Question about Acer Cromia Chromebook PC Notebook
Black screen on acer chromebook c720 - Acer Cromia Chromebook PC Notebook
4 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: my acer chromebook AC710 SCREEN IS CRAZY CANT SEE ANYTHING BUT COLORS AN LINES WHAT TO DO?
The reason your monitor is in screensaver mode, (Read your other problem too), is there is no video signal coming to it.
No Signal
This is because the Netbook isn't sending one.
It isn't sending one because apparently you have graphics problems. Problems with graphics hardware.
So no, there is no Sync, or settings to change on the monitor.
(It is Not a video/graphics card. Your laptop uses Integrated Graphics. Intel HD 3000 Graphics )
However the point is moot now. Netbook is being sent in.
Point now is getting the info off the Harddrive, before some geek looses it.
(I'm a computer geek too, so that was no slam)
Remove the Harddrive. Then install it in an external enclosure.
You've seen an external enclosure, if you have seen an external harddrive.
You can buy just that 'outside case', too.
The external enclosure has a USB cable going to it.
The USB cable goes inside the enclosure, and connects to a small circuit board, with an interface on it.
The harddrive plugs into the interface.
The external enclosure comes apart VERY easily. Manufacturers make it easy to open the external enclosure, and install the Harddrive.
Usually a 2 piece case. One screw to open. Remove cover, plug Harddrive in, replace cover.
Plug USB cable into a USB port, on a working computer.
This is one example that will work with your Harddrive,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
[Harddrives are measured across their width.
A laptop harddrive is 2.5 inches across in Width. 2-1/2 inches.
A desktop harddrive is 3.5 inches across in Width.
Three technology styles of Harddrive, are presently being used;
1) IDE (PATA),
http://en.wikipedia.org/wiki/Parallel_ATA
2) SATA,
http://en.wikipedia.org/wiki/Serial_ATA
These two types of Harddrives use mechanical parts. For example a Spindle, Spindle Motor, and Platters,
http://computer.howstuffworks.com/hard-disk.htm
3) SSD,
http://en.wikipedia.org/wiki/SSD
No mechanical parts. Just electronic components. (Solid State)
Your laptop uses a 2.5 SATA harddrive ]
Going on..................
I haven't had any direct dealings with this laptop. Or the Aspire V5-171 version.
I see no Service Manual listed.
Searching the internet for Harddrive replacement info though, I ran into that there is a large panel on the Bottom of the Netbook; which has a single Philips head screw in the middle.
Remove the screw, remove the large panel.
This is supposed to be in the User's Guide, but cannot seem to download it right now to see.
It will be in replace the Memory. Ram Memory.
The Harddrive should sit in a compartment area all it's own.
The Harddrive itself will be in a sheet metal Caddy. Harddrive Caddy.
Remove a screw, or screws; to remove Harddrive, and Harddrive Caddy.
Once screw/s are removed, L@@K at the Harddrive.
There should be a piece of 'silk strap', to pull on.
Keeping Harddrive flat, and down in Netbook, pull on the strap; and pull the Harddrive across towards the OUTSIDE of the Netbook.
You are unplugging it.
You DO NOT want to lift straight up on the strap, as you will bend contact pins.
Once the Harddrive is slid over, then lift at an angle; and remove.
Lift up on the Back of the Harddrive.
This is the opposite side of the one that plugs in.
Open the external enclosure case, slide the harddrive in; then close the external enclosure case. (Referring to Tigerdirect example. Other external enclosures will be different)
Plug the USB cable into any working computer's open USB port.
Look in My Computer/Computer. (WinXP/WinVista - Win 7)
The external harddrive will be shown.
DOUBLE-click on the drive letter it is next to.
Have problems with that post back in a Comment.
Your Netbook, is supposed to be just an ACER Aspire V5-171 series of Notebook PC; with a Chrome logo on it.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Mar 05, 2013
jonsnell4
  • 22787 Answers
SOURCE: acer chromebook
Try running chkdsk/f to attempt to clear errors.
Posted on Nov 26, 2013
highwheeler8
throw any acer chromebook in the garbage or give it to a preschooler to learn to do absolutely nothing with. its the biggest waist of money ive ever spent in my life.
Posted on Mar 01, 2014
How do I obtain a copy of the user's manual for the Acer C720 Chromebook?
Acer has the user manual for the C720 on their support page. If you start on the Acer homepage: https://www.acer.com/ac/en/US/content/home . Scroll down to the bottom of the page and select Drivers and Manuals (second line in the second column "Service"). Then use the drop-down menus to select Category = Netbook, Chromebook, Series = Chromebook adn Model = C720 . The C720 product page is currently https://www.acer.com/ac/en/US/content/support-product/4984?b=1 . Expand the Documents section then click on the Download button on the right side of the page on the User Manual line. The direct link to the manual is http://global-download.acer.com/GDFiles/Document/User%20Manual/User%20Manual_Acer_1.0_A_A.pdf?acerid=635538850729499895&Step1=NETBOOK,%20CHROMEBOOK&Step2=CHROMEBOOK&Step3=C720&OS=ALL&LC=en&BC=ACER&SC=PA_6 .
I hope this helps.
(The manual is a PDF.)
Feb 11, 2017 | Acer Computers & Internet
How do i connect my acer C720 chromebook to a CANON PIXMA MG 4250 printer , i am using 4GEE WiFi and i am not familiar with computers so step by step please
for chrome book
http://acer.custhelp.com/app/answers/detail/a_id/10397/~/printing-with-the-acer-chromebook
For the printer
PIXMA MG4250 Wireless Connection Setup
if you follow these instructions they should be all you need
Jun 24, 2015 | Acer C720 11.6" Chromebook - 2GB Memory -...
Owners maual needed for acer c 720 need to know how to change a fogotten password namly picture screen
Here is the a link to the manual. You can also download it.
http://www.manualslib.com/manual/578819/Acer-C720.html#manual
Feb 02, 2015 | Acer C720 11.6" Chromebook - 2GB Memory -...
How do i upgrade ram on acer c720 chromebook
Your question was posted in the PRINTERS & SCANNERS section. You will need to resend it to the appropriate section.
Oct 31, 2014 | Acer C720 11.6" Chromebook - 2GB Memory -...
Owners manual
You can find the user manual under documents
http://us.acer.com/ac/en/US/content/drivers/4984;-;C720
Aug 21, 2014 | Acer C720 Chromebook Gray 11.6" Notebook...
Acer Cromia Chromebook PC Notebook Logo
101 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
