Question about Water Heaters
I require an instruction manual for a Heller Wall Heater Model cwh50
Model # bth199100 low igniter current
Usually requires igniter replacement.
Here is a link to the troubleshooting page - says call service but details possible remedys...
Smith Vertex 100 Power Vent DV Series 120 Instruction Manual Fault And...
Jan 08, 2015 | AO Smith A.o. Smith Bth-199 Commercial...
I just bought irect water heater model HL40Sk ,is heater comes with legs it was nothing in corton ?
It most likely is a wall mounted model. Did it come with instructions? That will show you how to install it.
Sep 09, 2014 | Dunkirk HL40SK Hotline Indirect Domestic...
How can i install my hot water heater model 71-408 b
71-408 is probably electric water heater.
Unknown brand, unknown type.
Water heater comes with product manual with step-by-step instructions.
Example instructions:
http://waterheatertimer.org/pdf/How-to-install-electric-water-heater.pdf
If this is under-counter model:
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Oct 25, 2012 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Installation instructions for house
if this is what the problem thing says it is then this type of water heater requires a special instaliation ,the room its in must be ventilated with permant vents through to a outside wall ,then a special valve in the flue pipe to prevent blowback down the chimmney also another valve in the flue to shut off heater in case of a partial blockage liuke a birds nest .If you are not sure of exactly what to do and the security and safety measures that go with this type of heater then get a plumber in unless your mounting it outside in a roofed over space with no sides like a porch .
Dec 25, 2011 | Bosch ProTankless GWH C 800 ES LP Tankless...
7-25-11. Purchased Reliance 909 model 950 GKRT 200 natural gas hot water heater. 7-31-11, installed said hot water heater according to instructions and code, filled with cold water and checked for gas and...
The problem requires looking at manual and service handbook, except handbook doesn't show most recent water heater.
My first check point would be gas supply, and then vent draft, and then air supply.
Take off front cover and try lighting again to make sure air supply is not problem.
Review lighting instructions.
If there is no gas, and gas is turned ON, then gas control valve is suspect.
On-line manual for Reliance 909 gas
http://www.reliancewaterheaters.com/lit/om/manuals/186486-002.pdf
Reliance 2006 service handbook:
http://waterheatertimer.org/pdf/Reliance-2006-Service-Handbook.pdf
Other resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/images/Test-water-heater-vent-1400.jpg
http://waterheatertimer.org/images/Water-heater-in-attic-800.jpg
Jul 31, 2011 | Reliance Natural Gas Water Heater Control
How do you relight the pilot light after it has blown out or the gas supplied has been turned off.
Instructions for relighting pilot on Tankless water heater are in the product manual:
Model number is on label located on side of unit.
Open following link to help identify product and download possible manual:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
For tank-type water heater, the lighting instructions are usually printed on side of tank in addition to the product manual.
Find the model number and re-post question with as much information as possible for more assistance.
Jul 30, 2011 | Bosch Water Heaters
Pilot will not stay light but will turn on and work properly
When having a problem with pilot and burner, the place to start is troubleshoot section in your manual.
Whirlpool is probably made by Craftmaster which I believe is a Rheem company, and Rheem makes a number of different models.
Some models have specific manuals and others have generic manuals.
Open Rheem water heater page and click on water that matches your water heater. On page that opens, click on tab that says 'specs' and then download manual.
http://www.rheem.com/Products/tank_water_heaters/gas_water_heaters
If none of those water heaters look like yours, open following link to help identify company website and download manual. Craftmaster website does not have instruction manuals.
http://waterheatertimer.org/Water-heater-manufacturers.html
All gas water heaters require periodic maintenance.
Some require yearly maintenance.
The burner parts require cleaning.
http://waterheatertimer.org/images/Clean-burner-300.jpg
http://waterheatertimer.org/images/Clean-burner-250.jpg
May 01, 2011 | Whirlpool Water Heaters
I just bought a house, and the water heater instructions posted on the water heater is all covered up by the earthquake straps! The earthquake straps are a requirement in California, I can't remove them....
1) Model 41VR50N is Rheem fury gas water heater.
Look on tank label, the second 2 digits of serial number are year of manufacture.
2) Rheem does not show that specific model number, but has generic manuals for Fury series:
Open link to read about Fury series, and access brochures and manuals.
http://www.rheem.com/product.aspx?id=CC643E03-4C15-4775-B139-E504A95651F7
3) Sample manual for Fury appears on following link:
http://globalimageserver.com/fetchDocument.aspx?id=01091171-3bac-4cb9-a0a8-a11aac3bd668
4) Rheem phone number: 1-800-432-8373
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 30, 2011 | Rheem Water Heaters
DIDNT GET INSTALLATION INSTRUCTIONS WITH MY E-75 WATER HEATER SAFETY STRAPS. ANY SUGGESTIONS?
1) Watts doesn't seem to have installation manual.
Page 7 on sales-brochure/manual shows your product assembled.
http://media.wattswater.com/F-Spcmkr.pdf
2) Add a comment for more free help.
3) Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater straps or any do-it-yourself project. Give phone rep link to brochure/manual so they can speak to you about each individual part while you describe location of your heater and type of wall surface.
Jan 16, 2011 | Watts E-75 Earthquake Water Heater Safety...
No Instructions - not a water heater
Is it radiant floor heating? I am assuming you're talking about the control unit... Need more information about the type of heater you're using, model, etc. Does it look like this?
http://www.stiebel-eltron-usa.com/radiant.html
If so, it's probably made by their sister company Energy Products.
http://www.energyproducts.biz
You can find the PDF for that heater which includes maintenance, installation, and troubleshooting information for their website.
http://www.energyproducts.biz/PDF/sharkmanual.pdf
Nov 17, 2008 | Water Heaters
Water Heaters Logo
157 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
