Question about Sanyo Cell Phones
How to unlock my keypad when the buttons don't work
My keyboard buttons don't work ..phone on 1 mint keyboard botton working but leat no working only keyboard no working
My Dear your phone keypad ic default so please change keypad ic
and keypad problem will solved
Aug 15, 2012 | Nokia N96 Cell Phone
My buttons don't work
Your Phone Keypad Ic Deafult So Please Change keypad Ic
and keypad Problem Will Solved
Jul 24, 2012 | Nokia N96 Cell Phone
I have the door bell style wall button-how do I unlock the unit so the remotes can be synched? I have pressed green button on back of unit with remotes but they won't operate the door.
You don't unlock anything to program the opener for the remotes. If everything is working you do this:
Press and hold the button down on the remote while you press and immediately release the smart/learn button. Do this for each remote.
Jul 11, 2012 | Sears Craftsman LiftMaster Chamberlain...
Don't know how to set key pad lock
Before locking the keypad first remember if the keypad lock is assigned with a security code.
Default value of the security code is normally 0000.
1. To lock the keypad first press the option key, then select the LOCK KEYPAD.
2. To unlock the keypad press the option key then press the "C" button.
You can check more lock/unlock optoons in the users manual, downloadable from this link. Read page 63 and on.
http://dl-www.sonyericsson.com/cws/download/1/150/669/1192984731/J230i__UG_R1a_EN.pdf
Sep 04, 2011 | Sony Ericsson J230i Cellular Phone
Buttons won't work. Just returned from a 6 day golf trip where the SkyCaddie SG4 worked perfectly for the first 5 days. I recharged it in a wll outlet overnight, then on the next day the buttons...
Power On/Off and Key Lock/Unlock - Press the Power button located at the top right
of the Sky Caddie to power on/off or to lock/unlock the keypad. Upon pressing
the Power button you are prompted to choose either "Off" (Left Soft Key) to power
off the device or "Lock" (Right Soft Key) to lock the keypad. To unlock the keypad,
select 'Unlock" by pressing the Right Soft Key, then choose "Yes".
Jul 02, 2011 | SkyCaddie SG 4 Handheld GPS Receiver
My Luxpro psp511 ca is locked and I don't know how
TO LOCK THE KEYPAD: Start with the System Mode switch in either the
HEAT or COOL positions, and the Set Slide switch in the RUN position.
Perform a single press of each button, in the following sequence: NEXT,
NEXT, NEXT, HOLD.
TO UNLOCK THE KEYPAD: Start with the System Mode switch in either
the HEAT or COOL positions, and the Set Slide switch in the RUN position.
NEXT, NEXT, HOLD. The padlock should no longer be present, with the
thermostat now unlocked. If the padlock is still on the screen, please try
to enter the 4-button sequence again.
Jun 01, 2011 | Heating & Cooling
Keypad door lock does not work..?
it's in owner manual. But, first you have to enter your original code and it must work. then you press the 1 button and then enter a new 5 digit code, then press the 1 button again.
Keyless Entry Keypad To unlock the driver front door (20124) , and disarm the anti-theft alarm control (19A366) , (if equipped):
  • Enter the permanent factory code.
  • Enter the owner's alternate code.
To unlock the passenger door(s), press the 3/4 button within five seconds of unlocking the driver door or luggage compartment. To unlock the luggage compartment door (40110), press the 5/6 button within five seconds of unlocking driver or passenger door(s). To turn on the courtesy lamps and light all illuminated components, lift either front door handle (22404) or press any button on the keyless entry keypad (14A626) . To lock all doors, press the 7/8 and 9/0 buttons at the same time with all doors closed. (It is not necessary to enter the key code first.) This will turn off courtesy lamps and arm anti-theft alarm control (if equipped). To program an alternate code:
  1. Enter the five digit permanent entry code into keyless entry keypad .
  1. Within five seconds of pressing last button of permanent code, press the 1/2 button within five seconds of pressing the last button of the permanent code.
  1. Enter any alternate five digit code within five seconds of pressing 1/2 button.
    • Enter a sixth digit as follows to indicate operator's memory seat setting to be set by alternate code:
      • 9/0 — no memory recall
      • 1/2 — memory seat position 1
      • 3/4 — memory seat position 2
      • 5/6 — memory seat position 3
    • After successful programming, the doors will signal by locking and then unlocking.
  • Keyless Entry Keypad Does Not Work Properly
  • Circuit.
  • Keyless entry keypad.
  • Electronic door lock control processor.
  • Open Fuses:
    • Town Car and Crown Victoria/Grand Marquis
    • Power Distribution Box (under hood)- K, 40A (Maxi)
    • Instrument Panel Fuse Panel - 17 (10A), 10 (20A), 8 (15A), 5 (15A) and 4 (10A)
  • Loose Connectors
  • Corroded Connectors
  • Oct 04, 2009 | 1995 Lincoln Town Car
    External keypad is not working
    Sorry - answer found.... my vx10000 has front touchscreen when locked you tap the unlock, and it unlocks....
    The xx9900 :
    To unlock the phone is by pressing the OK button in the middle of the phone. This is the largest button on the phone and elevated from the surface above other buttons.
    Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
    Apr 21, 2009 | LG enV VX9900 Cellular Phone
    How to lock and unlock keypad Motorola VE240
    To Lock your phone
    Hold down the # symbol on your phone until it says: "Phone Keypad is now Locked"
    To Unlock your phone
    The screen should now read in the bottom right hand corner "Unlock". press the corresponding key. It then asks "Unlock Keypad?" "Yes" or "No". Select Yes and press Menu button (also the play/pause button).
    Hope this helps you all!
    Jan 02, 2009 | Cell Phones
    DON,T KNOW MY 3 PRIVACY CODE NUMBERS
    This tip unlocks the 3 digit security lock.
    1. at the same time hold the menu button (top left) and the jump button (bottom left)
    2. This will bring you to the emergency screen (it gives you the option to make an emergency call)
    3. Open to the keypad and hold in the menu+shift+q buttons at the same time.
    4. The phone will reset and clear/unlock the security code
    http://shop.sidekickskin.net/Sidekick-Tips-Tricks
    Mar 31, 2008 | T-Mobile Sidekick ID Cellular Phone
    Cell Phones Logo
    16 people viewed this question
    Top Sanyo Cell Phones Experts
    Jeffrey Thomas
    Jeffrey Thomas
    Level 1 Expert
    270rexton
    270rexton
    Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
