Question about Canon PIXMA MP160 All-In-One InkJet Printer
Canon Pixma iP3600 will not change paper source
pagebor
  • 2785 Answers
SOURCE: Pixma ip3600 not changing to 2nd black ink tank
you cant swap it for printing you have to refill the empty one
Posted on Feb 01, 2009
  • 153 Answers
SOURCE: Canon Pixma MP830 printing red/orange hue on glossy photo paper
are you using geniune canon glossy paper??? it is designed for the printers and really is the best for the machines
Posted on Apr 14, 2009
SOURCE: Canon ip3600: New Printer doesn t recognize that
Possible solution:
In Preferences/Properties, make sure that "Automatically Select" is selected in "Paper Source"
  • 5479 Answers
SOURCE: Canon Pixma ip3600 message saying printer is not online
This could be a problem with the port. If you have the printer attached to a USB hub, directly connect to the computer. Try connecting to a different USB port and test the current port with a known working device. Consider trying a new USB cable (minor damage could be a factor in signal loss).
I hope this helps.
Posted on Feb 04, 2010
Testimonial: "Thank you,I did replace the USB cable and all is well."
  • 164 Answers
SOURCE: My new ip3600 is only printing green, any
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 07, 2010
My Canon ip3600 has full ink, there is paper in the tray. It will print the page I want it to print. However, there isn't any ink / text on the pages that are being printed
It sounds like either the ink cartridges are clogged, or if you've installed new ones, it could be you forgot to remove the tape that covers the ink jet on them. If clogged, you can use alcohol on a Q-Tip to clean the jets.
May 06, 2011 | Canon PIXMA iP3600 Photo Printer
Canon IP3600, error # 6A80. Can't fix the issue
I have pixma ip3600 canon printer, been used 8months working fine, but today, when I turn on just wait for little whileand the amber light turn on, and when I open thetop cover the printer head won't move at all, please show me how to fix the problem. thanks. Email ( bui_lac972@yahoo.com )
Apr 13, 2011 | Canon PIXMA iP3600 Photo Printer
How to print from top tray canon ip3600
Hi!
Depending on the windows or operating system you got,Go to ''Printers and faxes or control Panel'' Select the canon printer and right click on it,scroll to properties and click on it!Go to the maintenance tab and select it,There is a option to set paper feed,Select rear tray and apply!!
Good Luck!
Apr 01, 2011 | Canon PIXMA iP3600 Photo Printer
I hope this helps.
Feb 04, 2010 | Canon PIXMA iP3600 Photo Printer
Starts to feed paper and then stops and says it is jammed, it's not.
We have become aware of an incompatibility between the ZoomAlbum software and the Canon PIXMA printers listed below. This issue applies only when using the ZoomAlbum software to print Photo Album covers with Mac OS X.
Affected Models
PIXMA MP240, MP250, MP480, MP490, MP560, MP620, MP640, MP980, MP990, MX320, MX330, MX860, iP3600, iP4600, iP4700 Printers
Phenomenon
The affected PIXMA printers are designed to feed paper via the rear tray with a center-feed mechanism and two paper guides. However, the ZoomAlbum software was intended to feed paper from the rear tray in printers with a right-feed mechanism and a single paper guide. As a result, when using the ZoomAlbum software with Mac OS X to print Photo Album covers with the affected Canon PIXMA printers, the printed image may shift.
adv_zoomalbum_1.jpg Countermeasure
To remedy this problem, please use the following settings when printing Photo Album covers with Mac OS X:
1. Click System Preferences
2. Click Print & Fax
3. Select your Canon PIXMA printer as the default printer
4. Select DL Envelope for Default Paper Size in Page Setup
Note: Be sure to change the Default Paper Size back to Letter after printing the cover.
Jan 26, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Have just got canon ip3600 printer and can't seem to load bottom paper try properly. Help please? Error message keeps telling me there is no paper. There seems to be no indication just how far to push the...
You may not have removed the piece of packing foam that lies in the track under the printer head. It is a long, narrow dark grey piece of foam that is wedged tightly in the track and is accessible when you lift the top cover. Unlike the pieces of orange tape it is hard to see and it is not shown in any of the setup instructions. If you don't remove it it prevents the paper in the A tray from moving and generates the "paper empty" message.
Nov 23, 2009 | Canon PIXMA iP3600 Photo Printer
Canon PIXMA IP3600 Service error 6C10, and doesnn't print at all
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Sep 27, 2009 | Canon PIXMA iP3600 Photo Printer
Possible solution:
Mar 31, 2009 | Canon PIXMA iP3600 Photo Printer
Feb 01, 2009 | Canon PIXMA iP1600 Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
old marine
old marine
