Question about Encore Computers & Internet
Enter the following bits 20-24 letters faaf8 3262a b6f31 e6d99 18a0a 92275
    Scholar:
    New Friend:
  • 149 Answers
HEX = binary bits = decimal
FAAF8 = 11111010101011111000 = 1,026,808
3262A = 110010011000101010 = 206,378
B6F31 = 10110110111100110001 = 749,361
E6D99 = 11100110110110011001 = 945,561
18A0A = 11000101000001010 = 100,874
92275 = 10010010001001110101 = 598,645
Is this a homework question of some kind?
Posted on Apr 15, 2014
FX-991es. How do I enter a formula?
The question is For what purpose?
To enter letters (A,B,C,D,E, X,Y) Press the ALPHA key followed by the letter symbol you want to enter. The color of the letters are the same as that of the ALPHA key.
Aug 01, 2015 | Office Equipment & Supplies
Tip
INSTALL WINDOWS 7 USING USB PEN DRIVE !!!!!!!!
Requirements:
*USB Flash Drive (Minimum 4GB)
*Windows 7 or Vista installation files.
Follow the below steps to create bootable Windows 7/Vista USB drive using which you can install Windows 7/Vista easily.
1. Plug-in your USB flash drive to USB port and move all the contents from USB drive to a safe location on your system.
2. Open Command Prompt with admin rights. Use any of the below methods to open Command Prompt with admin rights.
*Type cmd in Start menu search box and hit Ctrl+ Shift+ Enter.
Or
*Go to Start menu > All programs > Accessories, right click on Command Prompt and select Run as administrator.
3. You need to know about the USB drive a little bit. Type in the following commands in the command prompt:
First type DISKPART and hit enter
Next type LIST DISK command and note down the Disk number (ex: Disk 1) of your USB flash drive. In the below screenshot my Flash Drive Disk no is Disk 1.
4. Next type all the below commands one by one. Here I assume that your disk drive no is “Disk 1”.If you have Disk 2 as your USB flash drive then use Disk 2.Refer the above step to confirm it.
So below are the commands you need to type and execute one by one:
SELECT DISK 1
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
Don’t close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Next insert your Windows7/Vista DVD into the optical drive and check the drive letter of the DVD drive. In this guide I will assume that your DVD drive letter is “D” and USB drive letter is “H” (open my computer to know about it).
6. Maximize the minimized Command Prompt in the 4th step.Type the following command now:
D: CD BOOT and hit enter.Where “D” is your DVD drive letter.
CD BOOT and hit enter to see the below message.
7. Type another command given below to update the USB drive with BOOTMGR compatible code.
BOOTSECT.EXE /NT60 H:
Where “H” is your USB drive letter. Once you enter the above command you will see the below message.
8. Copy your Windows 7/Vista DVD contents to the USB flash drive.
9. Your USB drive is ready to boot and install Windows 7/Vista. Only thing you need to change the boot priority at the BIOS to USB from the HDD or CD ROM drive. I won’t explain it as it’s just the matter the changing the boot priority or enabling the USB boot option in the BIOS.
Note: If you are not able to boot after following this guide means you haven’t set the BIOS priority to USB. If you got any problem in following this guide feel free to ask questions by leaving comment.
on Apr 02, 2010 | Computers & Internet
Ps3 router connect
a bit is a computer term which can be either 1 or zero. so a 40 bit password would be something like 1100011000011101100110010100101011001010 or any other combination of 40 1's and 0's.. familiarity with Binary numbers would help here.. not easy to remember though.
Hexadecimal is another method used to help simplify binary notation and we use the digits 0-9 and the letters A-F to represent a grouping of 4 binary digits or 4 bits. so the 40 digit string above could be represented as 10 Hexadecimal digits as follows
C61D99499ACA - which is a little easier to remember. ASCII is a standard by which we use 8 bits ( 8 binary digits or 2 hexadecimal digits ) to represent the numbers, letters and symbols on our keyboard... using a 5 letter password such as Bird? ( including the question mark) would be the equivalent of the following hexadecimal representation
42 69 72 64 3F or the binary/bit representation
0100001001101001011100100110010000111111
Hope this helps.
Nov 23, 2013 | EnGenius EUB9707 Wireless N Mini USB...
I found the "user's guide"
Some keys have a letter of the alphabet next to them. The letters are A, B,C,D, M, X, Y. They correspond to memory registers (memory locations) in which you can store values.
To enter a letter as when you are entering an expression with variables, you press the [ALPHA] key followed by the key next to which is the letter you seek. To enter letter A, You press [SHIFT] [(-)] if I am not mistaken.
If you want to solve an equation (solve for X by default) press SHIFT (Solve) not the = sign at the bottom of screen.
Feb 26, 2011 | Casio FX-115ES Scientific Calculator
How do you get a letter on the calculator
Feb 22, 2011 | Casio FX-115ES Scientific Calculator
I want my sandisk memory card of 2gb to be formatted which needs drivers.
there is no requirement of driver to format any external memory card
you may format the card by following this step:
First connect you memory card to the PC and check the drive letter of your memory card
Start - run - (type) cmd - (press enter)
a black window will come
write the command
format (drive letter followed by :)
for example if your memory card has a drive letter as "K" then you may write like this
c:\format k: (press enter) you may also use the command
c:\format /s k: (press enter)
Jan 16, 2011 | Computers & Internet
Black screen with white arrow
Step 1: Opening a command promptThis error prevents Windows XP from opening. This problem has to be addressed from a command prompt environment. Use the following steps to open a command prompt environment:
  1. Turn on the PC and press the F8 key repeatedly when the first screen appears.The Windows advanced options menu appears.
  2. Use the Up and Down Arrow and Enter keys to select Return to OS choices .
  3. Select Microsoft Windows Recovery Console .
    NOTE: If "Microsoft Windows XP Recovery Console" is not listed, restart the PC with a Windows XP CD, Recovery Console CD, or Recovery Tools CD in the top CD or DVD drive and open Microsoft Windows Recovery Console. If a Windows XP Setup screen appears when using Recovery Console CD's, press the R key to open the Recovery Console.
    NOTE: If "Microsoft Windows XP Recovery Console" does not list and you do not have a CD with recovery console, try the following:
    1. Turn on the PC, and press the F10 key repeatedly at the first screen.
    2. At the Recovery screen, click Advanced Options .
    3. Press the Alt + D keys at the same time to open a command prompt window and skip to step 5.
  4. When the log in prompt appears, press the number next to the windows version (min int or Windows) and type the log on password. Try pressing Enter if you do not know the password.
  5. At the command prompt, type the following: disk part
  6. Press Enter , do one the following:
    • If a table of volume names appears, remember the drive letter next to the main drive volume name (usually D or H next to HP_PAVILION or PRESARIO) and press the Esc key.
    • If a disk part prompt appears, type list volume , press Enter , remember the drive letter next to the main drive volume name (usually D or H next to HP_PAVILION or PRESARIO), type exit when done, and then press Enter .
    NOTE: If the main drive volume name does not appear in the list, the PC needs to be recovered. For more information, refer to Performing a Full System Recovery in XP .
Step 2: Replacing the file from a backup folderUse the following steps to find and replace the L sass file from the command prompt environment:
  1. Type the following at the command prompt: CD X:\i386 (where X is the main drive letter)
  2. Press the Enter key. If the error The system cannot find the path specified appears, enter the following paths, in order, until the error does not occur:
    • cd X:\Windows\i386 (where X is the main drive letter)
    • cd c:\i386
    • cd c:\Windows\i386
  3. Press the Enter key, and type the following at the command prompt: expand lsass.ex_ X:\windows\system32 (where X is the drive letter)
  4. Press the Enter key, and type the following at the command prompt: cd X:\windows\system32 (where X is the drive letter)
  5. Press the Enter key, and type the following at the command prompt: attrib lsass.exe -r
  6. Press the Enter key, and type the following at the command prompt: rename lsass.exe lsass.bak
  7. Press the Enter key, and type the following at the command prompt: rename lsass.ex_ lsass.exe
  8. Press the Enter key, and type the following at the command prompt: exit
  9. Press Enter and the PC restarts without the error. If the error persists, go to the next step.
Step 3: Recovering the PC If the error still continues, recover the PC .
Please rate me if this solution works for you
Thanks......Have a great time.
Jul 11, 2010 | Dell Inspiron 530s Desktop Computer
The letter N doesn't function and unfortunately it
The ASCII equivalent for the lowercase "n" is 110. The uppercase "N" is 78. So, to enter your password with these letter equivalents, follow these steps:
  1. To enter "n": hold down the ALT Key and press 110 in the numeric keypad. When you release the keys after you entered 0, the letter "n" will be entered in your password area.
  2. To enter "N", use ALT + 78 like step number 1.
Give it a try and I hope you will succeed.
Jun 08, 2010 | Acer Aspire 7110-2069 Notebook
How do you put the codes in to the Eurovox
hi you need to go to menu on your remote and then press the yellow button then put in the code you will need to use some letters as well you can do this by using the letters next to the instructions for example if you need A you press tv on your remote that will give you A and you follow the rest with your remote using what you need to press for your next letter hope you can understand how ive explained it to you its a bit difficult to explain without showing you hope its helped im looking for the virgin codes does anyone have them please
Nov 30, 2008 | StarTech.com StarView SV211K 2-port KVM...
System not booting
take windows xp cd and repair from the cd
Sep 01, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
37 people viewed this question
Top Encore Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
