Question about Emerson PD6810 CD Boombox
Everything works except volume have none
Cd no sound phono none tape none am fm no sound
3 Suggested Answers
hardrocko
  • 1476 Answers
SOURCE: My Emerson NR305TT will not produce sound
You have one of 3 problems:1) bad solder joints in the amplifier or preamp section 2)defective output transistors/ICs in the power amp or 3)missing or incorrect voltages to the amp section. If the unit has a headphone jack plug in a headset. If you have sound then everything is OK thru the preamp section and your problem is in the power amp. Any competent repair shop should be able to solve this one easily.
Posted on Jun 23, 2006
  • 3 Answers
SOURCE: Blue screen
Change TV viewing channel to 3 or 4. If this works your VCR's output channel got changed during storm. If this is the case, review previous answers to prblems with this VCR.
Posted on May 26, 2010
The volume on technics SL-BD22 turntable will not turn up and stays at one volume
Since the turntable itself doesn't have a volume control the problem is with the amp it is connected to. It should be connected to an amp with a dedicated phono socket. It's no use connecting it to a tape or aux or CD socket. These sockets do not have a built in pre-amp for the magnetic cartridge. If your amp doesn't have a dedicated phono socket then you can buy a Magnetic Cartridge Pre-amp that will plug into a tape socket etc on the amp and have the deck plugged into it. If plugged into a none dedicated socket though you can hear it, the volume will be very low compared to other sources. If you have got it plugged into a dedicated phono socket and the volume is still low, then the internal built pre-amp inside your amp for the deck has failed and will need to be repaired. The pre-amp failure will not effect any other functions of the amp.
Feb 24, 2015 | Technics SL-BD22 Turntable
Crosley CR711
it sounds like the switch that indicates witch item gets power is gone,
Mar 16, 2014 | Crosley Audio Players & Recorders
How do i hook up my i pod up to a mcm530 philips stereo system?
If it has an aux imput all you need to do is get a dock (which will keep the battery charged while playing) or the cheaper way - by connecting a 3.5mm plug to two RCA phono plugs- lead. The 3.5mm plug goes into the headphone output of the I-Pod and the RCA's go into the Aux imput of the Philips.
It can be any imput on the amp (except phono) such as CD or tape.
You will find that you need to turn up the volume on the I-Pod to hear the sound.
Mar 08, 2010 | Philips MCM530 CD Shelf System
My harmon kardon hk 3475 has very poor sound, almost none at all. it does this through all inputs. if i hook up through the line input it sounds ok but i have to use the volume control on my mp3 to turn up...
Poor sound or low volume?
Sudden onset or always like this?
When you say this, "if i hook up through the line input it sounds ok ", what exactly do you mean? What alternatives are you using to Line Level inputs. All inputs except Phono are Line Level.
How does FM sound?
How is the MP3 player different than anything else, hook-up-wise? Do you have it jacked into the Main In? That would bypass all signal processing and selection in the receiver.
There should be jumpers between Pre Out and Main In. Are they there when you DON'T have the MP3 player plugged in there? If not, install a short pair of RCA cables between them.
Describe what is hooked to what in detail. Have you checked to make sure the Mute and Tape Monitor (T-Mon) are NOT active?
A manual is available for free download if you register with retrevo.com .
Feb 24, 2010 | Harman Kardon HK 3475 2 Channels Receiver
2008 Nissan Altima radio (AM/FM/CD) does not respond to buttons except on/off volume. It was playing an FM station (cant't tune/scan) and now plays a CD that won't eject.
2008 Altima radio-the sound just quit working. Everything else seems to be OK. I can change the radio stations, but no sound. Is there a fuse that could be bad?
Nov 24, 2009 | 2008 Nissan Altima
Connection compatibility
Connect the supplied short RCA "Y" adapter cable to the mini jack of the transmitter base unit. Connect the "Y" adapter plugs to the TAPE 2 "REC" L and R jacks. These jacks will supply "line out" levels of any source selected at the Kenwood to the EWOS1 internal amplifier. The line out levels are "fixed" so changing the volume levels of the Kenwood will NOT change the volume out of the EWOS1 speakers. The EWOS1 volume will be controlled by the volume up / down buttons on the front of each speaker, or by the incuded remote when directed at the speaker(s).
The signals from the TAPE 2 jacks are ALWAYS on regardless of the source selected, so the Kenwood volume can be turned to minium and still provide an unchanged sound level from the EWOS1 speakers. Likewise, if listening to FM, Phono, CD, etc. in the room that the Kenwood's speakers are located, the OWS1 speakers will by playing the same FM, Phono, CD, etc program - unless they have been powered off. The point is, that unlike having to choose FM, CD, etc to listen to those soreces, you should never select TAPE 2 as a source. If TAPE 2 is selected, the KENWOOD would attempt to amplify TAPE 2's "PLAY" jacks, which I assume are not being used.
Mar 20, 2009 | Audio Players & Recorders
Volume
Please let me know how your turntable is connected to the music system. I mean, to which input ? (Tape/Aux/Phono/VCR/CD) ?
Aug 24, 2008 | Technics SL-1200MK2 Turntable
Overall Problem - Panasonic RX-ED707 won't work properly at all
only 1 reason for that faults :
there is a flat connects the top panel which has all the controls with the other circutes in the stereo...
so you have to open it and care for the cd unit it damage easily then check the flat for loseness or cuts
it happened to me also and that works perfectly
good luck
Nov 14, 2007 | Panasonic RX-ED707 Boombox
Can't get B Speakers to work
Use the remote and switch it to be in the sub mode (top right corner of remote) It is here (in the sub mode) that you can change volume and inputs.
May 29, 2007 | Onkyo TX-DS555 Receiver
Emerson PD6810 CD Boombox Logo
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
