specific range (±2%) for an equivalent of 10 mm (print distance).
While the scanner motor is rotating at a specific speed, the BD input signal cycle is not as indicated (±2%).
During the WMUPR period after the power switch has been turned on or the front cover/left cover has been opened/closed, the drum unit is absent.
Possible cause: The wiring is faulty (short circuit, open circuit). The laser scanner unit is faulty. The DC controller PCB is faulty. The drum unit is not installed.
Mar 27, 2009 | Office Equipment & Supplies
go on line type in
rod
Jan 13, 2009 | Canon CLC 1150 Color Copier
Jan 12, 2009 | Canon NP 6545 Copier
Canon NP 6050 Copier Logo
old marine
old marine
