Question about HP Touchsmart 310-1125f Windows 7 4gb Ram 20" 720p Display 750gb Hdd
Will not wake from sleep mode
Whether you put computer into sleep mode or it goes into sleep mode by just leaving it alone, either way it will not wake up by moving the mouse or pressing a key. It use to for the past 2 years, but now it doesn't. Nothing was changed in the power settings since purchasing this computer.
4 Suggested Answers
SOURCE: monitor goes to sleep and never wakes up
I have called HP Technical Support 6 times about this issue and have logged at least 14 hours into the issue. The things they have done are turn all sleep settings in the "Power Options" in the control panel to "never". The problem persisted. Today, they sent my problem to the complaints department, so maybe they will have the authority to do something for my 5 week old setup.
For me, the monitor was in the "other devices" part on the device manager (go to start menu and type device, and the device manager will show up). I went to HP's website to the support and drivers spot and found a patch for the My Display program. This will allow you to uninstall your monitor, just right click the monitor under "other devices" and click uninstall. After you uninstall, restart and your computer will recognize the and put it under "monitors" in the device manager with the updated drivers. After I did this, the monitor hasn't gone to sleep.
Posted on Apr 02, 2009
budmrtn
  • 11361 Answers
SOURCE: monitor goes to sleep even with sleep mode
Does it do the same with other PC? More likely to have bad soldering works on the 4 inductors on the inverter board, see here: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/
Posted on Mar 10, 2010
budmrtn
  • 11361 Answers
SOURCE: HP f2105 monitor going into sleep mode on it's own
Does it do the same when you use this monitor with other PC, new VGA cable, just need to narrow down the problem first before start taking the monitor apart.
See pictures of what usually goes bad (mostly failed capacitors) with monitors:
http://s807.photobucket.com/home/budm/allalbums
Post back what you find so we can guide you further
Posted on Apr 04, 2010
Why and how does my fitbit flex go into "sleep mode?"
You can enter or leave the "Sleep mode" by tapping the Flex rapidly for 1-2 seconds. You'll feel a vibration and the LEDs will blink. (The blinks will depend on if you are entering or leaving sleep mode.) In this mode, the Fitbit Flex reduces the LED intensity and doesn't give alerts. Afterwards, it will provide some data about your sleep pattern - length, movement, waking up during the night. This can help you determine the quality of your sleep. (Note: it isn't a replacement for consulting a doctor if you always wake up tired.)
I hope this helps.
(You can manually enter your sleep and wake times into the app without using "Sleep mode". Then the app will use the movement data from the Flex to determine sleep quality. However, LED lights (primarily blue frequencies) are known to reduce sleep quality so dimming them helps most people sleep better. The alerts will also interrupt your sleep and reduce the quality.)
Jan 11, 2015 | Fitbit Flex Wireless Activity & Sleep...
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Windows sleep mode problems
Dec 21, 2012 | Computers & Internet
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
Computer won't wake after sleep mode
there is no other solution part from this..............all brand follos the same procedure to come out of the sleep mode do not worry.................................Sameeraryan
Jan 13, 2009 | Sony VAIO VGN-FW230J/B Notebook
Laptop goes into permanent sleep mode, etc
If you can restart it and it starts up fine, then I would go into the power settings and disable sleep mode. Every computer is different on how to wake a sleeping computer, so you could read through your manuals and find out for yours, but I just disable sleep mode on all computers so i dont have to hassle with it.
Dec 30, 2008 | Computers & Internet
Works when it wants to then turns whie with grey line in it
Hi
If only the monitor is going to sleep, then it could be a problem with the connection from the monitor to the computer or with the cable.
If the computer goes to sleep and if you are not able to wake it from sleep then check the sleep mode settings and also the power management settings for the keyboard and mouse.
You may also do a system restore if you are not able to wake the computer from sleep.
Feb 24, 2008 | Sony SDM-HS73P 17" LCD Monitor
Monitor goes to sleep and won't wake up
Yeah, im not sure about how to fix the problem with it shutting down like that, but one option is to go under your control panel and taking off the sleep function, or putting it on a 4 hour timer so that doesnt go into sleep mode anymore. However, the problem is not your monitor but your computer. Id just take the sleep mode off, there is no need to have it on.
Dec 24, 2007 | Computers & Internet
HP Touchsmart 310-1125f Windows 7 4gb Ram 20" 720p Display 750gb Hdd Logo
16 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
