Question about Dishwashers
Dishwasher kitchen aid model#kuds03ftss2 - Dishwashers
aborcass
  • 2651 Answers
SOURCE: Kitchen Aid dishwasher Child lock light on and dishwasher will not start.
if your unable to unlock the "childlock" by holding down the button, then it woud seem that theres a problem with the user interface itself
Posted on Oct 19, 2008
  • 338 Answers
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Posted on Nov 25, 2008
  • 3 Answers
SOURCE: Cancel Light Flashing on Kitchen Aid Dishwasher
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Posted on Apr 27, 2009
localwonder
  • 6784 Answers
SOURCE: Kitchen Aid dishwasher is not cleaning like it use to
Check the following to address this issue further.
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there.
Posted on Jun 21, 2009
FixinFax
  • 3085 Answers
SOURCE: what does add rinse aid and where do you put it
You don't need rinse aids anymore. It rots the wiring...use FINISH tablets, the rinse aid is built into the tablet.
Posted on Jun 28, 2009
How do I fix this. Kitchen aid dish washer?
It appears to be the door switch sensor. http://www.searspartsdirect.com/model-part/kudl03fvss0/0593/0130000/w0808049/00002.html
I suggest replacing it.
Mar 20, 2016 | KitchenAid Kitchen Aid - KUDE40FXBT...
My Kitchen Aid Dishwasher model # KUDS40FVSS0 has blinking cancel, sani-rinse and normal wash lights. It will not run at all. We replace the control board and still nothing. Please Help!!!
I have had this problem. Mine didn't work for over a week and by the time the repair man came over to 'replace the board' it suddenly worked. The guy told me that if you use ANY type of liquid dishwashing soap (for your sink) and any residue/bubble is on the dishes, it can cause your dishwasher to break. I have no idea why but I've been really careful to make sure I wasn't using dish soap prior to putting them in the washer.
I've had 3 service calls on this dishwasher since I purchased it 3 years ago. I'm having similar service issues with my Kitchen Aid Fridge. And of course no help from Kitchen Aid.
Sep 25, 2013 | KitchenAid Dishwashers
I have a new kitchen aide dishwasher. Does any of the insulation padding come off before installation
No. It is supposed to remain on the dishwasher. It helps cushion the machine noise from vibrating through your counter.
May 26, 2012 | KitchenAid Kitchen Aid - KUDC10FXSS...
CHANGE COLOR OF KITCHEN AID DISHWASHER
Go to www.applianceart.com
They have many options available for changing the color of your Kitchen Aid dishwasher. They also have designs, textures and stainless steel.
Apr 10, 2011 | KitchenAid 24 in. KUDI01FL - Multiple...
Kitchen Aid Model # KUDP01ILWH2 Dishwasher dishes
Hi.
Using too much rinse aid will not work. Stick to user manual factory prescriptions. If you use correct amount of rinse aid, and the right product for your dishwasher, that is not the cause of the stains.
Ensure that you are using the right detergent along with rinse aid. Check specifications on manual.
Ensure that the drain well is clean.
Ensure that spray arms have enough pressure, check water level and impeller pump.
If you still get stains on dishes, and you are sure that they had been caused by limescale, that means that the water in your house is too hard. This will also damage your appliances in the long term, causing faults due to accumulation of limescale and rust.
The best thing to do is installing a water filtration system on the appliance inlet.Call your local appliance shop or technician to discuss about the problem and purchase a filtration system for your appliance.
Apr 08, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
Kitchen Aid dishwasher model KDC-18 is not filling with water
Under the machine is the water inlet valve. if you take off the front end of that you find a filter which fills up with rust, and you can clean it out. If that doesnt work, repairclinic.com will sell you a new valve for 32
Jun 13, 2009 | KitchenAid Dishwashers
Want to replace dishwasher panel with stainless steel
Yes indeed! If you know the measurements, you can buy a stainless panel from www.applianceart.com cut to any size you would like. THey also have a cheaper "faux" stainless option too. Many colors and designs as well.
Mar 03, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
I'm not sure if that replacemetn part would work, but I know you can get cheap stainless panels and faux stainless options at applianceart.com. They have colors, textures, seasonal, designs, and stainless steel. You can choose between faux stainless (as seen on HGTV and the Today show) or regular stainless metal. check out www.applianceart.com
Jan 19, 2009 | Kenmore 13593 Stainless Steel Built-in...
Size specs
The measurements are difficult to find and verify. However, you can call Kitchen Aid. They will be able to mail or fax you a copy of the original user manual which should have the specs. The number is: 800-422-1230
Jan 08, 2009 | Dishwashers
Dishwashers Logo
52 people viewed this question
Top Dishwashers Experts
