Question about KitchenAid KERC700LBS Electric Kitchen Range
Control Panel does not light
Every thing else works fine but there is no light on the control panel.
  • 1314 Answers
SOURCE: kitchenaid kgri801pbs
there is a thermal fuse in the back of the oven that more than likely has tripped during self clean poor air flow around can cause this power surges during self clean can too you have to pull the oven out and remove back panel to find it
Posted on Jan 10, 2008
elhomspam
  • 58 Answers
SOURCE: Buttons don't work [7, 9 & Start]
make sure the unit is not control locked, usually holding start for 5 seconds activates this, most kitchenaids contain a lock symbol on control panel so hold that if you have it.
if its not control locked and not in sabbath mode (sometimes this is a SAB or to some looks like 5A6 on control panel) holding clock pad for 5 seconds activates and deactivates this same as start does with control lock
when you order the part you want to replace the part called Clock AKA PCB AKA ECB, these are the three most common names, the control panel is the decorative cover
Posted on May 02, 2008
Techsim
  • 59 Answers
SOURCE: I have the same problem as djeff757 post on Kitchenaid KDRP467
I don't recall a control panel fuse for this model, there is, however, a thermal cut-off on the rear of the unit. The part number is 8300802 and you simply have to remove the rear panel to access it.
Posted on Dec 29, 2008
  • 135 Answers
SOURCE: CONTROL PANEL WON'T WORK AND HAS - F2 E0 - ERROR
Remove the power and disconnect all connectors to the control board and put them back on one at a time. If it still won't work the board may be faulty.
Posted on Aug 26, 2009
Bravo 2012 gas dryer control panel
I have the same dryer. My control panel went dead today too. Light in drum works just fine. Nothing working at all on the control panel.
Mar 07, 2014 | Maytag Bravos 7.0 Cu. Ft. Gas Dryer
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
1993 Chevy k1500 HVAC Controls light up when they want to. when the panel lights up everything works fine. but when it doesnt nothing works. checked the connection of the panel and everything looks fine....
What you need to do is replace the control head.They had problems with these.Changed a few myself.If the connections and the wiring looks good then replace it.Hope this helps.Good luck.
Feb 23, 2010 | 1993 Chevrolet K1500
Control panel on my fridge
Pull the power cord for 5 minute to reset the control board. if this control panel malfunction still exist after the reset, replace the control circuit board.
This is a typical control fault that should be corrected by pulling power for 5 minutes. if not, this reset will confirm major damaged to the circuit board.
May 25, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Control lock
bottom button on last row on right side of control panel depress and hold for 3 seconds it should activate or deactivate control lock if this does not help you could have a faulty control panel
Dec 14, 2008 | Whirlpool GEW9250 Electric Dryer
F 1
control failure remove 3 screws along rear of control panel lift panel to acess control
Sep 18, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Panafax uf-890
Sound to me that the control panel is faulty the only thing you could do is check the connections between the control panel and the main board if they appear fine then most likely that the control panel will need to be replaced.
Hope this helps
Thanks J
Jan 03, 2008 | Panasonic Panafax UF-890 Plain Paper Laser...
Will not power on. Please Help!!
Error code 12 means normal operation. On these models we have found that a switch is sticking on the control panel not allowing the set to turn on. Disconnect the control panel. You will be able to use the remote on it. To find the plugs for the control panel: Remove the speaker grill and front panel, then follow the wire to the connection. Remember to unplug the set before putting your hands inside of it. Tell me how it went. Lead Tech
Dec 14, 2006 | Mitsubishi WS-55511 55" Rear Projection...
KitchenAid KERC700LBS Electric Kitchen Range Logo
85 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
