Question about Refrigerators
Replace thermostat kelvinator fridge model CSOOA-R cyclic?
  • 3 Answers
SOURCE: have Kelvinator Cyclic 500 Fridge, Does not seem to defrost prope
has the thermostat been replaced? if so it is probably the wrong 1
Posted on Mar 31, 2009
lojacksdad
  • 121 Answers
SOURCE: finding thermostat for Kelvinator model c-7-r
you can go to the parts store and get a universal thermostat very easy to install
Posted on Apr 23, 2009
oscarn
  • 110 Answers
SOURCE: I have a problem with
Check if the drain pan heater is operating.
Posted on Sep 12, 2010
  • 1891 Answers
SOURCE: replacing a cyclic defrost fridge
need more info like model # and brand . and if your replacing org thermo with which you state is a digital . /in most cases they will not interchange . need model # and brand the give better info . hope this helped m m
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: Hi I have a Kelvinator
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 19, 2010
Kelvinator Cyclic 330 not getting cold enough
Empty the refigerator and freezer, unplug it for about 8 hours, leave freezer door open so it will completely defrost. Plug it back in for 4 hours and close doors before you fill it back up with food. If you have a thermometer, check the interior temperatures before you fill it back up. Refigerator should be around 42 degrees F.
Mar 19, 2014 | Refrigerators
Freezer serial # 845440256 age?
Replacement thermostats depends on whether the fridge is a double door or single door model. You can buy this part from your appliance parts store/supplier.
Feb 20, 2014 | Kelvinator Freezers
Wiring diagram for a Kelvinator 330
There's only 2wires and it shouldn't matter which terminal on the cold control u connect it to. If there's 3wires one should b green and it's a ground wire
Nov 30, 2013 | Electrolux Kelvinator Cyclic Defrost...
Old Kelvinator Cyclic 340. Freezer is Ice cold
Read the below :-
http://www.fixya.com/support/r3886637-refrigerator_not_cooling_enough_or_not
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 16, 2010 | Kelvinator 12 cu. ft. / 340 liter Chest...
Where abouts is the thermostat inside the fridge there are white and yellow wires that go to either side of the fridge and the yeallow ones are broken what are these wires for it is a kelvinator C375vm
It sounds like you have a cyclic defrost fridge,Kelvinators were originally fitted with heat assist thermostats,so in order for the fridge to come back on a yellow wire heater was run around the cooling evaporator in the fridge compartment start running again at approx +4C so when the element fused the fridge did not start again until approx +12C.So instead of replacing heater a different thermo was used that came back on at +4c deg regardless.Kind Regards.
Jul 09, 2009 | Refrigerators
Finding thermostat for Kelvinator model c-7-r
Apr 23, 2009 | Refrigerators
Kelvinator Fridge/Freezer C 340 RM does not switch off
the problem is your thermostat in your frig.the dial with numbers on it.it is no longer sensing properly and theres nothing you can do but replace.that is as long as your dial is not broken[the plastic pice with the numbers] God bless ,tom
Jan 10, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
I have a Kelvinator Cyclic 501 Impression Series fridge. Model C501V-R. no matter what setting it is on everything is freezing - the door seals are in excellent condition.
I used a,Hair Dryer on mine that fixed it, had too do it twice though have not had a problem since, (it froze the entire Thermostat over), had my Fridge for over 30 years only ever replaced the seals recently, no other problems ever
Jun 11, 2008 | Refrigerators
Refrigerators Logo
16 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
