Question about Maytag Dishwashers
Hose won't stay attached to faucet
How do I replace the hose?
SOURCE: hose does not fit on sink faucet
Yes, the adapter was the answer!!! I went to the Sears Service Center and bought one, under $10. HURRAY! And say hello to softer hands . . .
Posted on Feb 15, 2009
gary1121
  • 332 Answers
SOURCE: my hose on my ge portable dishwasher will not stay on faucet
do you have the right connector on the faucet, it should be like a quick connect that pushes on and then locks in place the red button is probly the release button, you have to find the right adapter for the faucet
Posted on Jun 04, 2009
jmgldsmth
  • 1869 Answers
SOURCE: faucet solution for hooking up portable dishwasher
there is a generic adaptor that fits on your faucet; take the name, model# and, hose to a hardware store and, they can show you the right adaptor for your machine
Posted on Sep 15, 2009
  • 127 Answers
SOURCE: Kenmore Ultra wash III will no longer stay
if your adapter that hooks up to the faucet has 4 little white plastic jaws inside it then it can be rebuilt. there is a kit that replaces those 4 jaws, the spring, the attaching clip and the internal seal.. usually runs around 10 buks or so. if i was at the store i could tell you the part number without needing your model number, but any good appliance parts store should be able to locate them for you..
hope this helps,
best of luck,
ttfn
Posted on Oct 29, 2009
  • 864 Answers
SOURCE: My portable dishwasher hose that attaches to the
You should be able to find extension or replacement hoses that you can use to extend the existing hoses at a hardware store. If you need to join two hoses that have female connectors, adaptors with two male connections are available.
Posted on Nov 09, 2009
How to replace suction and return hoses on power steering reservoir
How-to: Replacing the power steering reservoir to pump hose - CEG ...
contour.org/.../82138-how-to-replacing-the-power-steering-reservoir-to-...
Jul 3, 2013 - How-to: Replacing the power steering reservoir to pump hose ... to allow air into the suction side of the PS pump, aerating the fluid. ... off the spring hoseclamps from the smaller return hose and the large hose to the pump.
images for How to replace suction and return hoses
Dec 01, 2015 | Cars & Trucks
Tip
How to troubleshoot water leaks
Water leaks in a washer are often difficult to trace. There are many possibilities to look for. The problem could be a loose connection, a broken hose, a cracked component, or a defective seal. It could also be a hole in the tub. If a hole in the tub is the problem, it's usually best to replace the washer.
Most leaks can be eliminated by tightening water connections and replacing deteriorated components. To stop a leak:
Check the lid seal. If faulty, replace with a new gasket.
- Check the hoses at faucet connections. Tighten connections or replace hoses.
- Check the hoses at water valve connections. Tighten connections or replace hoses.
- Check the drain hoses. Tighten connections or replace hoses.
- Check the inlet nozzles. Tighten connections or replace nozzles.
- Check the splash guard. Tighten connections or replace.
- Check any plastic valve. Tighten connections or replace.
- Check the outlet hose to drain. Tighten connections or replace hose.
- Check the water pump, using the procedures that follow.
on Jan 16, 2010 | Washing Machines
How to replace hose (tire inflator)
I don't know that machine specifically, but you'd probably have to get inside the machine wherever the hose attaches to replace the whole hose.
Aug 05, 2014 | Schumacher Xp2260 1200a -engine Starter/...
Can the hose in the retractable carrier be replaced? How do I do it?
You can replace that hose by fully extending it and locking the reel. At that point you should be able to unscrew the hose from its connector. A replacement hose can be screwed on in its place.
One alternative, if the reel's hose connector isn't inside the spool area, would be to just cut off the hose at the break, then buy a replacement hose end (with barb fitting to match your hose) and a small stainless-steel hose clamp. They work really well when you get one that's correctly sized for your hose. They're hazardous out at the "business end" of the hose, though - they can cut your hands.
Aug 04, 2014 | Toolshopusa Retractable 25' Air Hose
How do I connect the sprayer hose on single sprayer faucet ,peerless style, the pin wont go in?
What is the model number of the faucet? There was no attached pictures to this submission.
Jun 14, 2014 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Leaking faucet
I've had problems with the O-rings at the head leaking, feeding back inside the corrugated hose covering, and pooling under the sink. Might be your problem as well. Verify by holding the head downward, and look for water beading out further up the hose.
Apr 04, 2014 | Grohe Ladylux Cafe Faucet with PullOut...
Maytag Portable Dishwasher coupler/faucet problem
Standard garden hose has same threads/adapter size.for trouble shooting run garden hose to washer try running cycle. Give it 20 minutes to finish previous cycle as it may not be trying to run what appears on settings. Water won't fill unless cycle that will allow such is chosen and active.
Dec 01, 2013 | Dishwashers
I have a 1998 Toyota Pre runner that developed a gas leak. A small hose on top right side on engine connected to what looks like a diaphragm had a break. Replaced the hose thought the problem was solved...
as long as things are running correctly, and you have the right hose there, you should be okay. It sounds as if you maybe didn't have the right hose when you replaced it the first time? Or maybe a cheaper, possible faulty hose? if you have replaced that hose with a quality, somewhat pricey hose, and it does it again, you may have to take it to a shop to look at the diaphragm, because the hose should be able to handle whatever normal pressure the pump, or injector has.
Nov 04, 2013 | 2000 Toyota Tacoma PreRunner
GE portable dishwasher connector hose slips off faucet adapter
Google your dishwasher you will see parts on line There are loads just looked .
Apr 13, 2017 | Dishwashers
Replace pressure house on 1985 mustang
For procedure to replace power steering hoses,click the link below :----http://technoanswers.blogspot.in/2012/02/how-to-replace-power-steering-pressure.html
----------Also its advisable to go through this additional help links.Click the link to go through the procedures:----How to Remove Power steering Pressure Hose?
http://schematicsdiagram.blogspot.com/2011/12/how-to-remove-power-steering-pressure.html
Vacuum hose Routing diagram?
http://repairhelpcenter.blogspot.com/2011/11/vacuum-hose-routing-diagram-for-acura.html
Ac line and evaporator drain hose?
http://repairhelpcenter.blogspot.com/2011/10/ac-line-and-evaporator-drain-hose-on.html
How to disconnect the hose form the Evap Canister?
http://schematicsdiagram.blogspot.com/2011/12/how-to-disconnect-hose-form-evap.html
Vacuum Hose Routing Diagram For Throttle Body?
http://schematicsdiagram.blogspot.com/2011/12/vacuum-hose-routing-diagram-for-1995.html
How exactly the Vehicles A/C Hose works?
http://repairhelpcenter.blogspot.com/2011/11/how-exactly-vehicles-ac-hose-works.html
HOW TO REPLACE AN UPPER RADIATOR HOSE
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-upper-radiator-hose.html
HOW TO REPLACE A LOWER RADIATOR HOSE
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-lower-radiator-hose.html
Fail smog test due to gas filter hose?
http://repairhelpcenter.blogspot.com/2012/01/fail-smog-test-due-to-gas-filter-hose.html
EGR Hoses melting?
http://repairhelpcenter.blogspot.com/2011/12/egr-hoses-melting.html
EVAP connecting hose to PCV valve Collapse?
http://schematicsdiagram.blogspot.com/2012/01/evap-connecting-hose-to-pcv-valve.html
--------How to replace Power steering rack and pinion gear? http://technoanswers.blogspot.in/2012/02/how-to-replace-power-steering-rack-and.html
--------How to replace Power Steering Pump?
Also bleeding:
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-power-steering-pump-on.html
How to replace Steering Linkage? http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-steering-linkage-on.html
-----Car steering wheel makes noise?
http://schematicsdiagram.blogspot.com/2011/12/car-steering-wheel-makes-noise.html
Car makes clicking or tapping sound? http://schematicsdiagram.blogspot.com/2011/12/car-makes-clicking-or-tapping-sound.html
---------This will help.Thanks.
Feb 16, 2012 | 1985 Ford Mustang
Dishwashers Logo
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
