Question about Kenmore Refrigerators
I have a kenmore refrigerator with freezer on bottom--model # 59675502400-- replaced thermostat and now freezer is getting cold but top refrigerator is still warm-- the frig started to make a noise last Saturday and then stooped working and both freezer and top refrigerator was warm. Fans are running in freezer as well as in back near compressor. The thermostat replacement helped get freezer going and compressor running now but refrigerator top is still warm? Frustrated!
SOURCE: kenmore elite refrigerator, model # 59676534500
I went ahead and signed up for Sears' service warranty since I knew I had to get someone to come out.  IT costs $200/yr.  They say it covers everything, but when the technician came out, he told me that it just covers $500 per visit.  He said that a new motherboard and the labor alone was going to make it $498.  Anyway,   he had ordered a new motherboard. Apparently the motherboard wasn't working.  It is located in the back bottom left side of the refrigerator behind the panel.  There is a compartment on the lefthand side that slides out and houses the motherboard.  He put that in and also had to fix the fan that is in the back of the freezer.  That fan is the one that sends cool air up to the refrigerator part. When I had looked at the fan before the repair man came, it was not moving at all.  So at least take a look at the fan in the freezer.  Just take out the freezer drawers, and the fan is located in the top center of the freezer behind the compartment cover.  Maybe that's the problem with your refrigerator, the fan.  Hope that's all it is. Good luck!
Posted on Jun 25, 2008
  • 958 Answers
SOURCE: Kenmore Refrigerator 596.72913200 refrigerator is cold and freezer is cold but nothing is frozen
hi lussed,
your problem is still poping up even though it was resolve already. i guessed you should rate a technician in this form as to delete the work from the list of jobs to do.. i am on the way to solve it but you had it solve with a real technician.
can you just rate me?...thanxs...
drcool299
  • 958 Answers
SOURCE: Kenmore model 59675502400
if the evaporator is clogged with ice, then you have a defrost problem.
check the defrost heater and the bi-metal .
to answer your question what controls the fan then it is the module that controls the fan.
you said you have diagnostic to test the damper then there should be a procedure also to test the evaporator fan motor.
why don't you try it..
tnx 4 using fixya,
drcool
Posted on Aug 26, 2008
  • 1462 Answers
SOURCE: refrigerator warm on top, cold bottom, blower fan top of freezer not turning
check continuity thro the fan motor and check it is free to turn. also check if power is present at the fan
Posted on Oct 13, 2008
  • 906 Answers
SOURCE: Kenmore 596.72913200 refrigerator cold, freezer cold but not freezing
good day,
hope this link below will solve your problem.
ref
Posted on Aug 03, 2010
Why is the top of refrigerator warm and bottom freezer cold
Sounds like you may have either a bad defrost heater or a bad defrost thermostat or both
Aug 18, 2015 | Kenmore Refrigerators
Kenmore side by side Refrigerator top portion is not getting cold. The freezer is working and the bottom portion of the refrigerator is cold but not the top portion of the refrig,
the refrigerator simply by transferring the cold air from freezer via circulation fan the temp controls tells the fan to circulate cold air until the thermostat is satisfied I would check to see if the fan is blowing on most models I have seen its located in the left rear wall closest to the freezer above the top shelf
May 02, 2012 | Kenmore Refrigerators
If the ambient temperature is the same or less than the temperature in the fresh food cabinet of a refrigerator with the freezer on top, will the stat ever call for cool? sub question---where is the...
Yes, and if you turn the thermostat colder and the thermostat is in good condition it will. You model was made with a mechanical thermostat with Freon filled probe. You may need to close the cold air flow to bottom during extreme cold days and redirect the thermostat probe closer to the freezer opening but it should work. My refrigerator worked fine in ten inches of snow last year and temps in the teens. Thanks, Sea Breeze.
Jan 17, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Self defrosting not defrosting not cold in bottom of frig has top freezer
How to checkeverything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check defrost timer, defrost heater, defrost thermostat. Inmost newer models the timer has been replaced by an electronic control board.If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicksand everything shuts down. The heater should now come on. If it does, replacethe timer. If it doesn't, check the heater and defrost thermostat. Turn thetimer again till everything starts back up to end the defrost cycle.
Sep 06, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Refrigerator side temp keeps dropping below freezing.
Set the freezer temp control to MAX cold and see if it improves.
If not replace the off/on thermostat.(cold control)
May 24, 2009 | Kenmore Refrigerators
Top freezer Freezes/ Bottom not cold
defrost problem. advance defrost timer to defrost (till it shuts off) . remove freezer panel, check voltage and amps to heater,if heater is hot, replace timer, if heater is cold and no voltage, replace defrost limit switch. defrost all ice, carefully! with hair dryer, no poking with screwdriver.
Oct 26, 2008 | Kenmore 53642 / 53644 Side by Side...
tnx 4 using fixya,
drcool
Aug 26, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore elite refrigerator
It sounds like the fan is not circulating the air from the freezer to the fridge. Since it's new then you should contact the store where you purchased it for exchange or repair immediately.
Jul 08, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
