Question about Mitsubishi WD-60737 TV
Wd-60738 solid red light - Mitsubishi WD-60737 TV
3 Suggested Answers
  • 68 Answers
SOURCE: wd-52725 had blue screen no picture or sound
you may be on the incorrect input channel. look for an input or tv video button and choose each input until u get a picture
Posted on Mar 03, 2010
SOURCE: mitsubishi wd-60738 picture comes on and shows the blueish purple mitsubishi logo,then flickers and turns off.Then the indicator shows solid red light.got another lamp.Same problem,any suggestions?
You have a bad ballast board that ignites the bulb
Posted on Jul 04, 2016
REPLACE BOTH POWER BOARDS ON A MITSUBHIS1 60738 IM GET 4 BLINKING YELLOW AND 4 RED I NED TO NO WHAT THIS CODE MEANS PLEASE HELP IVE DONE EVERTHING I CAN.
That is a 44 error code. It means that the LVDS cable is not being detected. Make sure that you got it connected securely and that it didn't get torn. I hope this helps.
Nov 30, 2015 | Mitsubishi WD-60738 60 Projection TV DLP...
Wd-52627 tv turns off on its own,then solid red light
I just replaced my lamp and it worked for a day. TV only gives me sound. Black screen. Light goes from green to red lamp light after about 30 seconds. Did you get a fix?
Jun 04, 2014 | Mitsubishi WD-52627 52" Television
I have a Mitsubishi WD-60738 - about 3 or 4 years old. On Sunday heard a electronic 'popping' noise and TV turned off. When I turn it back on, i get audio, but no video - screen stays dark. Did my
Check and replace the damaged component/s at its main power supply regulator section circuit. The sound you heard might be due to a busted capacitor. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 24, 2014 | Mitsubishi WD-60738 TV
I just got a new blub for my mitsubishi wd-60738 it plays ok for about 5 min then the screen flickers and i hear a whinning noise then it shut and a red light comes on in the front for about 10 sec then a...
Color wheel should be checked. Might need replacement. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 26, 2013 | Mitsubishi WD-60738 TV
Mitsubishi wd-60738 overheating
Look in the back for the fan area and see if you can feel/see it running. May be blocked or need to be replaced
Sep 16, 2012 | Mitsubishi WD-60738 TV
WD-60738 mitusbishi tv comes on for a few seconds and shuts off and a red light stays on
This problem is most likely caused by the lamp needing to be replaced. The original lamp for these televisions are designed to last approximately 6000 viewing hours. When they start to reach the end of their life cycle, they will usually begin to dim, and some so bad it begins to look like a bad standard definition channel as opposed to an HD broadcast. The manual suggests you replace the lamp, and in the interim it says to max out the contrast and brightness, among other things. Still, the red indicator on the front of the set means you need to change your lamp.
NOTE: I caution you to use the recommended, original replacement lamp. There are many cheaper substitutes, and as the old saying goes "you get what you pay for", in this particular instance, it is very true. You will either experience poor picture quality, or it will be a very short lifespan/life cycle of your lamp before needing to be replaced yet again.
Aug 13, 2012 | Mitsubishi Wd-60738 60-inch 3d Dlp Hdtv
Mitsubishi WD-60737 TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
