Question about Samsung Galaxy Tab Tablet PC
Frozen tablet screen froze, was not able to perform any function or even turn off...knew battery was getting low so i plugged it in to charge & left it for a while...when i came back, tablet was off...tried to turn on but would not do that either...checked charging cord, & occasionally the screen would come on (w/the picture of the battery) as it does when u plug it in to charge...however, it would not indicate that charging was in progress...now it wont do anything???????
agc93
  • 44 Answers
SOURCE: How do I know when my Samsung Galaxy Tablet is
The Tab takes quite a long time to charge (not sure why). Note that the Tab cannot charge from a computer USB port (only from the included AC adapter. When the Tab has finished charging, it should put out a notification (open the notification drawer by pulling down on the status bar) saying the battery is fully charged and to unplug the charger. Other than that, you would have to install a third-party app like Smart Battery Monitor (see here) and watch that to see when it is full.
Hope this helps, Alistair
Posted on Mar 15, 2011
nashsaint
  • 172 Answers
SOURCE: I have been trying to
Most likely that it's faulty. Sometimes it takes awhile before it charges itself, specially it you drained. But if you left it plugged in for a day and still nothing happened then I think it's gone dead.
Try the following though and see if it helps.
1. Press and hold the power for about 10-15 seconds. or
2. Press and hold the power and the Volume up or Volume down at the same time for about 10-15 seconds.
If nothing happens then I suggest you send your tab for a repair.
Hope it helps.
Posted on May 06, 2011
nashsaint
  • 172 Answers
SOURCE: tablet is frozen will not
Try one of the following:
- Hold the power button for 10 seconds
- Hold the power and up volume for 10 seconds for recovery mode
- Hold the powe and down volume for download mode for 10 seconds
If none of these work then your battery might be completely drained and dead. I suggest you send your contact Samsung Support.
Hope this helps.
Posted on May 07, 2011
alpug
  • 1961 Answers
SOURCE: my tablet froze and now
Hello!
Here you can try the following procedure to unfreeze your tablet:
First: Hard Reset
1. With the Samsung Galaxy Tab turned off, press and hold the VOLUME DOWN button, and then, briefly press the POWER button.
Second: Remove SIM card
1. Take out the SIM card and put it back in.
2. Then it will turn right on from the beginning if you press the power button.
3. If that doesn't work, it means it needs to charge.
Third: Resets
Try one from the procedures below
1. Hold the POWER button for 10 seconds
2. Hold the POWER and UP VOLUME for 10 seconds for recovery mode
3. Hold the POWER and DOWN VOLUME for download mode for 10 seconds
If none of them works. Remove the battery and leave it off for 10 minutes. Then, return back the battery. If problem persist in the future, I would recommend to replace the battery.
Posted on Aug 30, 2011
KingDWS
  • 1606 Answers
SOURCE: My galaxy tablet was fine
You can damage the battery but it is very rare to actually do that. What you need to do is plug it in to the wall charger and leave it alone over night. At that point it should be just fine. it will actually start to show some signs of life after a few hours but don't be tempted to do anything wih it. it will first show a charge light or something after maybe 40 minutes if it is a faster charger.
If it shows no life the next day then you can try charging again but at this point you may hae a problem that requires either a battery replacement or warrenty. The battery has a microcontroller on it and when the battey gets real low they do not behave that well and typically you get the stone dead brick behaviour. And most people do not let it charge long enough to get it working. It is possible that there are other problems but those are usually moore serious and require replacement of the unit. The battery can be replaced but requires the etire case to be disassembled.
So charge it then check your warrenty and it may need serious repairs or to be replaced. If it is out of warrenty then you need to be careful on the cost verses replaceemn
Posted on Mar 23, 2012
Froze and wont charge or open up. It shows battery but not charging stays frozen. help Please!
Feel your chrger, Is it warm to the touch? If it isnt, you may need to replace it. Can you turn the tablet turn off and can you turn it back on? What is the level of the battery?1/2, 3/4?
Oct 21, 2015 | Tablets & eReaders
Why is my tablet frozen?
Try to do a HARD FACTORY RESET
Might help you if you give make and model of your tablet
May 30, 2015 | Tablets & eReaders
Why is the screen frozen?
If you can't turn it of, leave it till battery discharges. Charge it again. If still haged up, take it to a repair service
Apr 11, 2015 | Amazon Kindle Paperwhite
Froze on black screen that says android have tried holding down power and volume still froze
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it.
Support Troubleshooting Guide
Feb 23, 2014 | Kocaso MID-M750B MID-M750B 7-Inch Tablet...
Frozen won't come on
change the battery and try to power it on again
Jan 22, 2014 | Samsung Galaxy Tab Tablet PC
Tablet froze and now doesnt restart
Leave your tablet charging for a hour minimum. The battery might be so dead it has no power to start up at all. You get in to recovery mode do restore to factory settings.
Jun 02, 2013 | Coby Kyros 716829701508 Tablet PC
My samsung galaxy tab 2 has a frozen screen I can't even turn it off help
Here is how you fix this problem: Hold both the power button AND the volume UP button down at the same time for about 5-10 seconds it should restart. You don't lose any info doing this.
Mar 26, 2013 | Samsung Galaxy Tab 101 Tablet...
Screen is frozen
Couldn't even turn mine off ... researched this.
SIMPLE SOLUTION: Hold the power button down for more than ten (10) seconds. WORKED!!!!
No longer frozen.
Mar 09, 2013 | Samsung Galaxy Tab Tablet PC
How do i unfreeze my android tablet
My Pandigital screen is frozen, all I get is a green android with a triangle with an explanation mark inside it. How do I reset this?
Oct 28, 2012 | PANDIGITAL SuperNova
Non responsive (battery is fully charged). Screen has frozen up.
There is a reset button at the bottom (insert paper clip in pinhole). If all attempts trying to unfreeze it fail, you may have a logic board issue. Are you sure the Kindle powers up? Try to power up your Kindle with a different battery. If that fails, you can get the part at Kindle Repair and there is a guide that shows you how to open a kindle and install parts at Kindle Repair Guide.
May 29, 2010 | Amazon Kindle Wireless Reading Device
Samsung Galaxy Tab Tablet PC Logo
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
