SOURCE: Universal Remote Control CODE
You would need to contact the company that makes the remote and maybe Cyberhome for the code.
SOURCE: GE Universal Remote Code for my Insignia DVD Player NS-DVD1
if you have already tried "code search" then you may have to return that remote and get a different name brand of universal remote.
SOURCE: im using the rca rcr312w
SOURCE: rca remote control code list
OK GANG: HERE GOES, I PURCHASED A RCA REMOTE (RCR312W), 3 CHOICE FUNCTION.
SAT-CBL...TV...VCR-DVD.
I HAVE 2 DIFFERENT TV'S, DAEWOO TV AND A PANASONIC TV/VCR. THE REMOTE HAS
WORKED ON BOTH SETS. I DROPPED THE REMOTE WHEN IT HIT THE FLOOR THE BACK
FLAP HOLDING THE BATTERYS KICKED OFF AND ONE BATTERY FELL OUT. I WENT NUTS
FOR 2 DAYS TRYING TO GET THE CODE FOR THE DAEWOO. TODAY 11/14/2008 A FRIEND
GAVE ME A PANASONIC TV/VCR 20". AGAIN I TRIED TO FIND THE CODE, DIDN'T WORK OUT EASILY, AGAIN DRIVING ME LOONY TUNES IF YAA KNOW WHAT I MEAN.
HERE IS THE SKINNY: SOLUTION TO YOUR PROBLEM !!!! IT DOES WORK.
1, TURN ON THE COMPONENT YOU WANT TO PROGRAM.
2, PRESS AND RELEASE THE COMPONENT BUTTON ON YOUR REMOT THAT CORRESPONDS TO THE COMPONENT YOU WANT THE REMOTE TO OPERATE.
TV, VCR, ETC... THE ILLUMINATED ON-OFF BUTTON WILL TURN ON AND STAY ON.
3, NOW PRESS BOTH BUTTONS ON-OFF AND TV, OR: ON-OFF AND CBL. WHAT EVER.
THE ON-OFF BUTTON ON TOP OF THE REMOTE WILL TURN OFF, KEEP PRESSING
AND IT WILL COME BACK ON AND STAY ON. RELEASE THE BUTTONS,BOTH.
ON-OFF WILL STAY ON NOW.
4, KEEP POINTING THE REMOTE AT THE COMPONENT, THE REMOTE AND THE TV
NEED TO TALK TO EACH OTHER,(MAKES SENSE.)
5, GO TO THE BOTTON OF THE REMOTE AND PRESS THE "PLAY" BUTTON,
RELEASE. "" KEEP PUSHING THE PLAY BUTTON EVERY 5 SECONDS,
UNTIL THE TV TURNS OFF"". OR THE VCR, OR THE CBL, WHATEVER YOU ARE
PROGRAMING.
6, NOW: PRESS AND RELEASE THE "REVERSE" BUTTON, THIS IS AFTER THE TV
HAS TURNED OFF. TV SHOULD TURN BACK ON WHEN THE "REVERSE" BUTTON
IS PUSHED.
7, IF THIS WORKS THE LAST STEP IS TO HIT THE "STOP" BUTTON,
THIS WILL SAVE THE SETTING. REMOTE SHOULD BE PROGRAMED AND TURN
THE TV ON AND OFF. YOU DON'T NEED THE SILLY CODE NUMBER, THE REMOTE
DOES THE ACTIVE PROGRAMMING AUTOMATIC.
HOPE THIS HELPS YAA ALL... "PEACE".........OKIE
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Unfortunately,
Coby is a company whose electronics cannot be controlled by any remote
other than the one that came with it. This means there is no code
available for universal remotes. If you need a replacement remote (it
will be identical to the one that came with the unit) please call our
customer service number above. They will take your information and
provide you with the procedure for ordering a part from Coby.
If
you feel this solution doesn't deserve a good rating, please let me
know why so that I may better assist you. If there is anything more I
can do to help, I will!
