Question about Bulova Amesbury II Anniversary Collection Clock Watch
B8915 amesbury - how to shut off chime - Bulova Amesbury II Anniversary Collection Clock Watch
How to turn-off chime of elgin Westminster chime wall clock with pendulum?
Are there two batteries. One for the time and one for the chime? Try taking the one for the chime out and it should stop chiming. mine worked that way but is a different make.
Feb 04, 2017 | Elgin Watches
I have a Dakota Daniels grandfather clock. The chimes work, the pendulum works, but the clock hands don't move.
Change the batteries. The weight makes the pendulum and chimes work, but the clock in this thing is battery operated :>)
Accurate hourly Westminster chime movement tolls the hour - Automatic night shut off
  • Cathedral pediment, blue moon metal dial with raised roman numerals
  • Pendulum, weights and chains are made out of metal - Real tempered glass
  • Sturdy construction - Made of MDF & solid wood - Batteries (3-AA & 2-C) not included
  • Dakota Daniels grandfather clock Google Search
    Dec 12, 2016 | Dakota Watches
    NEED DIRECTIONS FOR CHIME
    clocks chime the hour
    what is the point of having a clock that chimes every 2 hours because you will not know how long it was from the last chime or be able to calculate the time between chimes
    Dec 28, 2015 | Watches
    How do I shut off the hourly chime on my aqualite watch?
    Try Googling (aqualite)(model)(manual) without parens for instructions.
    Dec 30, 2017 | Watches
    How do i synchronize my chimes on a westminster quartz abacus 401c wall clock
    If it is like mine you press the test button until you hear the chime. Wait for the hour chime to go and count it. If it chimes once for 1PM and you need it set to 6PM then you press the test button to reset the chime and repeat press the button 5 times. This will set the chime to 6 PM. If you get lost on the time press until it makes no noise. This means you are 11PM or later and continue to then press until it makes noise again. Count the hour chimes and you are at the count in the AM. Repeat the steps and keep pressing to get to the proper AM or PM hour count..
    Jan 16, 2011 | Watches
    Can't get the Hourly chime to shut off - tried going to alarm, then hitting adjust Button - alarm shuts on or off , but not Chime
    using the mode button (lower left, go to the alarm. once at this screen, hit the "12/24H" button (lower right). now hit the "adjust" button (upper left), that should toggle the hourly chime on and off. you'll see the bar next to 'SIG'. when it's lit, it's on, when it's blank, it's off.
    Oct 27, 2009 | Casio Illuminator AQ150W1EV Wrist Watch
    Same problem, I cannot shut off hourly chime. Men's model CG111M
    I have a Timex marathon, and this worked for me:
    Press 'mode' button till you get to 'alarm' screen. Then press start/stop. This will toggle the chime on and off.
    Oct 07, 2009 | Timex Marathon Night Light Watch
    On the CG 111M, the chime is turned off and on by pressing the start and reset buttons at the same time. Those two buttons are on the right side of the watch face.
    Oct 05, 2009 | Watches
    Kenneth Coleman Watch Beeps Every Hour! It Needs to STOP!
    think of the top buttons from left to right as A & B and the bottom buttons from left to right as C & D. The way to turn the chime off and on is by holding the C & D Buttons simatainiously and the pressing the B button. This will allow you to turn the Hourly Chime Off and On. When you see the digital chime pattern in the display the chime is on. When no pattern is shown the chime is off. Hope this helps the ton of people who have purchased these watches & either did not have instructions with or lost them. This perticular watch has been annoying the whole household for quite sometime and has now been put to rest..lol
    Mar 27, 2009 | Watches
    Timex westminster anniversary chime clock doesn't chime correct number
    Take the batteries out from the base, where the chime mechanism is. Wait till it gets close (20 seconds till) to a specific hour time, like 8:00 or 9:00, replace the batteries for the chime mechanism. And then count the chimes at the hour. If they are correct, you are set. If they are incorrect, turn the time back 15 minutes before the hour and bring it right back and monitor the chimes again. Hopefully this should fix it. Please post the results.
    Oct 04, 2008 | Watches
    Bulova Amesbury II Anniversary Collection Clock Watch Logo
    Top Bulova Watches Experts
    Geoff
    Ansel Alberto
    Ansel Alberto
    Are you a Bulova Watch Expert? Answer questions, earn points and help others
