Question about Crayola Marker Airbrush Set
Markers that came with it wont work - Crayola Marker Airbrush Set
Hello i have a toyota camry 1992 and my passenger side marker wont turn off ???
That's very odd, because the wiring for all of the side markers are just splices from the nearest park lamp wires- the rear tail light in the rear (and the license plate lamps are also splices from these tail lights), and in the front side markers, they are splices from the nearest park lamps. Do all the other park lights work and turn on with the park light switch on? I would examine the 2 wires from that side marker's socket to the wiring harness it goes into-the power wire would somewhere splice into the passenger tail light wire. The other wire would be a ground wire and also splices into a ground wire for the rear end. To be on, the marker lamp would have to be getting power from some live source. I can't imagine where. Does the rear passenger light work correctly?
In that harness to the rear where the park lamps run, there might be a live wire going to an electrical trunk latch switch, or maybe a trunk lamp. If the wires were frayed right beside the side marker wire, you could have some cross feeding of power between the two. Let me know, we always appreciate feedback.
Sep 06, 2015 | Toyota Cars & Trucks
Why wont my neato won't respect the magnetic boundry markers
Either your markers are at the wrong level or your bumpers are sticking.
Jun 10, 2014 | Neato XV11 Vacuum
Have a 2010 2500 dodge the under mirror lights and the passger front marker and the passger reverse light wont work ?
Replace the bulb in the front lens to get the mirror and marker to work. Replace the the bulb for the reverse light also. Both are on seperate circuuits.
Mar 19, 2014 | Dodge Ram 2500 Cars & Trucks
Marker lights wont go on
on 1998 and earlier models, the side marker light housing is located next to the headlight housing. Remove the screws and pull out the housing to access the bulbholder on the back of the housing. On 1999 and later models, the park and turn signal bulbs are located in the bottom of headlight housing. Twist the bulbholders out to replace the park or turn signal bulbs. Installation is the reverse of the removal directions.
Apr 04, 2013 | 1995 Jeep Grand Cherokee
2000 sunfire rear marker lights and Pontiac light not working?
If this is a coupe, check the 10A HVAC fuse in the instrument panel fuse block.
Sep 11, 2012 | 2000 Pontiac Sunfire
1997 gmc 3500 hd ...new headlight switch , new dtr relay, all grounds good, daylight running lights work ,marker lamps work...headlights will not come one but marker lights do..highbeams do not work either
I am having the same problem please let me know if you came up with a solution! I have replaced headlight switch and relay, and combination switch. My problem is it will start working on its own, then at night they wont come on
Dec 01, 2010 | 1997 GMC Sierra
Marker lights wont work on my trailer. but the break lights and turn signals work. I checked all fuses in the main fuse box and they all look good
96 gmc topkick truck... marker lights won't work... where do i find a fuse box diagram... which fuse box???
Oct 20, 2010 | 2006 GMC Savana
Drivers side front and rear marker (tail light) are not working but the turn signals are and they are the same bulb marker lights
check bulbs then fuses
bulbs are dual filiment means there iss 2 different wires inside the bulb and 1 will usually break but the other wont
Jan 28, 2010 | 2006 Jeep Liberty
Crayola Marker Airbrush Set Logo
43 people viewed this question
Top Crayola Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Crayola Office Equipment and Supply Expert? Answer questions, earn points and help others
