Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
How to connect a sony HT-CT260H sound Bar to Sharp LC-46D64U that connected to Cable Box by HDMI cable
The cable box only has one HDMI plug the TV has four, do I connect to cable box or TV
jsinex2421
  • 62 Answers
SOURCE: No surround sound when attaching hdmi to TV
Try running the optical TOSLINK cable from the TV to the receiver. If the TV doen't have a digital optical output, then try going into the menu on your cable box and setting the audio output to the digital optical out. Also check your TV menu and make sure NETCOMMAND is diabled. Some of your newer HDTV have Netcommand that allows the TV to control other devices through the HDMI cable.
Posted on Jan 10, 2009
  • 3 Answers
SOURCE: Sound problem with Sharp LC-32D4U
I got the sound on my LC32D6U fixed for free. Even though the TV is out of warranty, Sharp considers it under warranty for the sound problem. The number i 800-237-4277.
Posted on Jun 26, 2009
romsky79
  • 822 Answers
SOURCE: My sharp LC-19DV22U Will not connect to my PS3
well alex welcome to fixya technical support online.i just read your problems. there is an option to your problem you can use another cables with RCA inputs capable in your PS3 that can works on videos and also you can buy video converter. thanks!
Posted on Aug 14, 2009
  • 17 Answers
SOURCE: No Audio on Sharp LC-32d43u
If you had sound for before and then lost it (without changing any settings), then try the main resets in the back by the a/v in and out jacks. If this does not work, call Sharp Customer Service (1-800-237-4277) and tell them that you already did the resets. There is a known problem with a heat dissipation pad for the onboard speakers and they will send a repair tech to replace the pad for free, even if you are out of warranty. At least that was the case with my LC-32D6U.
Posted on Aug 23, 2009
satavlad
  • 405 Answers
SOURCE: No sound from ps3 when connected with hdmi to
on your PS3 go setting>sound setting> audio output settings to adjust settings for the audio device (OPTICAL or HDMI)
Posted on Dec 06, 2009
I have a Sony sound bar Model CT380. It has HDMI ARC and optical digital connections. The TV does not have these connections. What can I do to work around this?
How to connect a TV Sound Bar system to a television. - SONY
https://us.en.kb.sony.com/.../how-to-connect-a-tv-sound-bar-system-to-a...
Jump to If your TV has an HDMI terminal (without ARC) and an ... - Then connect theTV's Optical digital ... If your TV does not have HDMI input ...
2.1 ch Soundbar with Bluetooth ' HT-CT380 ' Sony US
www.sony.com/electronics/sound-bars/ht-ct380
Sony Corporation
Rating: 4.1 - ‎9 reviews - ‎$249.99
Discover the 2.1 ch Soundbar with Bluetooth from Sony & explore all the Sound Barsfeatures. ... filter higher frequencies to distribute audio smoothly around the room. ...against the sound bar to make an instant Bluetooth connection. No NFC? ... the HT-CT380 to allow data to pass through the sound bar straight to your TV ...
Dec 28, 2015 | Sony Audio Players & Recorders
How do I connect my ht ct260h step by step, with hdmi input do I use
HDMI can be a bit confusing when first connecting a system. Overall, the HDMI cable system allows for less clutter and digital audio and video, but you need some background to get it right.
The simple answer to your question is that the HDMI on your TV that is labeled HDMI out will go to your soundbar's HDMI input. Now, the reason you have a picture but no sound, will be one of 2 problems. If your TV is labeled with ARC, this means that it has an HDMI with Audio Return Channel and will be compatible with your CT260h soundbar. If you don't have sound, then you need to replace your HDMI cable with a ver1.4 HDMI cable so that ARC is supported in the cable design. If your TV does not provide ARC, then you will need to connect the audio using the digital optical connection which is a fiber optic cable of the TOSLINK variety. This cable should have been included with your soundbar packing.
Also be aware that if you buy a HDMI1.4 with Redmere technology to save on the size of the cable, it has a direction for the signal flow which must be adhered to, otherwise the cable will not pass either audio nor video.
I hope that answers your question.
Feb 16, 2015 | Sony HT-CT260H Soundbar and Wireless...
I just bought a Sony sound bar ht-st7 I have a Panasonic tc-p50vt25 tv and and a Panasonic blueray player these products don't have ARC. I have been using the red white cable connected to my cable box the...
Your TV does support Audio Return Channel (ARC). Try connecting your Bluray player to HDMI 2 and your sound bar to HDMI 1(ARC). You will need to make sure that VIERA link is turned on in the Setup menu of the TV.
Aug 27, 2013 | Sony Audio Players & Recorders
Connecting HT-ct 150 to cable box, and tv with HDMI cables
The user manual for the device should contain a schematic of the various cable sockets:
Sony HT CT150 manual
Feb 05, 2013 | Sony HT-CT150 Theater System
How to connect sharp HT-SB350 to Sharp LC-42D69U
You may have to use the optical cable connections. Make sure there is an optical out on the tv and on the sound bar. Get an optical cable to connect them and go to the audio setup screen and direct the sound from internal speakers to optical out.
Nov 13, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Blu Ray player and dish network sat box both connected to Sony HT-7100DH with HDMI cables. HT-7100DH is then connected to Sony HD TV with HDMI Cable. Blu Ray sound only works if the coax cable is...
Hey my nameis Mike Houston of DISH Network and I see there is a problem with the Sony hometheater system connecting with the DISH receiver. To get the full surroundsound you want there are two different options you can use, the first is to usethe HDMI and connect the RCA cable or you can use the Optical cable for sound.If you have any questions or concerns please e-mail me back; michael.houston@dishnetwork.com.
Jan 03, 2011 | Sony HT-7100DH System
Sony PCM 48 Issue
As long as you continue to have both HDMI and optical outputs connected at same time from the cable box, it will probably always choose the default as HDMI. If you do not want to change any connections then the best thing to do in this case is to always leave the cable box turned on. Otherwise, disconnect the HDMI and connect it to the TV by component video.
Jun 17, 2009 | Sony STR-DE698 Receiver
Wiring problems
Not certain if HDMI can be used in a setup like this. I'd try it from the home theater (HT) to the TV, and other wiring for the other components.
For video:
All of these should have component connections (Y/Pr/Pb). You'll only need the video cables for each device:
  • Video out from cable, HT, and combo player.
  • Video in to TV. Your choice of inputs.
For audio:
Hopefully, the two output devices (the combo player and the cable box) have digital audio (fiber optic, or RCA coaxial). Otherwise, you'll only get stereo sound. VHS is stereo only anyway.
  • Audio out from cable box and combo player.
  • Audio in to HT.
The TV won't have anything to do with audio in this setup. Alternatively, you could try hooking up all inputs to the TV, and connecting audio out from the TV to the HT. Works best if this connection is digital, for surround.
Jan 01, 2009 | Sony BRAVIA DAVHDX275 Theater System
No Closed Caps With HDMI Cable
The information the closed-caption decoder in the TV needs is not provided over the HDMI cable from your converter box. This means the TV's closed-captioning can't be used. But the cable box should provide closed-captioning, so check its setup menus. Contact your cable provider for more information if it's not obvious from the box setup how to turn captions on.
Aug 12, 2008 | Sharp LC-46D64U 46 in. LCD HDTV
Mar 23, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
