Question about Proscan PSVR57 VCR
Vcr cuts on and off does not stay on? - Proscan PSVR57 VCR
Program my remote
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Jun 11, 2012 | Televison & Video
Instructions and programs
Direct Code Entry
    CODE SEARCH METHOD
Apr 26, 2012 | Televison & Video
Need users manual to program remote
Direct Code Entry
Code Search Method
  1. Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search
Mar 24, 2012 | Sylvania 6719DF 19" TV/VCR/DVD
Gflight@yahoo.comdo you have the universal remote code for emerson dvd vcr combo ewd2202
Hello
Unversal remote setup codes for Emerson DVD/VCR combo are:
0456 [0458 0227]
Where the code is listed as [### ###] the first is for the DVD and the second is for the VCR. Otherwise just the one code operates both the DVD and the VCR.
Direct Code Entry
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
OK
Aug 13, 2011 | Emerson EWD2202 DVD Player/VCR
I need the code for a magnavox dvd vcr combo. its the quick set up code or codes. its for little leaps learning steps. i cant find the manual for it.
Hello
Setup codes for Magnavox DVD/VCR are:
0456
[0914 0286] [0969 0286]
Direct Code Entry
OK.
Jul 19, 2011 | Philips Magnavox DVD/VCR Dual Player
My magnavox model mwc20t6 keeps turning off after 10 to 20 secs
tv was working fine however when we moved it to another room it will not power on at all even using different plug ins
Nov 22, 2008 | Philips Magnavox 20MC4304 20 in....
Magnavox vcr/dvd
cold solder that the common problem of tv so try to re solder the power supply or the jungle & horizontal section
Sep 22, 2008 | Philips Magnavox 27MS343S 27" TV
Tv cuts off
being it was older and a left over gift....we trashed it and saved my husband's blood pressure.
Aug 06, 2008 | Symphonic Televison & Video
DVD problem with Toshiba TV/VCR/DVD Model MW24FP1
I've only had mine for 3 years- DVD didn't recognize 2 out of 3 discs or would cut out- started about a year ago. Today the whole picture went out. Just don't make them like they used to
Mar 04, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
VCR eats the tape
you have a bad take-up reel clutch or a belt on the bottom of the player mechanism that is causing this trouble.
Apr 12, 2006 | Philips VR630 VHS VCR
Televison & Video Logo
19 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
