Question about Kyocera Mita FS-1030D Laser Printer
Kyocera Mita FS1030D printing too close to top of page
Printer has erratic top margin on documents printed from Word - sometimes prints exactly at the top of the page, sometimes even cuts off a line or two.
SOURCE: How to print configuration page for a Kyocera FS1030D
Try press and hold the green button for about 10 seconds. HOPEFULLY this will cause the printer to produce a configuration page with the details. Good luck!!
Posted on Nov 22, 2008
leroyal
  • 2120 Answers
SOURCE: Kyocera Mita km-1820
Unplug the power cord for 10 seconds.
Posted on Jan 15, 2009
SOURCE: Kyorcera FS1030D - error light sequence
Dave,
You need to empty the excess toner reservoir in the front of the process unit.
Front as in the other end to where you put in a new toner.
All you have to do is open the side panel and empty all the toner out.
That should fix your problem.
Sorry to give you all the instructions like this but people still open up the toner end and have a lot of fun putting it back together.
Enjoy
Posted on Apr 23, 2009
  • 46 Answers
SOURCE: Kyocera Mita KM-2530 Laser Printer will only print the first page not the rest.
Log into your pc as admin and under the driver properties change from kpdl to pcl5
Its a combo of a problem with adobe reader and the KPDL driver
Posted on Jun 11, 2009
SOURCE: Huge Margin with Kyocera FS 1000+
If the FS-1000 prints too far down the page or leave too much top margin or leaves a gap at the top of the page etc (<- for google searches). This is a problem with the felt pads on the three solenoids/clutch electro magnets that are under the right panel (2 under the engine/button board, 1 under the inner plastic cover, sometimes 4 in total on other kyocera printers). They get compressed over time meaning the metal leavers come into contact with the solenoid meaning they are released too slowly. Simply replace the felt pads with .5mm cardboard or another non-sticky non-metallic material. Too thick and it prints too far up the page.
Posted on May 16, 2010
Document not printing from top of page
This is a common problem with this model as it gets older the sponge on the feed solonoids becomes sticky and needs to be replaced. Also one or two of the clutches may need cleaning/replacing.
Feb 20, 2013 | Kyocera Mita FS 1010 Laser Printer
Tip
Top margin, header page, the print is changed (lowered).
If you print and the top margin is altered (low), look at the figure below.
excuse my English.
on Oct 25, 2013 | Kyocera Mita FS-1030D Laser Printer
How do I change margin setrtings foe Lexmark P4350
If you are preparing to print a document that you have created in Microsoft Word, you may be concerned that all the text on the page will print exactly as you see it on your screen. This is not always the case. You can adjust your print margins to ensure that your text prints on each page exactly the way you would like it to appear.
Opening Your Document
Open your Microsoft Word document by double-clicking the Word icon on your desktop. If you do not see the icon on your desktop, then you can locate it where it is buried on your "Start" menu. Click "Start," followed by "All Programs." Then click "Microsoft Office," followed by "Microsoft Office Word." A new document will open on your screen. Click the "Office Button," followed by "Open." Scroll through the files listed, and double-click the one you would like to print. It will open on your screen.
Check Your Margins
By default, your page margins are set to 1-inch margins on the top, bottom, right and left of your page. You can check your margins or change them by clicking "Page Layout," followed by the "Margins" button.
Select New Margins
Select a different margin size, such as "Narrow," which indicate 1/2-inch margins, or "Wide," which indicate one-inch margins on the top and bottom and two-inch margins on the left and right. You also can select "Moderate," which indicate one-inch margins on the top and bottom and 3/4-inch margins on the left and right. Finally, you can select "Mirrored," which indicates one-inch margins for the top, bottom and outside. The inside margins are set at 1 1/4 inches.
Print Your Page
Print your page. Press "Control" plus the "P" button. The printer dialog menu will come up. Make sure that "All Pages in Range" is selected. Press "OK." If your printer cannot print your new margins, then a new menu will pop up telling you to adjust your margins.
I hope you find it very helpful. Best regards.
Aug 22, 2011 | Lexmark P4350 All-In-One InkJet Printer
Can't print entire pdf documents only first page.
There may be a few possible things for your to try. Below is the list of things you can try.
1) Reinstall the PDF software that you use to open your pdf documents. (reader or acrobat) *restart machine after reinstall.
2) Remove the printer from your list of printers and faxes then add it back again
3) Restart the spooler service
click start -> run
type services.msc then ok
on new window, look for print spooler, right click and select restart service.
May 29, 2009 | Kyocera Mita FS-C5016N Printer
Kyocera fs-3830 cutting off print on top of page
check the margin settings and outline settings because minor things worries us too much
May 01, 2009 | Kyocera Mita FS-3830N Laser Printer
Printer does not print whole document
In 'Print Preview' look at the margins, and see if anything is too close to the edge of the paper. If it is, then set your margins further from the edge, or drag graphics further from the edge, etc.
To correct the margins that are set to close to the edge of the paper, open the document in Microsoft Word and follow these steps:
  1. Make sure that you are using the same printer driver that gave you the error in Microsoft Word Viewer.
  2. In Word, on the File menu, click Page Setup.
  3. Click OK.
    You receive a warning dialog box about the unprintable regions.
  4. Click the Fix button.
  5. Save and close the document.
You can now open and print the document in Word Viewer without receiving the error message.
Dec 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Dave,
Enjoy
Dec 15, 2008 | Kyocera Mita FS-1030D Laser Printer
Sep 28, 2008 | Kyocera Mita FS 1000+N Laser Printer
Sep 25, 2008 | Kyocera Mita FS-1030D Laser Printer
Kyocera Mita FS-1030D Laser Printer Logo
313 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
