Question about Electrolux Centralux Vacuum
Motor not running - Electrolux Centralux Vacuum
Roller bar will not spin on dc25 animal
If the brush bar motor is running try putting on a new belt. If the motor is not running it may be the main switch, the switch that activates when you recline the handle, the motor itself or a loose wire or connector somewhere. Check the connection between the vacuum and the power head. If power isn't transferred properly the motor will not run.
You have to closely check all these areas to find the problem.
Mar 05, 2017 | Dyson DC25 Animal Bagless Upright Vacuum
Hoover spirit 900 canister wont turn on?
see this causes and fix it. God bless you
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
Sep 27, 2012 | Hoover Vacuums
Beater bar motor quit, now the main motor quit. Replaced the on/off switch. still nothing
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced.
Sep 27, 2012 | Vacuums
Power is not coming on
Sep 27, 2012 | Wagner Spray Tech Wagner 915 1,500-Watt...
No suction and is not clogged
The motor is bad, when these type of electrical motors go bad the power of the vaccum dies but the motor can still sound like it is running. One way to tell the motor is shot, is the motor while running will be a might louder than it was originally.
Aug 07, 2010 | Bissell Upright Vacuum - The Pet Hair...
The motor won't run. There was interupted running
What model#? Plus check to see if their is a reset switch, sometimes on hoover the switches do go bad, but if the unit is new could be still under warranty
Nov 23, 2009 | Hoover Vacuums
Rainbow vaccum power nozzle model number r-2800c is getting power but the motor does not run
If all connections are good and taking power, this simply means that you need a new motor.
Good luck
Sep 15, 2009 | Vacuums
Power head
If you have checked the power delivery down to the powerhead and you have current running to the powerhead, then you likely have a burned fuse. There is a fuse built into the powerhead motor and is usually located on the field winding. This is not easy for a novice to replace and even most professional repair shops will replace the motor. It is possible to replace the fuse if you know what you're doing, but if the fuse blew, there may be a more serious problem, after all, the fuse is there if the motor starts to experience distress and the fuse will blow to avoid any electrical issues. The fuse can blow if something is jammed into the roller and causes the motor to labor heavily. If this is the case, then the fuse can be replaced safely. If the motor is burning out, then a new fuse will just blow immediately after replacement. What I do is take the fuse out and run the motor without it to see if the motor is still viable and replace the fuse if the motor proves to be o.k.
Feb 08, 2008 | Eureka 6831A Bagged Canister Vacuum
Not enough suction for Panasonic MC-V5716 upright
Probably not the motor protector, its function is shut off the motor if it overheats. Most likely you have a clog or partial clog in the inlet down by the brush roll, or it is in the hose. But if the motor is running, and suction is low, with no clogs, then maybe the motor is running at a slower speed and will have to be replaced.
Nov 04, 2007 | Panasonic MC-V5716 Upright Vacuum
Electrolux Centralux Vacuum Logo
24 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
